Question about Jack Lalanne Power Juicer 250 Watts
Jack LaLanne Juicer
I cant get my Jack LaLanne Juicer to clean since the blade and basket part wont remove remove for cleaning. I lifted then turned it counterclockwise but that's it? IT IS STUCK! (Motor works) Mine is Plastic Model:CL-003 AP.....Should I unscrew the metal basket and see what happens or if something might be stuck? Luvinia
  • 3 Answers
Try this site for a manual
http://www.powerjuicer.com/pdf/classic.pdf
Posted on Dec 12, 2008
I cant remove the blade or mesh basket to clean it.
you need the orange crescent shaped tool to loosen the filter
Jun 28, 2010 | Jack Lalanne Power Juicer 250 Watts
HOW DO YOU take apart the jack Lalanne juicer blade and top unit to clean
LIFT UP AND SLIDE COVER RETAINING BRACKET OFF COVER, REMOVE COVER AND
PLASTIC NUT THAT HOLDS DOWN BLADE. ALL PIECES JUST LIFT OUT, BUT KEEP TRACK
OF THE ORDER THEY ARE REMOVED IN TO REINSTALL CORRECTLY.
Jun 28, 2009 | Jack Lalanne Power Juicer 250 Watts
I bought the juicer at a second-hand store in brand new condition however the crescent tool was missing. To remove the flat blade for cleaning, I use a pair of scissors spread far enough to fit the ends in both holes. Hold the basket still while turning the scissors counter-clockwise untill the flat blade detaches. Easy as that! I ordered the tool, but it hasn't arrived yet. Hope this helps!
Oct 11, 2008 | Jack Lalanne Power Juicer 250 Watts
Jack lalanne juicer, 8 yrs.old model?
I have a Jack LaLanne power juicer model number JLS-8 and lost instruction manual and don't remember how to remove filter basket to clean machine.
rhanson616@cox.net
Sep 08, 2008 | Juicers
Cant grt it apart to clean
Take off the top part of the juicer that has the chute. You will see the blade and basket. The blade appears to be attached to the basket with three small screws but is actually screwed onto the basket by a large screw that protrudes out of the basket underneath the blade. So the trick is to unscrew the blade, turning it to the left by using maybe a small screwdriver that you will have to put into one of the two small holes that are on the blade surface and pushing the blade to the left. This should loosen the blade and then you can just unscrew the blade off the basket. Once you get that blade off, the rest of the juicer comes apart. The newer models come with a little tool with a couple of arms that go down into those holes and loosen the top. Good luck.
Jul 22, 2008 | Jack Lalanne Power Juicer (Stainless...
Jack lalanne power juicer
I seem to be able to put the crescent too in but the blade just spins and doesn't seem to be connecting to anything to pull it out. Talk about frustration!!!!!!!!!!!!!!!!!!!!!!!
Jul 21, 2008 | Jack Lalanne Power Juicer 250 Watts
Taking apart Jack Lalne power juicer to clean.
There are two holes on the surface of the blade. When the juicer was bought, it came with a half moon shaped orange tool that has two posts that fit into these two holes.
By inserting the tool into these holes you can unscrew the blade from the machine as long as you hold the outer screen while doing so.
Once this is done, you simply lift the other pieces off.
If you can't find your orange two prong tool, i would suggest using a screw driver or two that fit into the hole(or two)..... hold the orange screen and turn the blade counter-clockwise..
Hope this helps
Smitty
Jun 06, 2008 | Jack Lalanne Power Juicer (Stainless...
How to dissassemble Jack Lalanne Power Juicer?
After about a half hour I finally figured it out. I'll go through all the steps.
1. Remove pusher from chute.
2. Pull the locking bar down over the spout.
3. Remove lid.
4. This part is tricky. Stick the orange crescent tool into the blade holes and while holding the filter basket steady with one hand, turn the blade couterclockwise while pulling up.You do have put a little muscle into it. And remember, if you don't hold the filter steady, the whole damn thing just spins.
5. Remove the receptacle.
Good juicer, but it seems unnecessarily complicated.
Jan 01, 2008 | Jack Lalanne Power Juicer 250 Watts
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Power Juicer 250 Watts Logo
1,272 people viewed this question
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
Starnley Johnwells
Starnley Johnwells
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
