My printers smoking
All of a sudden my printer has started smoking. it was fine before.
I have read on the internet that i could possibly be steam, but it never did it before and i got it about a year ago... im not sure what the model is though, i just need to know its not dangeroius...
    Master:
  • 461 Answers
What is the brand and mode, I would like to see the information you found on steam. If it is a laser printer and it is cold in the room and the paper has humidity, I could see were steam would form. Smoke would have a burning smell and is always a bad thing.
Posted on Dec 07, 2008
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
Aug 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Printer smokes!
This could be steam created when the paper goes through the fuser. Heat dries the moisture out of the paper so causing a slight amount of steam
Oct 12, 2009 | HP LaserJet 1018 Printer
UNIT VERY HOT WHEN PRINTING, EVEN SINGLE PAGES, AND SMOKE OR STEAM COMING OUT WHERE PRINTED COPIES COME OUT. NO WATER RESIDUE OR SPILLAGE NEAR UNIT AND PAPER NOT DAMP.
Look into changing out the drum that may be defective.
If this unit is that hot that it smokes but it still prints see if there is a cooling fan.
This unit running under the condition you mentioned might start a fire.
Jul 29, 2009 | Xerox Phaser 6110/B Printer
Printer does not print. It has worked fine for about 15 months. I can send a document to be printed, the printer goes through the motions, makes all the "correct" sounds, but ejects a totally blank page....
it seems that the cartridge is empty but if ot check as below
u need to turn off ur printer & pull out the cartridge and clean the pinout of the printer cartridge mount then also clean the pinout of the cartridge with acitone then try it if it's not work u need to pull again the cartridge and apply the output ink place to a hot steam then install it back again.
hope it works
Jun 29, 2009 | HP Officejet J5780 All-In-One InkJet...
Rough idle, no power, steamy exhaust
when your getting clouds of steam from your exhaust that is a good tell tell sign that you blew a head gasket
Nov 17, 2008 | 2000 Jaguar S-Type
Help!
It might not be smoke but rather steam. I found a help page at HP.com:
Moisture on Trailing Edge of Paper
Read that document and see if it fits the bill. If you suspect this is really smoke, it means your printer is having a serious issue and you should stop using it immediately. I hope it's just the "steaming" problem. If it's smoke, it's too dangerous to continue using.
Post back and good luck.
Oct 02, 2008 | HP LaserJet 1020 Printer
My 03 wrx suddenly started blowing smoke
most likely the turbo, if its a darker or bluish smoke.
Jun 14, 2008 | 2003 Subaru Impreza
Printer prints backwards/upsidedown
This sounds like an advanced setting on your printer setup. When you get to the print dialog, hit Properties for your printer, then look around there for a "mirror" or "reverse" setting. Different printers use different drivers, so your configuration options are difficult to predict.
Apr 18, 2007 | Brother MFC-5840CN All-In-One InkJet...
272 people viewed this question
jasbo
jasbo
