Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
How to change a light bulb on a sony KDF-42WE655
  • 10,594 Answers
Please download user manual of KDF-42WE655 from Sony Support and go to page 17, there described how to replace lamp in this TV.
Posted on Dec 07, 2008
My TV is a Sony Grand Wega KDF-42WE655. I purchased the TV new 5 1/2 years ago and have had to replace the bulb once at the beginning of this year. I have a blue shadow on the bottom right corner on the...
The blue shadow is a sign of a bad light engine. this is a common problem for this model. Fixing this type of problem is quite expensive. Light engine Costs you several hundred of dollars nearly to the price of new TV set.
Nov 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The tv Sony kdf-42we655 will not turn on, the light will flash green and make a humming sound but thats it, the light below that labeled "lamp" flashes red? Why is the tv not working properly and why is...
Your tv is a projection one - it uses a very powerful lamp/bulb to generate the light that used for the image. In your tv that bulb has died and must be replaced - it will cost about $200.
Jul 05, 2010 | Sony KDF-42WE655 Television
Sony KDF-42WE655. Screen goes dark.
Replace your lamp if you had it more the 3 years.
Nov 08, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Just changed the bulb in in Sony grand wega. TV turns on a for second and then goes off. Red flashing light appears
Make sure lamp is secured and the door for the lamp is closed, check door switch and Check lamp fan.
Good luck
N Sabre
KDF-60XS955 Blue dots all over screen. Lower left corner of screen has a small blue cone shape. Will a new bulb fix this? If yes how do I replace the bulb?
It is problem of light engine (optical block) in TV and Lamp replacement does not solve it.
TV needs replacement of light engine, that is costly part.
Jun 20, 2009 | Sony KDF-42WE655 Television
I have a 2004 Sony LCD projection TV. The set
It is symptom of weak Lamp (bulb) that requires replacement.
You can buy Sony original lamp from Sony Accessories Store.
Lamp required for KDF-42WE655 part number is as follows..
A1606034B LAMP BLOCK XL-2100U
May 02, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Bulb Replacement for Sony TV KDF-42WE655
no you should only replace a bulb with the one made for that brande t.v. you should put in a sony xl-2400 in your sony t.v. and yes you should get both housing and bulb in 1 i bought mine off ebay for about 116.00$ both lamp and housing very easy to replace good luck also if you have a sony kdf-42we655 or 50we655the lamp part # is xl-21oou or xl-2100
Jan 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDF-42WE655 Wont power up
you need to buy a bulb for the tv its about 179.00 on ebay
Nov 07, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
287 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
