Question about Kenmore Elite 45986 Front Load Washer
What does a flashing code HF mean? This is a kenmore elite HE3t washer. thanks
    Problem Solver:
  • 8 Answers
That is the code for a water inlet issue.  Meaning "no or insufficient water supply" according to the manual. It says to hit PAUSE/CANCEL twice to cancel cycle. Then unplug unit and check for:
Are faucets completely turned on? Are screens at the inlet hose connection to washer clogged? Are inlet hoses kinked? And last...Are inlet hoses frozen? After checking all those it says to plug back in, re-select cycle and press START. If problem still comes up call for service. I remember on another site someone had the same code coming up, all the inlet suggestions checked out OK and they had to call for service as it was something in the control panel/computer of the unit.
Hope your issue is something simple as suggested by the manual. Take care ; )
Posted on Dec 08, 2008
I have a kenmore elite HE3t and it has an F20 error code. What does this mean?
The F20 error code means; no water was detected entering washer or pressure switch trip was not detected after 6 minutes
Many times that is caused by a blockage a pinched fill hose,or the filter screen on back of washer where hoses attach to are clogged
Good luck,i hope this helps
Gene
Aug 01, 2011 | Kenmore Elite HE5t Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washing machine error codes
I am getting F35 error code. What is the problem?
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3t code problem
check your water supply make sure that you have both hot and cold water on at all times. Pull the hoses off and see if the screens on the water valve in the back is clogged.
Aug 10, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t
Here's a link that explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Read through these steps and let me know if you require further assistance. HINT: I'm assuming you have water entering the wash tub since you mentioned the washer will begin a wash cycle. Check for a siphoning issue or Drain Pump problem first. These are the simplest items to check. I hope this helps you.
PS There should be a tech sheet located inside you washer behind the lower panel under the door, or along the interior cabinet wall that explains all the error codes and how to troubleshoot. This may also assist you further.
Jul 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite washing machine
This code means its not getting a sufficient water supply. I was doing a cold wash and noticed it was sucking down some hot water, so shut off the hot. MISTAKE, after a little bit the HF code came up. Apprently it likes to decide for itself just how cold is cold. Darned Computers.
To make a short story long, when I shut off the hot, it apparently shredded the washer and sent the remnants down to the little filter thingy at the washer itself, whereupon they reassembled themselves into a clog, once again giving me the HF code.
(Check your user manual Troubleshooting section. I think it says to press Pause/Cancel twice)
Mar 30, 2008 | Kenmore Elite 45986 Front Load Washer
F20 code.
in my fixing f 20 needs a new cpu main board in the top washer middle back side
Nov 16, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3t
I am getting an F35 code on the washer has anyone had this problem
Sep 21, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
324 people viewed this question
Sal De
fordexpert
Robert Rankin
