Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Compressor makes a loud gurgling sound when it shuts off.
Product is a profile ge model tpx21pr or br
  • psabalja Dec 19, 2008
    i may have describe the noise incorrectly. it is definitely not normal because they would never be able to sell another re-frig if this noise was normal. the noise is like a metal banging against other metal when the compressor shuts off which last about a seconds or two, the compressor seems to vibrate severly when it stops and thats when noise occurs again not always. thanks
    Scholar:
  • 111 Answers
The gurgling sound is normal. When the compressor shuts off the refrigerant is still flowing through the system until the pressure equalizes... probably 5-10 minutes
Posted on Dec 19, 2008
  • Expert Brian Dec 19, 2008
    Oh... that's not good news... Sounds like you have a bad compressor and when it shuts off the torque is causing it to jump internally and hit the inside of the compressor case. Only way to fix is to have a tech replace the compressor. Sorry about the bad news.
How to stop the really loud noise on my GE Refrigerator?
It sounds like the compressor is failing, I would make a service call soon.
Sep 23, 2016 | GE Refrigerators
Very loud noises
Check the rubber mounts under the compressor and look for any lines touching the sides of the cabinet. The gurgling and clunking are often normal. good luck. Roger
Jan 19, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
GE PROFILE MICROWAVE MODEL JEB1095SB002 Making
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 05, 2011 | GE Profile Over-the-Range Microwave
I have a GE Profile Side by Side TPX21PR/Tpx21BR. The freezer is not freezing ice cream or even bread, but the meat seems fine. There has been a loud noise emanating from the unit for over a year.
Kindly provide few more details so that i could provide more appropriate solution to your problem :-
1. How old is the unit?
2. Kindly hear the noise - Is it from the freezer section or upper back or lower back of the refrigerator?
3. Do you hear the compressor running?
4. Any problem with temperature in lower section or is it limited to freezer section?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 21, 2011 | GE Refrigerators
My brand new Beko frost free fridge freezer makes a loud gurgling noise and sounds like water trickling inside every time the fridge door is opened then closed again, regardless of how long its open for....
mINE IS DOING EXACTLY THE SAME - I'VE HAD IT ABOUT 2 WEEKS BUT ONLY STARTED MAKING THIS SOUND TODAY AND AS YOU SAY ONLY WHEN THE FRIDGE DOOR IS OPENED AND THEN SHUT!
Oct 08, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
The compressor motor on our GE Profile side by side has been making a loud banging sound when it shuts off. Now, it doesn't shut off at all. I notice some ice formed in the back of the freezer.
two seperate issues,the springs within the compressor housing that support the piston have broken,can only be resolved by replacing compressor....in regards to the ice build up,you have a defrost problem.defrost issues can usually be resolved for about 120-160.00 through a qualified servicer
Mar 06, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
The GE Profile of 13 years old makes a loud bang sometimes a few times a day after running awhile -- does it mean it is the compressor and time for a new refrigerator or could it be something else -- we...
Good day,
If it makes the clunk or banging noise when the compressor is shutting off, then yes, internal spring or springs inside the compressor have broken.
Only solution to that problem is a new compressor.
P.S. these things can run a long time with this condition, but ultimately .....
Thank you for using FixYa
Dec 25, 2009 | GE Refrigerators
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Sub-zero 650 makes loud gurgling sound
gurgling is not unusual and is caused exactly by fluid bubbling thro a pipe.
Nov 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
329 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
