Question about Kodak EasyShare V1003 Digital Camera
Pictures won't transfer from the camera to computer using usb
The pictures did transfer with the usb but won't. I don't know if its the camera or thw usb cord. I can still take pictures with the camera and they show up on the camera when I review them.
  • 3 more comments
  • mjm929 Dec 07, 2008
    The suggested solution doesn't seem to be right because there is no tab, to lock or unlock, next to the memory card on this camera Kodak easy share v1003.
    The pictures still won't transfer and I haven't purchased another cord.
  • mjm929 Dec 15, 2008
    We purchased another USB and have tried it on 3 different computers. There is a message that says "USB not recognized". This is different because with the old USB nothing happened but we still can't transfer photos.
    There was no other solution suggested since DEcember 7th.Since then, I did get another USB cord and plugged the camera into 3 different computers. The same message came up on each computer:"USB not recognized".
    I DID purchase a new cord. Please, read my comments!!!!!!!
    Genius:
  • 1,199 Answers
Make sure camera is turned on before you plug in the usb!
Posted on Dec 15, 2008
    Top Expert:
  • Kodak Master
  • 77,499 Answers
There is a setting in the camera that must be set to USB option to download via the USB.
    Master:
  • 479 Answers
Dont replace the USB wire.just interchange the usb port there r mostly two usb sockets in the back of the cpu just try to insert it in another socket and check out it should detect.or otherwise it could be the fault in your camera usb socket that has to be checked to make it proper. thanks.
  • 145 Answers
Try changering the usb cable with a new one
    Sergeant:
    Champion:
  • 347 Answers
What is your exact problem?
Cant you open the window of your camera once connected to the computer?
Can't you dragg them (or copy paste)?
Do you get any specific error message?
Posted on Dec 07, 2008
  • Santiago Vallejo
    Santiago Vallejo Dec 16, 2008
    Before trying anythign else make sure your camara software is instaled properly.
    If your not sure, you can uninstall and reinsatll the software.
    If you dont have the Installation CD; you can download the driver from here:
    http://www.kodak.com/global/mul/service/...
    Good luck
  • 6,487 Answers
This can be a problem woth the USB cable that you're using better if you try a different USB cable, or if you like just use a card reader so you can transfer all the data from the memory card of your camera to yoru computer.....
    Scholar:
  • 111 Answers
Hello, I have a similar problem with my HP camera, it turns out it was a bad USB cable, in most cases the USB cable will go bad before the camera goes, the best thing to do is test it out with another cable it should work.
Hope this helps.
  • 10,594 Answers
It can be usb Cord, usb port of camera or corrupted usb diver in your PC.
Try to connect some thing else like MP3 player with same usb cord and test the cord and usb ports in PC.
test your camera in another PC to make sure that camera usb port is working.
  • Shahid Electronics
    Shahid Electronics Dec 15, 2008
    Camera USB port got bad.
    Its not worth to repair because complete main board will be replaced and cost would around new camera price.
  • 928 Answers
I understand that the camera does not transfer pictures with the USB anylonger. I would suggest you try to plug the camera in the back of the computer if its a desktop. then turn off and on the camera and restart your computer. After doing that and it still does not work please try to plug the camera in another computer and see if it is detected. if that still does not work id suggest you try to use a different cable.
    Genius:
  • 1,142 Answers
Clean the contact port on of the cable and the camera with isoprolyle alcohol then tell me the status
  • Maanita Chadha
    Maanita Chadha Dec 07, 2008
    you might need to replace the cord as it seems to be having the problem,
    Genius:
  • 1,124 Answers
Unplug the usb cord and plug it again. If does't work reboot your computer. If still doesn't work replace the cable
  • Kodak Master
  • 19,396 Answers
CHECK THAT THE SMALL TAB ASIDE THE MEMORY CARD IS NOT ON LOCK STATE, IN THAT CASE MOVE THE MEMORY CARD LOCK SWITCH TO UNLOCKED.
  • Ginko
    Ginko Dec 07, 2008
    Do the following
    1. The memory card has a small tab on a side, that can lock or unlock the memory card, check that teh switch is not on lock position.
    2. Test a different USB cable.
    3. Unplug computer power cable for ten minutes, if this is a laptop, also remove the battery at the same time.
    4. Test camera on a different computer.
    5. Reinstall camera software.
  • Ginko
    Ginko Dec 15, 2008
    Get this USB card reader and use it to transfer the fotos: Kingston FCR-HS219/1 19-in-1 USB Media Reader
Easyshare Z5120 won't transfer pictures to computer
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Mar 10, 2013 | Kodak Cameras
My computer doesn't recognize my fujifilm finepix 98100 anymore.
Try NOT connecting your camera to your computer.
Nov 23, 2012 | Fuji FinePix Cameras
Transferring pictures onto my desktop
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Nov 19, 2012 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Kodak easyshare c743 won't connect to computer to transfer pictures
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 25, 2012 | Kodak EasyShare Cameras
I don't know how to get my pictures from my Nikon COOLPIX S570 onto my computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa or Nikon Transfer.
May 13, 2012 | Nikon COOLPIX S570 Digital Camera
I don't know how to transfer pictures from my camara to my USB and then to computer or how to transfer pictures from my USB to computer (ie. don't know how to transfer to dBay). Thank you!
Sorry, but the answer you seek is much too long for this site. You need to sit down with the instruction book for your camera and then the help section for beginners on the Ebay site.
Sep 19, 2011 | Cameras
Need USB cord to transfere photo to computer
You don't need a USB cable.
Dec 07, 2009 | Kodak EASYSHARE M1063 Digital Camera
I need the new version of the usb driver because my usb cable will not work
You don't need a USB driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Nikon Transfer or Picasa.
Nov 22, 2009 | Nikon COOLPIX L20 Digital Camera
HELP!!!!!!!!!! USB cord needed!!!!
You don't need a USB cord.
May 31, 2009 | Vivitar ViviCam 5299 Digital Camera
Transfer pictures
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Nikon Transfer and Picasa.
Jan 11, 2009 | Nikon COOLPIX L18 Digital Camera
Kodak EasyShare V1003 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
