Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven too hot!!
My oven (Whirlpool 30" self cleaning free standing) is about 5 years old. It suddenly started burning everything I try to cook because it is providing too much heat no matter what temp (high or low) I try. My husband tried to figure it out, but to no avail. Any ideas???? Thanks a lot!! Carol
  • macs178 Dec 14, 2008
    Thanks so much for the advice, but that didn't seem to be the problem. I just can't figure out what it could be. We got an FOEO code and unplugged the oven for 30 minutes (as suggested by another thinking it might be due to a power outage) but even that did not work. I have no clue! Thanks, a lot!! Carol
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds like a bad oven temp sensor, small 3-6 inch, metal probe in upper left corner of inner cavity, 2 screws and the sensor should pull right out, replace you should be fine
Posted on Dec 08, 2008
  • Ron Coons
    Ron Coons Dec 15, 2008
    F0 - E0
    Analog to Digital Failure
    Disconnect for 30 seconds - if display re-appears - replace control looked up your fault code. here what i found
Double oven no model number Whirlpool 14 years old Door is locked after self clean and display is blank
Your oven has resetable high limit thermostat that tripped off on the self clean cycle,im not sure if you have free standing,or a wall oven if freestanding the t-stat is on back panel if wall oven its behind control panel on upper oven and for lower oven its behind the grill between bottom of upper oven and top of lower oven. In either case it has a small red button that can be pushed in to reset it
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Whirlpool Ovens
Frigidaire free standing, electric, self cleaning oven
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 18, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The oven won't lock shut for cleaning
heatman101
Apr 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven wont come on
Cleaned the oven yesterday with self clean and the next day while cooking on the top it just stopped working
Dec 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I have an older whirlpool free-standing gas range and oven and the broiler works but the bake option does not, the oven doesn't get hot, any suggestions?
you may need to replace the bake ignitor. if it is glowing orange and not white, it isn't hot enough to light the bake. hope this helps
Oct 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Model SVE 47600 - oven door remains locked after self cleaning
Called an appliance repair serviceman....after checking it out...turned out to be a sensor that actually burned up (first time using cleaning feature!!). The oven got so hot it actually burned the wiring going to this sensor. Pretty scary! The repairman said he doesn't trust the self cleaning feature...recommended doing it the old fashion way! He's had to repair many ovens due to the lock remaining locked. IF you do use the feature, he said to absolutely remove the racks first because they will slowly warp and you'll end up replacing them due to uneven cooking (i.e. lopsided cakes). It cost me nearly $200.00 to clean my oven! Could have had my entire house cleaned for that amount!!
Jan 27, 2009 | Jenn-Air JJW8430D Electric Double Oven
Self cleaning
Sometimes, according to what I've seen.  My theory is that the elements are probably covered in grime and this causes the damage.  As far as the control...I don't think that makes sense.
Never use cleaner on the elements..also causes damage.
A typical duty cycle for cleaning is 2- 2.5 hours.  Longer and you could burn them up, too.
Nov 28, 2008 | KitchenAid KEBC101 Electric Single Oven
Oven staying hot a long time after it was turned off
Thanks for your reply. I contacted an appliance repair person I have used before and he told me about turning off the breaker, which I did. He suggested using an oven thermostat to see if it was heating to the correct temperature as a first step. It may be the thermostat, I do not know what the controller is as presented by one of the responders. At any rate I learned that my breaker for the oven is by itself and is not attached to the stovetop which is good. I will have to weigh the cost of replacing a part on a 20 year old builder quality oven with microwave on top to a new one. Any ideas on a new problem free model are appreciated!!
Feb 12, 2008 | Ovens
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
3,155 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
