Question about Sony MegaStorage CDP-CX355 300-Disc CD Changer
Sound is distorted and volume is low
Sony CDP-CX355 is playing at low volume and the sound quality is distorted
  • peter355 Dec 14, 2008
    My CDP-CX355 cd player is producing low volume and the sound quality is extremely distorted.
    I do not understand what is meant by a hard reset as suggested ?
    Does anyone else have any ideas ?
    Genius:
  • 2,920 Answers
You could have cracked speakers or they could be bad from the factory.
Posted on Dec 14, 2008
    Genius:
  • 1,061 Answers
Volume switch may have gone bad.contact sony.com tech support at once.RICHARDM69
    Master:
  • 479 Answers
Check out connecting headphones to the unit and then check out the sound.if in the head phone the sound comes proper then it could be the settings or wiring problem.but in head phones also if u get the same problem.its the internal board problem for sure.and each component on the board has to be checked to locate the exact fault.and asfter that the faulty component should be replaced to make it proper.
  • 505 Answers
This model is equipped with a variable analog output for fading. Make sure fading is turned off. Also check the digital output and headphone output to diagnose the problem. If the analog is always bad, but others ok you probably have a hardware failure.
Posted on Dec 07, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, low volume level and distorted audio indicates probable fault at the amplifier stage and/or the power supply of a unit.
This of course would require opening the unit, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 10,594 Answers
It seems problem in output amplifier area in CDP-CX355 player.
If you have basic electronics knowledge, repair experience and god solder skills, then get service manual of same model from any on-line manual store and check output stage.
need further info, let me know please.
    Genius:
  • 1,142 Answers
Try to hard reset the unit that will take care of the issue
A sony cd player belts for a cdp cx355.Do you carry these belts,and how much?
http://www.ebay.com/itm/SONY-CDP-CX300-CDP-CX335-CDP-CX350-CDP-CX355-CDP-CX400-Drive-Belt-Kit-3-belts-/152184107208?_trksid=p2141725.m3641.l6368
Nov 10, 2016 | Sony Audio Players & Recorders
I need the 3 belts for sony cdp cx355 cd player. Do you carry these belts
here are the belts. http://www.ebay.com/itm/SONY-CDP-CX300-CDP-CX335-CDP-CX350-CDP-CX355-CDP-CX400-Drive-Belt-Kit-3-belts-/152184107208?_trksid=p2141725.m3641.l6368
I have two multiple CD players. One is a 200 CD player (CDP CX205) and the other a 300 CD player (CDP CX355)I do not have the manuals for either. Where can I get them?
Hello Albert,
I went to google and typed in a search for both of your players and came up with the following:
CDP-CX205 got to www.dvdplayer-manual.com and you'get a PDF to download;
CDP-CX355 go to www.usermanualguide.com and type in your model number in the search, then, on the next screen scroll down and select your model number.
Peace Out
Gerry
Oct 18, 2016 | Sony Audio Players & Recorders
I have a Sony CDP-CX355 300 CD Player and old Technics SA-5060 receiver and two new Insignia NS-B2111 bookshelf speakers, with old but solid speaker wires. When playing the CD player, loaded with symphonic...
Don't run anything but a TURNTABLE through Phono. That's the only labeled input that's literal. Use any other Line Level input for the CD.
If you don't have anything connected to the Tape loop, use the Tape In connectors.
Feb 18, 2011 | Sony MegaStorage CDP-CX355 300-Disc CD...
CDP CX355 Seems to Skip- sound similar to what happens with LP record when dirty.
If the player "skips" after 15+ seconds the likely problem is the split rack&pinion used to position the laser. The split rack is sprung to remove play or backlash when meshing with the driver cog. This split rack can jump cogs over time, eventually becoming ineffective. The solution is to remove the laser assembly and gently disengage the driver cog, compress the split rack and re-engage the driver cog. This should solve the skipping problem.
Nov 28, 2009 | Sony MegaStorage CDP-CX355 300-Disc CD...
I need the user manaual for a Sony Mega Storage 300CD
Click Sony Support to download user manual copy for CDP-CX355
If model number is different, let me know to provide you that manual copy.
Thanks.
Nov 04, 2009 | Sony MegaStorage CDP-CX355 300-Disc CD...
I need an instruction manual on how to use
You can download user manual of CDP-CX355 by clicking Sony Support.
Thanks.
Jan 24, 2009 | Sony MegaStorage CDP-CX355 300-Disc CD...
CDP-CX355 cd player
You can have service manual of CDP-CX355 from Manual Zone and Service Manual net
Regarding test and checking of audio out circuit, service manual will help you a lot and let me know do you get distorted sound in digital out or analog out.
If its analog audio out, then IC401, 402 and IC302 on main board are suspected. (see below picture, part of main board)
Need further info / help, let me know to guide you further.
Thank you.
Dec 14, 2008 | Sony MegaStorage CDP-CX355 300-Disc CD...
Sony MegaStorage CDP-CX355 300-Disc CD Changer Logo
62 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
