Question about Averatec SL3150H-01 Notebook
Compaq V 2000 Notebook Does not TURN ON
Hi,I am having a problem with my Compaq V2000. For a while it kept shutting down on me without any heating problem. This happened after not working on it for 3-4 weeks. Now it does not TURN ON. when I plug it to the power I don't show any lights ON at all. I had my Charger checked and there is no problem related to the charger. Could it be the Power Supply or the Mother board? How can I find that out without taking it to shop. It had passed the warranty. :( I appreciate any respond. Eva
    Novelist:
  • 198 Answers
Whell the answer is pretty complicated but however I'll try to give you some info. Laptops have some safety features on them. When you power up a laptop it does something called POST. (Power on self check) This is a BIOS function and after the laptop is powered (only then the BIOS is brought online) it displays eventual errors on the screen and so on. However laptops also have some hardware level potections. They use the various LED's on them to display a error code. If the charger wouldn't work properly some of this LED's will power on in a weird configuration, signaling an error code. If no LED, no response, no nothing ..maybe the problem is more simple. An internal faulty connection for example. You may dissasemble the laptop (if you have some basic knoledge of that, and some proper tools like a multimeter to measure some parameters). After that check the entire area around the DC jack connector for lose connections or burned out components. If you have another question, or want to do that, please reply with another question, to take this to a more deeper level.
Posted on Feb 20, 2007
Drivers for windows 7 for presario V2000
Compaq Presario V2000 Notebook PC has only drivers available for windows XP and 2000. HP has no driver download for Windows 7 for this model.
Please click here for reference
Regards
Riztech
Jan 13, 2011 | HP Compaq Presario V2000 Notebook
Screen is black, but fan runs. Then computer cuts
This most often means you have a bad cpu or motherboard. When the bios does its post checks it looks for issues and will shut the pc down if all the devices are not funtioning correctly or the CPU reaches critical heat.
Dec 29, 2009 | HP Compaq Presario V2000 Notebook
Its just shut down and wont turn on. It has been working fine.
If you have connected your power adapter directly (without a power strip) to another outlet that works, and still doesn't power on, these are generally the reasons:
1. Power adapter is faulty - replace
2. Battery is faulty - replace (try without battery)
3. Power jack on laptop is faulty - repair
Hope this helps to at least narrow down and help you troubleshoot your problem.
Aug 23, 2009 | HP Compaq Presario V2000 Notebook
V2000 (2710US) shutting down randomly
try to use other hard disk. if it works on your machine then your OS is corrupted. You might need to reformat your hard disk.
Before reformatting your hard drive safe all the files first because everything will be deleted.
Jul 01, 2009 | HP Compaq Presario V2000 Notebook
Compaq V2710us shuts down randomly with a loud click
Loud click sounds like either a short or overload, causing ground default. recheck inside for any loose connections anything grounding out the motherboard.
Jun 28, 2009 | HP Compaq Presario V2000 Notebook
The fan is not working
Hi
me too had this problem..the fan may not be rotating..thats the reason..you can remove and fix it yourself if you know to dismantle the laptop.
Mar 16, 2009 | HP Compaq Presario V2000 Notebook
Compaq v2000 dies after some time
Is the machine getting hot when it shuts down? If so, then you may need to clean the fan and heat sink. A dust or dirt build up can hinder the cooling system performance allowing the machine to heat up to a level that kicks in the built in fail safes in order to keep from damaging the processor. Try cleaning them and let me know. We'll go from there.
Aug 01, 2008 | HP Compaq Presario V2000 Notebook
Random shutting down
Your CPU is heating up it will shut down on you the fan that keeps it cool must of clapped out replace it. Then you should be right..
Sep 12, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 "Doesn't turn ON"
1) Unplug the laptop. 2) Press and hold down the standby switch under the lid in the upper left hand side of the laptop while pressing down the power key. You should have full power startup now. Let me know if it worked..
Jan 27, 2007 | HP Compaq Presario V2000 Notebook
Averatec SL3150H-01 Notebook Logo
57 people viewed this question
Top Averatec Computers & Internet Experts
Steve Allison
Steve Allison
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
