Question about Fahrenheat Ceiling-Mount Industrial Heater - 7500 Watt
Electric space heater contactor won't stay latched
2-yr. old Fahrenheat FUH724 240VAC electric space heater malfunctioned this season. Contactor won't stay latched and cycles and cycles on and off every few seconds. Any cures other than a new contactor? 240V goes through high limit switch, contactor coil and thermostat. Would temporarily bypassing the thermostat and limit switch identify any contactor coil problems?
    Problem Solver:
  • 15 Answers
Jumpered the bimetal thermostat and everything worked smoothly. Tried to clean contacts in thermostat with no luck, so ordered a replacement. At least it was cheaper than the contactor.
Posted on Dec 12, 2008
K star electric pool heater
Had same problem K-Star 10 both contactors, Check all your connections, I found 2 loose. If the contactor closes and can't get enough power the voltage drops, contactor starts to chatter. Loose connections also cause arcing and fires. The manual says do not store clorine in the same room.
I took the contactors out, to the bench, applied 208volts to the coil and beat on them till they stopped acting up. Put them back and they work. They are very ugly on the inside I will replace them as soon as I can find new ones on Monday..
Jul 17, 2013 | Pool & Spa
My contactor will not pull in
If the contactor won't pull in the first thing to check is the low voltage circuit to the contactor. Is there 24v going to the contactor? If yes and the contactor is not pulling in, then you have a bad or dirty contactor. I have often time seen bugs get in between the contacts and stop the flow of electricity. If there is not 24v being supplied to the contactor then you will have to check your thermostat and the wiring from the furnace to the outdoor unit. Hope this helps
Aug 14, 2011 | Goodman Heating & Cooling
My Fahrenheat baseboard strip heater is a 1996 model, 120 volts. It only works for one thermostat cycle. The thermostat points open slowly and arc as they open. The points will not reseat to supply any...
Why not get a 24 volt definite purpose contactor and connect it to power?
Use a transformer to open and close the contactor and then you can use a low voltage 2 wire el cheapo wall thermostat to turn on the heater?
Dec 01, 2010 | Fahrenheat Electric Convector Baseboard...
Hobart am 14 electric heat does not turn on water temp just drops
Assuming that the machine fill cycle works properly and the float is intact, and the heater contactor doesnt pull in:
possible heater contactor malfunction: check for power to coil
High limit snap thermostat may be tripped or damaged ( needs to be manually reset). located in heater connection cover.
Thermistor probe and or wiring to it may be damaged
main control board may not be functioning properly. check output to heater curcuit
Feb 01, 2010 | Hobart AM14-253 Free-standing Dishwasher
Hi, I just purchased a FUH-54B at Northern Tool and Equipment and installed it this evening. I have a 30 amp double pole breaker installed, and I have 120V at L1 and 120V at L2. The ground is properly...
It sounds like you have 120v from line 1 and line to to ground. What do you have between line 1 and line 2?
You should have 220 or 240v. If you dont have this
the problem is at the breaker. Are the wires going to the same breaker?
If you do have 220 or 240 between line 1 and line 2 at the unit, then it appears thr problem is at the unit,
probably the thermostat isn`t turned up high enough?
If it has a contactor, is it pulled in? If not then there is
a control problem. If you are skilled and confident you
could simply push the contactor in and it should
operate or have an electrician do it. Most of the time
you can bypass the thermostat and close the
contactor that way.
Jan 04, 2010 | Fahrenheat FUH5-4 Heater
Contactor for La Pavoni Pub 2 espresso machine
1>Tom you must pay atention on electrical suply if coil of contactor, your contactor gets suply of electric wich passes through the contactor.
2>please go back to contactor and pay atention to coil suply you must have mistaken there something.
3> if it isnt visible than study the old contactor, was he 3 closed 1 open contact or 4 closed???? it can be that too, the contactor could not be with the same function.
Nov 18, 2008 | La Pavoni Pub M1 Espresso Machine
Carrier A/C units
Double check that the new contactor has the same electrical ratings on it. My guess is that the coil should be 24v while the relay should be able to carry the same amperage at 220v.
First shut off the breaker and disconnect switch for the furnace and outdoor condenser and call a licensed HVAC contractor:)
If you are determined to do it yourself, Then read the schematics first. Be aware, if you mis wire the system you may cause more damage than you have now. Not to mention your personal safety is at risk.
I am basing this on the most common style contactor found in my area.
The main relay side should be labeled. (eg. L1,L2-T1, T2). These should match exactly like the old one. L1 and L2 are the incoming power. T1 and T2 are the power leaving the contactor. All the 220v wires should correspond to one of these four terminals either by screwing them down or fitting the spade connectors together.
Usually the 24v wires will plug onto the coil (near the bottom, left and/or right sides of the contactor) silver spade connectors.
(STEP 1.) Leave all Wires Connected to your Old Contactor.
(STEP 2.) Remove the two mounting screws that hold the Old Contactor to the Air Conditioners casing.
(STEP 3.) Now Install the New Contactor to the old contactors existing location using the Same two Screws.
(STEP 4.) Now take Off one wire at a time from your old Contactor and Install each wire one at a time to the proper location on the new Contactor.
Jun 24, 2008 | Carrier 38CKC042 Air Conditioner
Fahrenheat LFP6152 Halogen
Hi8 , contactor in electrical is the one who connect electrical to a certain equipment , magnetic contactor is operated with electromagnetic contact supplied low dc voltage.
Jun 06, 2008 | Fahrenheat LFP6152 Halogen Baseboard...
Hot electrical smell
Before you open the the unit check first the warranty period /if open the unit the warranty will be cancelled .
The heat sensor not working in automatic / the heat exceed the limit by the heating machine the insulation keep smelling .
The small contactor might stuck due to spark and then stick together , /need to replace contactor .
Jan 09, 2008 | Fahrenheat LFP6152 Halogen Baseboard...
Fahrenheat Ceiling-Mount Industrial Heater - 7500 Watt Logo
602 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
