Question about GE WBXR2090B Top Load Washer
The timer on my GE washer WPXQ3090T2WW is broken. How do I fix it
I have the washer almost 11 years. It's the second time it has broke.
How would I fix it? If it's too hard, does it pay to fix or should I just buy a new one? How much should it cost to fix? The big companies around sub-contract the work out. If it pays to fix it, who should I get to do the repair?
Bob Gemmell
  • 209 Answers
SOURCE: Need to remove top cover of GE WPXQ3090T2WW top load washer
There should be 2 screws holding it on at the rear. Looking from the rear these will be at each top corner. Once these are removed push the lid from the front of the machine towards the rear and it will pop off.
Posted on Sep 13, 2007
  • 178 Answers
SOURCE: ge timer on washer is broken
If it no longer clicks, the timer assembly will need to be replaced. If just the knob broke off, the timer should be good.
Posted on Mar 16, 2008
  • 1214 Answers
SOURCE: kenmore washer 110.92292100..Washer Timer Control Knob is broken,
If the knob is tight on the timer stem, then the timer has failed.
If the knob is loose, then maybe just the knob has failed.
You can order either of these from a number of places. One I recommend is searspartsdirect.com. YOu just enter your model number and find the exploded view for the controls. If it does not find it, drop a number off the end of the model number that you've given and try again.
They are easy to replace.
Reply back and I can give you more advice or instruction.
Posted on Feb 03, 2009
landsend
  • 1066 Answers
SOURCE: Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Posted on Apr 01, 2009
  • 130 Answers
SOURCE: Broken knob on GE washer
There are four separate parts that make up the knob dial. You can pull off the knob if you use a screwdriver/pliers to remove the clip holding it on. Check if the mounting areas appear stripped or broken. There should also be a compression ring in the mounting hole on the back of the knob. That's what may be broken or stripped. These are all parts that you can get from a local parts store (check the phone book) and you can do it yourself. Any of those parts should cost less than $10. The bad news is if you stripped the pole coming out of the timer assembly. You would need to replace the entire assembly which costs about $130. If you call a GE repairman, you are looking at $89.95 or more just to have them show up. If it is still under warranty, there is no charge. You can call them to verify this:
1-866-383-3933
Posted on May 03, 2009
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Why does my GE washer get stuck in Drain cycle??
for one G.E not a good choice mostly junk. the timer may indeed be bad if its sticking at 1 point and u can move it manually?
Feb 27, 2015 | GE GTWN2800DWW 3.9 cu. ft. capacity top...
Dx4500 ge dryer
Maybe the knob is broken and slipping on timer shaft. If not, replace timer.
Sep 10, 2017 | Dryers
Clothes washer- Broken timer
if your timer is not going round it could be the timer motor faulty can you turn the knob and empty it ?
May 28, 2012 | GE Washing Machines
I need to replace the timer on my GE Washer Model WPXQ3090T2WW. I understand that the knob is held on by a clip. How do I get that off?
Pull the knob out and use a very small screwdriver to push the clip off or a long thin pair of needle nose pliers to pull the clip off.
Eric
Jun 20, 2009 | GE Washing Machines
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
Mar 27, 2009 | GE WBSR3140DW Top Load Washer
Ge timer on washer is broken
Mar 16, 2008 | GE WDSR2080D Top Load Washer
Sep 13, 2007 | GE WBXR2090B Top Load Washer
GE WBXR2090B Top Load Washer Logo
61 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
