Question about HP Officejet 5610 All-In-One InkJet Printer
Installing the right filter
I have a 5610 all in one ... that I am trying to hook up . the manual tell's me to install a filter in the phone line . I notice that the filter that i have for my DSL say that it is for a two line phone but I only have one line comming into my house . is this a problem?
  • pf8552 Dec 18, 2008
    Hello.I found out that there are several different types of filters. some have two wires and some have four wires. My fax machine requires a two wire filter for a single phone line once this was installed the fax works fine.thank you.
  • 236 Answers
No it is not a problem.
The DSL filter filters out the DSL "noise" from the phone line.
Connect the filter to the phone jack in the wall then your fax into the filter.
Posted on Dec 08, 2008
Siemens Gigaset 675 I'm just installing it and
check the power cord for faults at the base and the wall socket. make sure everything is tight.
Oct 07, 2011 | Lands Phones
Cannot receive faxes
The storm has likely damaged the phone line, or the ADSL microfilter (if you have one). Which is why it thinks a phone on the fax line is off the hook. Check your line for breaks and your ADSL filters for a blown filter.
Sep 18, 2007 | HP OfficeJet Pro L7580 Color All-in-One...
Hi I have a laptop of Dell & i have a phone of Samsung Mode GT-C3053 Handset GPRS Compatible I want to connect my phone to laptop for using internet Can you have any solution
Are you hooked up to the net through your phone company? If so, all you need to do is plug a phone cord into the right place on the PC, & be sure to hook up a filter they sent you from the company, if there will be phones hooked up to the same line. If you have a line dedicated ONLY for internet use, just plug in the cord, run the disk they sent you, & you're set. Do you have dialup or broadband? That also makes a difference. Dialup you can do the above & add a phone running from PC also, np. BUT if you have broadband & you want to have a phone & PC hooked up to same line, you want the phone to come off a line BEFORE it gets to the PC, as the filter thing is important. Put filter on the phone line. If you have broadband & a phone that runs off line from PC, you will hear horrible sounds louder than voices on the phone. Ask my ears, I tried that. :) If all that doesn't help, ask again & tell us lots more about it, OK? :) More info helps a lot.
Sep 18, 2010 | Samsung Computers & Internet
Uniden wall-mounted cordless phone unusable since DSL installed
This happened because there are too many phones sharing the same line with no power amplifiers.
Your phone line is self powered by a small current generated by the phone company (that's why old, wired phones don't need a separate power connection to ring or make calls, it's enough to just plug them in). Each phone you connect to the same line acts as a resistor and drains some of this current. Eventually not enough power is left to carry the signal.
The phone company technician can fix this by installing power amplifiers.
In any case, I would test this theory by unhooking all other phones and checking the cordless ones on their own.
If they work fine, call back the phone company and ask for a "real" repair person..
Jul 13, 2010 | Uniden Cordless Phone
Hp office jet 5610 all in one printer--- am I able to fax without hooking up to a computer if yes how- thanks
All the HP office all-in-ones fax without computer hookup, simply place the fax on the load tray face up until you see the window state that the original is loaded. Then on the number pad dial the fax number you want to connect to, once that is the black fax button and the machine will dial the number, once a connection is made the fax will feed itself through and complete. The only connection needed is an outgoing phone line. Just make sure that the phone line is in the right socket on the back. You will see icons by the sockets, the one with the phone icon is for a line to go to a phone headset....this is not the socket for the main phone line, ise the other one that says "line".
Jun 27, 2010 | HP Officejet 5610 All-In-One InkJet...
I'm confused on how to hook up the phone that came with the all in one. also does the telephone company have to do something for me
No you hook up the Hp to the phone line using a phone cord and your all in one can send and recieve faxes anytime and auto answer. If you have a 2 wire cable box for internet highspeed you will have to put a filter on it and you can get that from the phone company for free. So if you have a phone splitter you can have the fax on the same line as your phone and your computer.
Nov 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Try installing filters on your phone line. Make sure not to put filters on the broadband modem. If you are using a splitter for the phone and the modem, just put a filter on the phone line and not the one going to the modem. If this doesn't work, contact your internet service provider (ISP) and tell them the problem. They should send a tech to resolve the problem. This has something to do with the POTS splitter outside your house.
Nov 09, 2009 | Lands Phones
Its telling me no scan option
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
Jul 16, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp all in one 5610 wont receive fax and phone line does not go on double ring . incoming fax shows phone off hook when trying to receive ready appears
Jul 07, 2009 | HP Officejet 5610 All-In-One InkJet...
How to install solaris os on acer aspire 5610 model
You can insert the cd before booting and u can continue installing by selecting in which drive u need to install!!
Jan 15, 2009 | Acer Aspire 5610-4648 Notebook
HP Officejet 5610 All-In-One InkJet Printer Logo
42 people viewed this question
Ben Johnson
