Question about Astar Televison & Video
Astar LTV32PRM The parental lock sign is on, I did not know who set it but I do not have the code. Tried reset to factory default of 0000 but no change. Can you advise how to reset parental lock code on this unit?
    Problem Solver:
  • 28 Answers
Please call 323-7667-6030 I will try to go through with you how to clear the code.
Posted on Dec 09, 2008
How do you reset the parental code for the coby 19" TFT LED 1926 tv??
If you don't know the current password you can't. If you do then find the LOCK menu under TV function.
Tochangethepassword,inputtheoldpassword-->inputthe Password
newpassword-->verifyagain.
Pleaserememberthepasswordsincethe player'sreset
functionwouldnotrevertthepassword.
The default password is "0000"
If you want to set it back to the factory default you can email Coby support at techsupport@cobyusa.com.
the phone number is listed as: 800 727-3592
Jul 26, 2014 | Coby TF-TV1901 19 in. LCD Television
Parental lock code
Most tv's can be reset when you unplug them. Unplug the tv and let it set for about 30 min and plug it back in. This should reset the code to factory default of 0000.
Mar 03, 2014 | JVC TV 50in ELED 1080P 120Hz
Factory reset press
Channel guard and V-Chip settings are protected by a four-digit lock code. Your TV comes preset
with a lock code of 0000 You may change the code to any four-digit number you wish. To
change the lock code, follow the steps below.
Press the MENU button
To "Initial Setup"
To enter
To "Set Lock Code"
To operate (Password input screen will appear)
Enter the password by using the 10 button
keypad
The Set Lock Code screen will appear
To set the password, use the 10 button keypad
Press the OK button to finish your lock code is now set
Oct 15, 2013 | JVC LT-32E488 32 in. LCD Television
Cant remember parental code to unlock channel for AOV FL4L42W98H_V2_O1 ,TV
There should be an option in the main menu to return all settings to factory default. That may or may not reset the parental lock to either 0000 or 1234. Hope it helps.
Apr 02, 2012 | Televison & Video
My son blocked everyone out of the tv with parental control. He can't remember the password he used and I can't get the reset to do anything. How can I fix this?
If you have reset the TV back to factory settings, you can use the factory unlock code, which is 0000.
To Reset the TV:
  1. Press the MENU button on the remote control to display the Main menu, and select SETUP.
  2. Highlight Reset Default, and press the OK button.
To Remove the Parental Control Block:
  2. Highlight Parental, and press the OK button.
  3. To use the Parental function, must enter a four-digit password. The factory password is 0000.
  4. Select Program Block, and press OK to display the Program Block menu.
  5. You can remove the parental control in this section.
May 25, 2011 | Polaroid TLA-01911C TV
I have a receiver and accidentally locked one channel. Problem is i do not know how to unlock the parental lock. what is the usual default lock code for parental lock?
If you have not set a code for it, most parental lock default codes are simply 0000. If more than a 4 digit code, just put all zeros.
Aug 24, 2010 | Televison & Video
Someone changed the parental code how do i reset it the channels are locked out and i don't have the code
The factory code is 0000 Try using that first if not try doing a factory default reset through your TV setup options . I believe your T.V. input cannot be setup to HDMI to access the parental control submenu. If you can't reset it give Vizio a call and they will help you figure it out. That's what they get paid for.
Oct 25, 2009 | Vizio L32 32 in. LCD HDTV
Kids playing with system put lock code on it and now we cant get off dont know what it is..parental control
Try 0000 and then 9999. These are the default passwords. If those don't work:
Turn on the PSP.
In the main menu, under "Settings" (Toolbox Icon), go to System Settings. Press X.
Go to "Restore Default Settings". Press X
The password should reset to 0000 or 9999.
Aug 09, 2009 | Sony PlayStation Portable (PSP) Slim...
How do you reset forgotten parental control password?
Disconnect power to the TV. The power interruption will allow you to reset the parental control password to the default password of 0000.
To change the password after disconnecting the power, do the following:
1. Press the Menu button on the remote.
2. Arrow up / down to SET LOCK CODE
The lock icom will appear
3. Arrow left / right to operate
4. Press 0 to access the lock code
5. The first digit will be highlighted.
Arrow left / right to select the number
Arrow up / down to move to the next digit
4. Continue to follow these directions for all 4 code numbers.
5. Arrow up / down to FINISH
6. Arrow left / right to save settings and exit.
The password has now been reset.
Nov 29, 2007 | JVC AV-36260 TV
Forgotten pass code for parental lock
Try 3308. That is what is shown in the oweners manual I received with my Qwestar 360MVP. If that doesn't work, go to DEFAULTS and select RESET. This should give you the factory initial settings then try 3308 again. Good luck!!
Sep 14, 2006 | Qwestar MVP360 Car DVD Player
Televison & Video Logo
511 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
