I have a canon 4-in-1 printer pixmamx310. I am getting a message in th led screen "recomend new c-crt". What is this message referring to ? There is no such error code in the manual. Thanks, Joe burns
  • josephburns2 Dec 08, 2008
    Yes. Thanks again
  • 586 Answers
   This message ifto change for ink cartradge,Therefor,Your printer needs to change the cartradge.
Posted on Dec 07, 2008
  • 6,487 Answers
This error message is pointing C-CRT means to replace color ink cart. because it is low on ink or is out.
    Genius:
  • 3,422 Answers
Replacing An Ink Cartridge Use the following procedure to replace empty ink cartridges or when an ink cartridge error appears.
  1. Confirm that the printer is powered on
  2. Lift the Scanning Unit (Printer Cover) with both hands, and pull the Scanning Unit Support down into place (A).
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  3. Press down on the semi-circular tab located on the top of the cartridge to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
    *Optional cartridges PG-40 and CL-41 shown in examples
  4. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  5. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  6. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  7. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)05sj00081_04_en.gif
  8. Confirm that the ink cartrI have a canon 4-in-1 - 05sj00081_04.jpgled properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  9. Fold the scanning unit support and close the scanning unit (printer cover).
  10. Wait until the preparatory operation is complete; it takes about one to two minutes.
source:fixya's expert
  • 10,594 Answers
Its New Cartridge recommendation message.
Canon MP700 Multifunction printer displays message "Wrong cartridge"
1. With the printer powered off but connected to a power source, press the Power button while
pressing and holding the Stop/ Reset button.
2. When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4. When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in. (orange and green, starting with orange.)
Mar 24, 2012 | Canon MultiPASS MP700 All-In-One InkJet...
I have an error message stating, "Release the
This took me forever to find. Please let me know if it works.
http://support-th.canon-asia.com/contents/TH/EN/8000675301.html
Oct 08, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Message on led screen "download
you have to download system software in copier. it can be done by canon engineer only.
May 07, 2011 | Canon iR 2016i Black and White Copier
Clearing LCD Screen from RECOMEND NEW CRT
if u refill it may can't remove that message but try to press stop button for 5 sec to clear it
Apr 28, 2009 | Canon FAX-JX200
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon fax jx200
You need a new ink cartridge
Oct 25, 2008 | Canon FAX-JX200
I am getting a message in the lcd screen that reads "recommend new c-crt". what does this refer to?
It means 'recommend new color cartridge'. And since all Canon printers do not have LCD screens, you might receive more meaningful help if you were to identify your model when submitting questions.
Sep 30, 2008 | Canon Office Equipment & Supplies
Received in Memory issue
=) SOLUTION!!! To print from memory, simply press the "FAX button on the front panel.
Then, press the "MENU" button. "1. Fax Settings" will appear in the display. Press the
"right" arrow key once so that you get "Memory Reference" to appear on the screen.
Press the "OK" button once. It will display "Print List", but you want to "Print Document",
so press the "right" arrow key until you get to "Print Document" and press "OK."
Once you are there, press "OK" again and the message "Print 1st page only?" It displays a YES and NO, so hit the left or right arrow key to choose. If you want to print the entire document,
choose NO and press "OK" Your document will print out!!! =)
Feb 10, 2008 | Canon PIXMA MX310 All-In-One Printer
18 people viewed this question
jasbo
jasbo
