Question about Coleman Heating & Cooling
Coleman 7970-856 gas furnace heater problem
Blower cycles on and off
5 Suggested Answers
  • 70 Answers
SOURCE: Coleman presidential II furnace blower on and off
Sounds like the flame sensor. But it could be the thermostat. Is the furnace standing pilot or electronic spark or hot surface ignition. I would start by checking thermostat. Turn power off to furnace take thermostat off wall and take wires marked r & w and connect them together. Turn power back on if furnace works then change out thermostat.Most eclectronic ignition Furnaces have a flam sensor, You could take flame sensor out and clean it up with steel wool or wire brush. If you need anymore help just reply back .
Posted on Jan 17, 2009
  • 70 Answers
SOURCE: Coleman Presidential II mobile home
Is this furnace standing pilot or electronic ignition. If standing pilot i would check furnace filter then the thermastat. To test themostat first turn power off to furnace. Take thermostat off wall and take wires labled R & W and connect them together. If you have electronic ignition I would start with cleaning the flame sensor with steel wool or wire brush.If you have and more questions i will be glad to help.
  • 92 Answers
SOURCE: Need replacement glass for pilot cover of Coleman Presidential II
the glass is there as a service tool to veiw pilot and flame or relite just get a peice of sheet metal and cover hole with it ,it will work short term or long term
Posted on Feb 05, 2009
  • 252 Answers
SOURCE: I have a coleman presidential model#7670
NO, the regulator in the valve MUST be converted too!
Posted on Oct 05, 2009
heatman101
  • 43501 Answers
SOURCE: Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Posted on Nov 12, 2009
I have a coleman furnace model 4066A656
Make sure your air filter is clean. Is the thermostat satisfied? or is the room temp. still below the thermostat setting? When ever you have to turn the power off and then back on to a furnace that usually indicates that the furnaces ignition control locked out. The first thing that I would try is cleaning the flame rod.
Mar 02, 2017 | Coleman Heating & Cooling
Coleman evcon furnace
How old is your furnace? Does it have a circuit board that controls everything, or are there separate controls for each function?
Nov 19, 2013 | Heating & Cooling
I have a coleman furnace it comes on the electric igniter glows red the gas comes on then the blower starts and the fire goes out it gives 2 different code for this 1 is ignition failure and the other is...
I would have the ignition control board replaced. That is what tells the gas valve to come on and if there is flame or ignition it will keep the gas on if the flame sensor gives the board a signal that the burner is lite. By you shuting power off and on to the furnace it resets the board and it will go through its cycle again.
Feb 10, 2011 | Coleman Heating & Cooling
My Coleman DAGT gas furnace blower fan will come on at time when there has been no heat cycle or will stay on after heat cycle is done. I have replace the the themostat and put in new intregated control...
try looking at the afc the fan control might need cleaning at the back of it could be filled with dust, or blocked air filter afc works on temp rise to start fan running and temp fall to stop running check settings on the afc thhey should be in your manual or afc might need changing
Sep 11, 2010 | Coleman Heating & Cooling
I have a Coleman Evcon gas (propane) furnace. When the t-stat is switched to heat the furnace heats up but the blower will never turn on. The unit then shuts down and tries to cycle again. I have replaced...
If the unit fires but the main blower fan doesn't come on the the unit is shutting off on a temp high limit switch and it sounds like the problem is the main blower fan motor or control
Jan 18, 2010 | Coleman Heating & Cooling
Coleman furnace -- fan runs, ingniter won't light,
The chances are that the furnace was running when the power went out. This will cause the high limit switch to cutout and needs to be manually reset.
You will find that switch in the blower compartment near the blower. Usually somewher near the highest point of the cabinet.
Push the little red button firmly till it clicks.
When the power goes out while the furnace is running the heat builds up because the blower shuts down immediately and causes this limit switch to cut out.
If you have a electric tester you can also follow the low voltage circuit till you find the open switch. Ther is usually a wiring schematic on the door cover of most furnaces.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 09, 2009 | Coleman Propane Forced Air Heater...
Jan 17, 2009 | Coleman Propane Forced Air Heater...
Coleman Presidential II mobile home furnace. When burner lights the blower cycles on and off instead of blowing constant through burner cycle.
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Heater blower motor cycles on and off (frequently). I have a class 2 LR95329 Honeywell Thermostat
The clicking noise is a relay or switch of some sort. You are right about that. I have 2 questions. 1) does the thermostat have a mercury bulb in it? 2) when the fan shuts off and on, does the burner stay on?
Nov 05, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
103 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
