Question about Cameras
I have a fuji a340 .....It will not record when picture is exposed to the memory card.....you can see print in view window but has not recordon memory card....can you help?
    Genius:
  • 1,142 Answers
The port needs a good cleaning as the contact is not being established correctly.
Posted on Dec 07, 2008
  • Cameras Master
  • 6,487 Answers
This can be a problem with the memory card , first thing that you can do here is to format the memroy card using the Fprmat option on your camera's menu and if its still didn't work better try a different memory card so we can check if that is the problem...
    Genius:
  • 1,142 Answers
Is the camera not recognizing the card or you computer ?
FINEPIX a340 to windows 7
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Jan 27, 2013 | Fuji FinePix A340 Digital Camera
I want to view the pictures on the internal memory
Hi vicki. The camera probably only displays the pictures in internal memory when there is no extra memory card in place, so you will be able to see them if you take it out and then switch the camera into its review mode. Hope this helps
Dec 28, 2010 | Fuji FinePix A340 Digital Camera
My computer has Windows Vista. When I run the CD
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Apr 05, 2010 | Fuji FinePix A340 Digital Camera
Display says card not initialized when a new xd picture card is inserted in the fuji fine pix A340 how do i initialize or format the card
the camera cannot use XD picture card and multimedia card (MMC). SD and SDHC can be used. for compatibility check this http://www.fujifilm.com/products/digital_cameras/accessories/card/a/ you might need to update your product depending on your serial no.
to format the card, press menu to display menu setup, press right to move to setup 2 (3rd tab) you will see Format. click Format to format the memory ("SD" is displayed if memory card is inserted and "IN" (internal memory) if no memory card. hope this helps
Jul 08, 2009 | Fuji FinePix A340 Digital Camera
Memory card
press menu and go left or right to setup. Scroll down to format and follow along to format (initialize) your new card. If that new card has an "H" or "M" before the size printed on it, it may not be compatable with the A340 unless an upgrade is performed (firmware upgrade). This can be done by Fuji, or you can do it with help from their website, under the support section.
Jul 27, 2008 | Fuji FinePix A340 Digital Camera
Fuji finepix A340
a340 needs a firmware update from fuji to work w/xd cards that have a h or m on card-should work ok w/older cards-check mem card and update camera from website to make compatible w/new type card
May 21, 2008 | Fuji FinePix S5000 Digital Camera
Fuli A340 memory card problem
Try opening your My Computer screen, connect the camera to the computer and watch for the new removable disk to show up. Depending on the camera there may be two that show up. Right click on the removable disk/disks and choose format, click start and click okay. This should fully reformat the memory and you'll be able to take pictures again.
May 03, 2008 | Fuji FinePix A360 Digital Camera
Digital memory card
Cards can go bad, but usually this happens only after a long period of time (years), or if exposed to a magnetic force of some kind.
You can try a few things to resolve it:
1. Try reformatting the card, if the device can process data on it.
2. Insert the card into a card reader on a PC to see if the drive can be read. If you can read the card, remove all data and empty the trash, then reformat it.
3. If you get an error on that as well, replace it.
It's not worth risking that you might lose your valuable pictures to unstable media.
Nov 07, 2007 | Fuji FinePix A340 Digital Camera
Fuji finepix a340-card error
Storage cards can go bad, but usually this happens only after a long period of time (years), or if exposed to a magnetic force of some kind.
Good luck.
Oct 24, 2007 | Fuji FinePix A340 Digital Camera
Fuji s5000 problem
hello Musicman, I think you can snap but not get view on lcd right ? and there is whole black on display right ? If so i think there is some problem with CCD and if ccd is damaged so no one can help you you have to replace it in fuji shop. good luck....
Aug 02, 2006 | Fuji FinePix A340 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
