Question about Canon PowerShot S2 IS Digital Camera
Goto take a pic, no flash wanted. Touch the button and the lense retracts and the camera powers off. Using tripod for low light shots.
    Problem Solver:
  • 14 Answers
Be sure you have new, fully powered batteries and see if this happens. Some "new" batteries still do not have enough power to do the job. Even one bad battery out of 4 can derail your efforts.
Posted on Dec 13, 2008
How to take a good picture in bad lightning
You can find the manual here. They have some suggestions for shooting in low light:
  • Set scene to "NATURAL LIGHT" Capture natural light indoors, under low light, or where the fl ash can not be used.
  • or set Scene t "PARTY" Capture indoor background lighting under low-light conditions.
Use a tripod if available, or brace the camera against a wall, table, or other fixed object when taking pictures to reduce blurriness.
If you don't have an object to brace the camera against, use these techniques to reduce camera shake. Press the camera button instead of jabbing at it.
Search the internet for "low light photography" for more tips. The PARTY and NATURAL LIGHT settings on your camera should boost the ISO on your camera.
Do some test shots before hand in low light situations to see what works best.
Feb 11, 2012 | FUJIFILM FinePix S2950 / S2990 Digital...
Jewelery pics
Yes and no. It depends on how small the piece is.
Aug 13, 2009 | Nikon N55 35mm SLR Camera
Low light lense?
You can use ANY lens t take low light photographs, however if you are hand holding camera you should use as fast a lens as you have at your disposal ie F1.8 (faster if you have it!)
If you are using flash it will not matter but are limited by range of flash gun!
I my opinion the best way is to use a tripod, no flash and fast lens.
Bj
Jan 25, 2009 | Nikon Cameras
Beeps repeatedly, lense won't retract...won't take pictures?
Hi Jeanice21, I just posted the same problem a few minutes ago with my SD400. I followed a few steps of the suggested solutions and here's what worked for me.
1) take apart the front and back by unscrewing the six screws holding the camera together
2) on the left of the flash, there are two little retangular holes with grooved dials in them
3) using a little flat head screwdriver, push up or down to turn the grooves while power up in the movie or capture mode
4) the lens retracted at this point and my camera started working again. Good luck!
Dec 28, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
My sony cybershot digicam is capturing blurred pics and just before clickin the pics a "hand mark along with an exclamation" sign appears which i found to be vibration error. how do i deal with it
The hand icon means you don't have enough light to hand-hold a shot with the settings you are using. You need to either:
1) Use the flash
2) Use a tripod
Dec 23, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Indoor shots such as a wedding
Have you thought about using the flash??? In low light you may not be able to hold the camera steady enough to take pictures without using a tripod.
If you want to change the colour ballance of the camera, look in the user manual. It is a little bit involved. I would recomend using the flash instead.
Jerry G.
Jun 30, 2008 | Sony Alpha DSLR-A100 Digital Camera
Flashless photograghy
If you set the camera to P (program) the flash will not pop up automatically but the camera will still control the shutter speed and aperature settings automatically. Also with the lens you are using you should probably have a tripod which will help you hold the camera more steady.
Jun 10, 2008 | Canon EOS 40D Digital Camera
Power issues.
you sdaid power surge on the laptop. Thus suggests that this may have affected the camrera. I would think a 'repair' if such is possible will be near the cost of replacement. Only Olympus can advise
Nov 10, 2006 | Olympus FE-115 Digital Camera
Night shots
Hi: Well, I think you have a problem because you cannot take still shots at night :) Not even with the best SLR. The camera as to get light to make the picture. My advices are, not only use the tripod but when you shoot, but set the timer function so you don't touch the camera when it shoot's and use a high time of exposure like 2 or 5 seconds depending on the subject... Make several experiences with low resolution and when you suceed, make it with a higher resolution ;) Regards
Sep 04, 2005 | Fuji FinePix S5500 Digital Camera
Need help with Kodak CX7530
The first thing you need to determine.... Is it your or the camera? You need to take a series of shots with your camera sitting on a tripod. If you do not have a tripod, sit the camera on a solid surface. ................... Camera movement is the number one cause of blurred photos. A few tips: 1. When you punch down the shutter button ... that can move the camera just as the picture is taken. Dont ''punch'' down the shutter button. Hold the camera in such a manner that you are squeezing the shutter button between your forefinger and thumb. 2. When you are using the LCD to frame the shot, you have your arms extended in front of you. This invites camera movement. Instead, use the viewfinder and make sure that the camera is pressed against your face. Your head is steadier that two outstreatched arms. For added stability, lean your shoulder against a pole, tree, building, or other solid object. 3. When taking flash pictures remember, that flash only covers so much area. The CX7530 is rated for 11.8 feet if you are not using optical zoom. It is rated for only 6.9 feet if you are using optical zoom. If your subject(s) are beyond those distances, you will get a dark photo. 4. When shooting in dim light and not using flash, the camera will select a slow shutter speed. You must use a tripod or sit the camera on a solid surface.
Aug 30, 2005 | Kodak EasyShare CX7530 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
