Question about Garden
Trying to take off tire from my troy belt mower
I have a troy bilt 33" mulching deck, both tires won't stop leaking air so I was going to take the wheels off and take them to get new tires put on them but they won't come off after taking the clip and 4 washers off. Not sure what I am missing
highspeedsan
  • 61 Answers
SOURCE: Dry rotted tires on riding mower. I can't get the
Try some penetrating oil around where the rim and shaft meet. Spray as far into the space as possible. Let sit for a little while to let the oil work. You may have to persuade it with a hammer.
Posted on Apr 30, 2009
  • 6 Answers
SOURCE: i need to change the blade belt on my troy bilt 33 inch walk behind mower
look up on the internet the make and model of your mower and look under diagrams
Posted on May 22, 2009
moretons
  • 155 Answers
SOURCE: troy bilt lawn mower bronco belt broke HELP!
hi try this site its called pats small engines
Posted on Jul 26, 2009
  • 396 Answers
SOURCE: I have a rear Semi solid rubber tire on my Troy
you can get replacement tires at sears
Posted on Nov 01, 2009
  • 12 Answers
SOURCE: NEED A DIAGRAM OF HOW TO ROUTE A BELT ON A TROY
type in your model number to your search engine. find your model and the diagrams will be there.
hope this helps.
Posted on Aug 13, 2010
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Troy Bilt Mustang XP mower belt diagram
https://www.partstree.com/parts/troy-bilt/mowers-zero-turn-lawn-mower/17wfcacp011-troy-bilt-50-mustang-xp-zero-turn-mower-2013/mower-deck/
Aug 27, 2014 | Troy Garden
Mower belt diagram
Try Goggle it. belt diagram troy -----
Aug 03, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
My lawn mower starts and cuts fine, but it will no longer self propel even though the wheels actually turn when I lift the rear wheels off the ground.
Have you checked the belt? There is a belt that runs from the shaft to the transmission that gets worn and streched out. It will spin the tires, but not under a load. I'm sure thats the problem! The cover is usually located under the deck.
Sep 09, 2011 | Troy Bilt 5.5hp Self Propelled Mower
How maintenance Troy bilt, 6.50 190cc 21" 2 in 1 push mulch mower with rear bag?
my troy-bilt 21" mulch mower 6.50hp/190cc won't start after it run for any amount time.
Sep 05, 2010 | Garden
I have an early-2000s Troy Bilt Bronco, 42 inch deck, 18hp Briggs Inotek engine, hydrostatic drive. It broke or threw a drive belt (not for the mower deck, but a transmission belt). How to you go about...
While mowing the yard, the mower went dead. I tried to recrank it and it won't crank. The gas pedal goes straight to the floor and doesn't work to crank the mower. I do not know anything about mowers and don't know where the problem could be. Can someone help?
Jun 14, 2010 | Troy Garden
How do you remove the gears on a front wheel self propelled troy bilt push mower?
Take the front tires off, pull gears and take out pins, put tires back on and you have a "non-self propell" mower.
Apr 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I just punctured the front tire on my Troy Bilt Pony riding mower. where can i find a replacement tire?
troy sells them but just put tire slime or, a similar product to seal the puncture; into the tire and, fill with air
Oct 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy-Bilt Pony riding lawn mower and the tire was low when I started using it. The tire ended up getting flat and now it won't seal when I try to air it up. What can I do? Is there a sealant I can...
there is a sealant called slime it is green in color at lowes or depot or walmart read directions and install
or you can buy a inner tube and fix it
tube size is based on tire size
check inside of the tire before the tube is used if you go that route to be sure there is nothing to puncture the tube.
you can buy string type plugs to plug a leak if it is in the tread
use windex or equivalent to search for a leak
if its leaking around the rim remove tire and completely clean the rust from the inner rim where the tires bead seats against the rim when inflated.
Sep 16, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
218 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
