Question about Kenmore 63942 Dryer
Putting a kenmore electric dryer back together
Im trying to make sure that i put everything back together the way that it was suppose to be because i took the dryer apart about a month because the motor belt broke. now i need help with little odd and ends. like how to put the door ignition button back on and for it to stay because its not matching up to screw it, and how to make sure that i put the electrical outlet back on right. Serial Number- MD0445196 and the Manufacturing Number is 101-96310100
  • 979 Answers
Your best bet since this will be hard to do without looking at it is to call a local repairman. There are too many things left to chance.
Posted on Jan 20, 2009
Kenmore 80's series electric dryer no heat...drum
Check your breaker by turning it off and back on. Then check wiring at plug and back of dryer. You could have a bad relay switch. You can find it under the top and put the 2wires together and try it then . If it works, you know that it is the relay switch. Last but not least, it may be your element. Check it visually to see if there is a break in it or a weak spot.
Feb 27, 2013 | Dryers
Can you put a cycling thermostat for a drier on backwards. I took one out and not sure which way it went back on.
As long as the wires are connected to the correct terminals, it should work as it is supposed to.
May 11, 2012 | Kenmore 63012 Electric Dryer
Kenmore Elite HE4 gas dryer won't start
I had the same symptoms and it was a bad motor relay. This happened twice within 5 years.
Apr 19, 2010 | Kenmore Elite HE4 Electric Dryer
Timer ticks, but dryer does not run
Sounds like door switch. Open door and push on door switch. you should here a clicking noise. If you can open the top of the dryer. put the 2 wires together of the door switch. Make sure it is unplugged when doing this. Make sure you use electrical tape when you put it together. Temp fix. Get a new switch
Oct 23, 2009 | Kenmore 62602 Electric Dryer
I need help putting my dryer back together
Here is a couple of websites that shows the breakdown and parts of dryers, maybe they will have your model to help show where the two springs go.
http://www.appliancepartspros.com/index.aspx
You could also try this website.
http://www.partselect.com/
Good luck,
I hope this helps
Oct 06, 2009 | Kenmore 67082 Electric Dryer
Dryer runs but there is not heat on any cycle.
HI,
try looking at your door switch and also your thermal fuse on blower. it is white in color and has 2 wires going to it. black center stripe you can put those 2 wires together and wrap with electrical tape. make sure dryer is unplugged before attempting/then plug back in and see if it works.
any further question let me know.
thanks,
Mar 21, 2009 | Kenmore Dryers
Kenmore dryer
If this worked before that part was taken off, then take it off agin and make sure that the gear is engaged with the other gear in side the timer unit re adjust and before putting screws back in try turnning dial if it engages the put screws back in and if this fails you may need new unit (timer unit) That small gear may be pushing on the one it's suppose to engage.
Mar 03, 2009 | Kenmore 64902 Electric Dryer
KENMORE 80 SERIES NOT HEATING
you need to check the heating element and the thermal fuse in the back of the dryer, they should be their. do you have an ohme meter, if not barrow one or you can pick one up cheep and lowes or homedepo .
Dec 13, 2008 | Kenmore 659 Electric Dryer
Putting dryer back together
if whirlpool are kenmore the pulley slides in tobottom of the dryer in front motor there a slot it goes in
Dec 24, 2007 | Kenmore 64952 Electric Dryer
Kenmore 63942 Dryer Logo
220 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
