Question about Symphonic WF803 DVD Player/VCR
Eats tapes The VCR/DVD eats the tape after rewinding then hitting eject. The tape will pop out but part of the tape is still ont in the mechinism Which part is causing this?
  • Anonymous Mar 27, 2014
    VCR EATS TAPES
    EATS TAPES
  • 2,130 Answers
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Posted on Feb 07, 2008
My vcr/dvd recorder eats the tapes.
clean pinch rollers and head. check if there is any dirt on capstan post
Apr 30, 2009 | Philips Magnavox DVD/VCR Dual Player
Vcr eats tape old samsung blak box
Check all belts. clean the all moving parts
Oct 16, 2008 | Sansui VRDVD4000 DVD Player/VCR
Eats Tapes
clean all moving parts.
May 02, 2008 | Broksonic DRVCR900 DVD Recorder/VCR
VCR problem in EWR2OV4
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle. The pincher wheel can become worn and/or dirty from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out than can be wound up. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
- Jim
Jan 29, 2008 | Emerson EWR20V4 DVD Recorder/VCR
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
Eating Tape when rewinding in vcr mode
look for a tiny pinhole and insert a pin while powered up to reset the device. if no-go, then the take-up reel needs attention...needs possibly a new or well-cleaned-with-alcohol-swab rubber belt
May 27, 2007 | Canon XL1S Mini DV Digital Camcorder
VCR eating tapes when attempting to rewind
VCRs are so cheaply priced these days that it's not worth the time and trouble to fix them or have them repaired. If you fix one worn or slipping belt, another problem isn't far behind.
Feb 26, 2007 | Symphonic WF802
Open Questions:
Symphonic WF803 DVD Player/VCR Logo
352 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
