Question about Philips Magnavox MWR10D6 DVD Recorder
How to set up my magnavox dvd player / recorder
I dont have the manual and I need help setting it up and how to use the dvd recorder to record movies off the dvr
  • 1 more comment
  • angelface524 Dec 11, 2008
    got new directv dvr and magnavox mwr10d6 dvd recorder. the recorder will no longer record from the satelite. can someone tell me how to connect this to my tv so it will record
  • bdunsoon Dec 13, 2008
    I need help in recording from my cable dvr to my dvd recorder?
  • evenstarjm Dec 29, 2008
    I would like to hook this up and don't have the manual; however, looking at the manual online doesn't help either. I have a cable box, receiver, TV, DVD, and VCR. Which do I hook it up to?
  • 558 Answers
Http://safemanuals.com/user-guide-instructions-owner-manual/FUNAI/MWR10D6
Posted on Dec 13, 2008
I have Magnavox DVD player/vcr DV225MG9, does it record from vhs onto dvds? And if not, what do I need to get so that I can copy all of these old vhs movies to dvds?
it won't record dvd's its only a dvd player. only the vcr records
if the vhs movies your trying to record are movies like star wars and stuff like that it's copy protected and no worth the trouble. if it's home movies or something you recorded from tv they might work. if you get a dvd recorder/vhs player.
Jul 20, 2015 | Magnavox Televison & Video
Why doesn't my recorded dvd-r movies play on my magnavox dvd player
Does your DVD player support that version of DVD disk? Not all players will handle DVD-R. Check the manual for compatibility.
Try recording to DVD+R then see if your player will play it.
Also, in what format (.avi, .flv, .mov, etc.) was the item recorded and is your player able to handle that format? Again, check the manual for compatibility.
Jan 20, 2015 | Funai FDRV90E DVD Recorder/VCR
How do I finalize my disk once I have finished recording from VHS tape. How do I get the finalize to light up on menu on screen?
If they are +RW discs they cant be finalized and can only be played on +RW compatible players. Use +R, -R or -RW if you need a wider compatibility (DVD-VIDEO). Finalizing is quite easy following directions in the manual.
Apr 20, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
Trying to connect Magnavox MWR 10D6 DVD/Recorder to Sanyo HDTV. TV is connected to Dish network through coax. cable.
Unfortunately, the Magnavox MWR10D6 recorder can not record HD signals. It's only video inputs are coax (RF) and composite video; both are limited to 480i (SD). NTSC (analog signals) are translated to video.
Your best recording option is to connect the composite video output of the Dish receiver to the video input (yellow for video, red and white for audio) of the recorder. Then set the receiver to the channel that you want to record and set the recorder to Line In.
HD recorders may exist. They are much more expensive than the SD versions.
I wish that I had better news for you. The manual for the MWR10D6 is available from Funai here: http://www.funai-corp.com/support/om/MWR10D6.pdf .
Apr 18, 2013 | Philips Magnavox MWR10D6 DVD Recorder
I would like to know if it is possible to copy two vhs movies onto one dvd disk.
Yes, this should be possible, as long as the VHS movies are not copyright protected. Just make sure that the recording mode on the dvd is set to allow enough time for both movies. Just remember: the more you record onto a single disc, the quality of the dubbing (recording of VHS to DVD) is decreased.
Sep 09, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dont know how to finalize dvd after recording on magnavox vcr/dvd
You can find a copy of the manual on the web link provided here:http://tv.manualsonline.com/manuals/mfg/magnavox/mwr20v6_1.html Print a pdf copy for yourself. If you need more help the customer care for you dvd/vcr player is at this telephone number. 1-800-605-8453 give them the model number of your dvd/vcr unit and they will be able to help you. I hope this information helps you with your problem.
May 10, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Mar 02, 2009 | Toshiba DR410 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Cannot record in +VR mode
check to see if the U-verse box is in HD mode. If it is, change it to standard definition and the problem should be solved.
Menu -> Options -> System Settings -> Aspect Ratio
Sep 28, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Dvd recorder mwr10d6
The manual is located at: www.funai-corp.com/6pdf/om/MWR10D6.pdf (copy and paste in your address bar) hope this helps!
Jun 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
911 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
