Question about Boston Acoustics BA735 Computer Speakers
Sound card works for audio but no sound for XP sound files
I use Turtlebeach Santa Cruz sound cards in all of my computers so I am pretty familiar with the cards. One machine has suddenly stopped playing any of the sounds associated with actions in Windows XP -- like logon etc. The card does play stored wav files and audio CD's however. Device Manager says the card is working -- and it is, as I described. If I go to Sounds etc. and select an associated audio file, it appears in the box as it should, but the triangle button to cause it to play is greyed out. I can adjust volume, balance etc. with no problem when playing a wav file or audio, but cannot figure out how to get the XP associated audio files to work as they used to. I have cleared to default and reassociated files with no change.
Any suggestions would be apprciated.
    Problem Solver:
  • 18 Answers
Have you checked the colume control? maybe you hace something muted on the volume control. Otherwise, I should say go to eventviewer and let me know if you see any errors. Also running windows updates can also work for you or fix your problem...
Posted on Dec 09, 2008
PROBLEM WITH TABLET CRUZ READER R101
To update the firmware you can follow the directions here http://www.ehow.com/how_7890482_update-cruz-reader-firmware.html
I used a similar method when I had my Cruz Reader R101. This process is called "side-loading"
You will have to download a file to your computer (not your tablet), remove the SD media card from your cruz, then transfer the downloaded file from your computer to it, then replace the SD card to your cruz.
Also you can download the user manual here http://www.retrevo.com/support/Velocity-R101-Tablets-manual/id/23894dj696/t/2/ which shows how to remove the card, and this is a great reference to keep on your reader. For example, page 14 shows how to transfer files to and from your reader. Good luck!
Jul 21, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
How do you restor you cruz r101 to factory default
The easiest way to restore the Cruz Reader to factory defaults is to update to the newest firmware which can be downloaded from here. The instructions for doing the upgrade are also explained on the link above.
This will revert everything back to original condition leaving any information on the internal and external memory cards intact. If you are looking to clear those as well you can do so by formatting the cards by going to Settings->Storage (might say SD card)->Unmount->Format. You can also take the cards out and put them in your computer and use the computer to format them.
The process is pretty of upgrading the firmware is pretty simple even though it might be intimidating. Let me know if you have any more questions
Hope this helps
Ray
Mar 12, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
How to I sync my ebooks to my cruz reader
The easiest way, if you don't have CruzSync on your computer, is with an SD card. Copy the files onto it then put the SD card in your Cruz. Then open Astro from the home screen and find your new SD card and open that up. Or you can use the cradle to transfer files. Open one internal browser to the cruz and one to your e-books then copy and paste them over. You'll fill up your internal memory pretty quickly this way, though.
Dec 27, 2010 | Velocity Micro Cruz Reader R101 Tablet PC
I installed windows XP on my desktop and when i was about to play a music, it displayed no audio device. Can you help me in my problem? I am not familiar with this desktop. Any help is appreciated.
You need to install the motherboard's device drivers after installing Windows XP. If the audio card is built-in on the motherboard then you need to doenload the audio driver from the motherboard manufacturer's WEB site.
If the audio card is installed on the PCI expansion slot the you need to download the audio driver from the audio card manufacturer's WEB site.
If your computer isn't connected to the Internet then you need to download the drivers from a computer that has Internet connection and then copy these files to a flash memory stick and install them on your computer.
The other way to upgrade is to install a driver upgrade program, but this will only work if your computer has Internet connection is up and running. Try these WE sites :-
Driver Detective
http://www.drivershq.com/
Driver Guide
http://driverguide.com
Nov 28, 2010 | Computers & Internet
When i am listening to music i notice that the music starts to get quieter and after about 1 hour or so it goes silent if i just leave it i cant see the slider moving when i watch it but when i leave it...
Look for a fade or cross fade function.
Use the "help" feature of the TB software to research things under these two names. Somehow one of these might have got set to a long time period rather than never.
Dec 30, 2009 | Voyetra Turtle Beach Santa Cruz Sound Card
Distorted sound.
You can try shutting off Audio Hardware Acceleration.
Start > Control Panel > Sounds and Audio Devices > Advanced (Under Speaker Settings) > Performance.
Let us know
Good Luck
Apr 14, 2009 | Audio Players & Recorders
Need suggestion for replacement sound card for Dimension 8100
Most sound cards use the PCI bus to install a card. A cheap Sound Blaster Audigy works great for most applications.Under 40 bucks at Walmart.
Nov 26, 2008 | Dell Dimension 8100 PC Desktop
Audio sound driver
i lost my asus drivers cd so i want to isntall this
Mar 24, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Boston Acoustics BA735 Computer Speakers Logo
54 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
