Question about Indesit K344GX Gas Kitchen Range
Oven doesn't stay on
The oven ignites, but after the 6 second delay the flame doesn't stay on
  • curlytrace Jan 04, 2008
    i have the same problem and i have been told that is the flame failure device
    i have just been checking out the prices for the parts and they are about £50 upwards try giving it a clean first its situated next to the ignitor under neath i think
You need a new thermocouple. This is a safety device which holds a small gas valve open when a flame is detected. It stops unburnt gas building up in the oven. I would seek professional advice from a gas safe registered engineer. Check www.gassafe.co.uk for an engineer in your area. Good Luck
Posted on Jun 09, 2009
How do we start the Oven?
first question
have you turned the gas supply on?
Feb 02, 2018 | Kitchen Ranges
Why does my westinghouse gas oven ignite, go off, ignite again, off,on, off, on, before temp is reached?
dirty gas orifice in the oven near the burner clean it and try again
Jul 22, 2017 | Ovens
After oven reaches desired temperature, it has late ignition that turns off the pilot AND OVEN WILL NOT STAY ON.
Sounds like the pilot is mounted to far away from the burner. I have seen it happen before where the pilot has detached and the main burner will just keep pumping gas in until it hits the pilot flame and just flash flames and everything goes out.
Or it just could be a bad thermocouple that is going out all the time.
Mar 01, 2013 | Southbend S36D 36" 6 Burner Gas Range,...
Can get the oven to stay lite
If the oven lights for 4 seconds and shuts off you are experiencing an ignition module safety lockout. First verify that the flame is lighting at the top of the burner and reaching the very bottom venturii tube where the flame sensor is located. If this bottom tube isn't lighting or it takes longer than 4 seconds to light then you have a dirty burner and it needs to be taken out and rinsed. If the bottom tube is lighting and then going out your flame sensor needs to be cleaned, which is easy.
Mar 21, 2012 | Baxter BXA2G Stainless Steel Gas Single...
Long delay before oven ignites
if the flame doesn't ignite within 40 seconds change out the ignitor.
May 15, 2011 | Amana AGR5735QDS Gas Kitchen Range
Hello and thank you for your help. My lower oven will not ignite while the smaller upper oven will. ?????? Thank you Rob
most likely all you have is a bad ignitor.if it glows it should ignite the flame in less than 40 seconds,if it doesn't glow,pull it out and read it out with a meter.next time send the model number.good luck.
Apr 30, 2011 | Maytag Ovens
Flame does not always stay on after ignition, sometimes it does and when it doesnt you open and close the door for re- light ?
Opening and closing the door will reset the ignition sequence, do not do this repeatedly as you could cause a build-up of unburned gas in your heat exchanger and damage it. Instead verify that your ignitor is glowing, then see if the burner lights and make sure the flame carries all the way down to the bottom of the burner. If the flame stalls halfway or doesn't make it all the way to the bottom in 4 seconds after 3 attempts you will experience an ignition lockout, a safety feature built into your ignition module. If this is the case your burner needs to be cleaned and serviced, have a professional do it.
If the flame is reaching the bottom of the burner but still going out after about 4 seconds then you have a dirty/broken flame sensor. You can attempt to clean your flame sensor by removing the screw that holds it into the burner. With it removed it will look like a metal rod going through some ceramic, clean the metal rod part with a wire brush or emory cloth (fine sandpaper). Replace the flame rod and try again and see if the burner stays on this time. If it still goes out your burner needs to be serviced by a licensed technician.
Feb 11, 2011 | Baxter BXA2G Stainless Steel Gas Single...
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
Oven will not respond
The knob won't have any effect on the flame size.  The knob controls temperature.  If you're referring to the pilot light staying on and then the main flame not going on...that's another problem.  If the main flame will not go on, the assembly that controls the main flame is likely defective.  If the unit has a thermocouple, you might change it out first.  Sometimes, that's all that is needed and they're cheap.
Nov 23, 2008 | Rangemaster 110 (Gas) Kitchen Range
Pressure of flames in Cannon gas oven
HI thanks for your question. the part that's at fault, is the igniter. it glows but not hot enough to ignite all the gas. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | Ovens
Indesit K344GX Gas Kitchen Range Logo
1,015 people viewed this question
Top Indesit Kitchen Ranges Experts
Paul Carew
ptpumpman
Marvin
Marvin
Are you an Indesit Kitchen Range Expert? Answer questions, earn points and help others
