Question about Dell Dimension 2400 PC Desktop
Dell model DHM DESKTOP which is stuck while plug in .
Cant shut down and as well cant work by clicking any program.
  • tpgopi85 Feb 15, 2009
    this ids gopi i m useing dell Model no DHM
    i have problem with win23/worm antivires problem then i formet my system then internet not working
    i m useing cable net with modem
    and again i have a problem with same vires
    now net not working and vires
    but i dont have net in my room
    when i conneted to net its not working
  • 19 Answers
Try this out:
1. Hold down the Start (Windows Flag Key) button on your keyboard and press R
2. Type this Command : shutdown.exe -s -f -t 00
This will shutdown all running programs and shutdown windows Instantly.
Optionally you can create a desktop shortcut to do this automatically. Here is how:
1. Right click on any blank space of windows desktop -> New -> Shortcut. A “Create Shortcut” window will open.
2. In the blank, type in:
It means, shutdown and wait for Zero second. Click “Next” button for next step.
3. Type in whatever name you like in the blank. I use “Turn Off PC”. Then, click “Finish” button.
4. You are finished . A new shutdown shortcut has been created on your windows desktop!
Just click on it to shutdown.
Posted on Dec 07, 2008
Power buten not working on dell dhm
Hello this should be the homepage:
http://www.dell.com/support/drivers/us/en/04/Product/dimension-4700
Here is how to disasemble the pc:
http://support.dell.com/support/edocs/systems/dim4700/sm/parts.htm
If i am wrong, search for the model here:
http://www.dell.com/support/drivers/us/en/04/ProductSelector/Select?rquery=fkey-e-Drivers_PS
By selecting desktop, and model number.
A solid amber light is usually a indication of a failed power supply. The fact that you maybe get the light means the button is working and the problem is else where.
Start by removing all the ram and all plug in cards. Then disconnect all the power inputs to all the drives.
If you still get the solid light then its either the mother board or the supply.
But you can order a new power switch, from a dell dealer.
This is rarely happening, so i suspect the power supply, is malfunctioning.
All ATX power supplys fit`s in the case, so it does not have to be a dell.
Best of luck
Feb 03, 2013 | Dell (E210882) Motherboard
To joecoolvette reguarding 2005 compaq presario SR1000 and Dell LCD TFT monitor. The dell monitor was part of my mothers comp and I wasnt given a CD with it. Im sure she dont have it now. As far as the...
jason,
When a device is installed, Windows 'Breaks it's neck', to find a compatible driver, (Or drivers)
If THE driver is not present, then Windows will match up one of it's thousands, of generic drivers it has on hand.
Then if THE driver is installed, there is a driver conflict.
{Crude illustration}
Windows: 'Which drivers do I use? These or THESE?'
Let's try this;
{Based on Windows XP operating system}
1) Left-click on,
Start>
Control Panel>
Add/Remove Programs
When Add/Programs populates REMOVE the graphics cards software.
ALL of it. Anything you see associated with that graphics card.
Close all windows, go back to your desktop screen.
(If you are asked in Add/Remove Programs, if you wish to restart your computer - NO)
Shut your computer down normally.
(Start>Turn Off Computer>Shut Down)
Unplug your computer from power. Open the computer case, TOUCH the metal frame to relieve your body of Static electricity.
(Static will fry out your computer hardware components)
Remove the graphics card.
Press the Power On button in, and hold it in for a count of Five seconds. (And I mean Five. Count - 1001..1002..1003..1004..1005)
Let go of the Power On button.
Do this same procedure Two more times. (Imperative!)
What you are doing is clearing CMOS Error Codes, and resetting your BIOS Setup back to the factory default settings.
Now plug your monitor into the VGA port on the motherboard.
Plug your computer back into power.
WAIT 1 minute.
Turn your computer on.
When Windows has loaded all the way, put the CD disk for your graphics card in your optical drive tray. Load the software.
When you are finished, close all windows, go back to your desktop screen.
Unplug your computer from power. TOUCH the metal frame. Install your graphics card.
Plug your monitor into the graphics card.
Close your computer case.
Plug your computer into power. WAIT 1 minute.
If the resolution isn't correct:
Right-click anywhere on an empty spot of your desktop screen.
In the drop down menu, Left-click on Properties.
Now left-click on the Settings tab, all the way to the right.
Look down at where it states - Screen resolution, in blue.
(Halfway down the Display Properties window)
Is the pixel resolution what it should be?
If not, Left-click on the slider.
Hold your left mouse button down, and slide the slider, to where the resolution settings are correct for your Dell LCD monitor.
(To the left is Less. To the right is More)
Now go down to the right, and click on Apply.
Then go over to the left, and click on OK.
Don't know what the native resolution, for that Dell LCD Thin Film Transistor monitor should be?
Look it up on the internet using the Model Number, or give me the Model Number, and I'll look it up for you.
Jan 29, 2010 | Compaq Presario SR1000T (568657) PC...
Getting my dell motherboards to start up.......
you might have fried the mobo when transferring it, and try it with a monitor see if anything comes up on the screen at startup
Oct 08, 2009 | Dell Dimension 2400 PC Desktop
Unable to connect to internet or any program whatsoever
Some viruses do lock themselves to legitimate Windows programs. If they get delete, so do the Windows programs.
Re-installation is your next logical step.
May 12, 2009 | Dell Dimension 2400 PC Desktop
Dell Optiplex GX260 will not shut down.
Could possibly be virus/malware issue. Try running a full scan to see if anything is found.
Mar 30, 2009 | Dell OptiPlex GX260 PC Desktop
Audio driver for Dell PC Model- DHM Os- Win XP professional please help find were to download from
just go to google and search with below text
"free sound driver forDell PC Model- DHM Os- Win XP professional "
or from www.freedriver.com
Feb 21, 2009 | Computers & Internet
Dell Desktop
Have you tired holding down the power button. Other wise what model is this computer? And how far into the boot cycle does it get?
Jun 16, 2008 | Dell Computers & Internet
Dell Dimension 2400 PC Desktop Logo
613 people viewed this question
Alun Cox
