Question about Philips 27PT5441 27" TV
I can't program the cable channels on a used philips TV
I have a Philips 27' older TV model PCW127 C121. I'm having trouble getting all the cable chanels programed into the TV w/ remote. And I have no manual. The ID is 62594337
Peter Garich
5 Suggested Answers
  • 476 Answers
SOURCE: Universal Remote not working
With nearly all brands of universal remote control, there is usually more than one code for Philips. Keep going through the codes until you find one that works correctly.
So if you know that the 1st code doesn't work, then don't save it, and move to the next.
You may find that several codes will actually put the TV into standby, but other functions will be different.
Posted on Mar 13, 2008
  • 458 Answers
SOURCE: i have a philips tv whith no remote from a hotel
If this has been a hotel TV then you cannot tune it in manually as the Hotel Mode will be activated & can only be re set to normal TV use by using a specific code from the remote control. The only other way is to re-initialise the internal memory using software that is only obtainable from a Philips dealer.
Posted on Jul 12, 2009
  • 10 Answers
SOURCE: Philips Magnavox 2783 c101 - will not auto program tv channels
Ya what you got to do is Grab your tv, and throw it out your window. Garbage tv with built in problems made to be fixed. I had the same tv and i had many problems with it before. Just buy a new one boss.
Posted on Feb 17, 2010
  • 5 Answers
SOURCE: philips tv model id: 19pfl5422d/27 terrible loud sound
The issue is 4 1000uF X 10V on the main board under the shield close to the connector that from the power board. you will see them because they will be FAT( exploded)
Posted on Apr 07, 2010
Philips Magnavox TV TS 3260 C121
Audio decoder section circuit fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 22, 2016 | Philips Magnavox 27MS343S 27" TV
I have a 27 inch philips tv serial number 62573703 model #pc0127 c121 i tryed to go to the menu and it only gives me the caption on or off and the sleep timer i need the channel search trying to watch dvds...
Hi if you are using a universal remote control that will be the cause, if not the tv has a problem with the system control IC this IC is responsible all the signal being transmitted to the unit solving this fault must be check and test in actual by a well experienced technician I suggest that you should contact a service technician to do it for you and save you from stress. Or replace the battery of your remote if no changes you really have to contact a tech. good day and best regards.
Sep 12, 2011 | Philips Televison & Video
I have a philips tv,it's a 2002 model(pcw127 C121).It was originally a hotel room tv and it was given to me.I only want to use it to watch movies.I plugged in the dvd player to the two jacks in the front...
Hi Russell,
TV's most commonly found in Hotels do not have an input button which is what you would use on almost every TV set out there.
I believe that if you go to channel 2 and then channel down there maybe an AV1, AV2, Video1, Video2 or even an A1, or A0, etc.. This is what you will need to tune the TV to in order to watch a movie from the VCR or DVD player using the RCA Cables.
Unfortunately there is not a user manual online at this time, but this is where you would find it:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=PCW127C199&slg=en&scy=US
Scott
Feb 11, 2010 | Televison & Video
Channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Nov 18, 2009 | Philips Magnavox 27MS343S 27" TV
Reference to Phillips Magnovox Model PR1302 C121.
turn on tv,it turns back off,without lighting screen.
May 04, 2009 | Philips Magnavox 27MS343S 27" TV
Can only get channels 1-13,can't get the cable channels
Press Menu
Scroll right to TUN (Tuner)
Scroll down to TV/CABLE
Toggle from TV to Tuner
Problem Solved
Feb 15, 2009 | Philips Magnavox 27MS343S 27" TV
Philips magnavox 25tr19 c121 problem
Still need info..? Can you replace soldered in parts.? Let me know.........................T.
Nov 16, 2007 | RCA F31672ET TV
Philips 27PT5441 27" TV Logo
110 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
