Question about Sanyo SR-9510W Refrigerator
Glass shelve on bottom over grisper is broken Sanyo SR-9510W
Like to order a new shelve asap.
You didn't say what size or model Sanyo you have, but the solution is easy. I have a Sanyo under the counter refrigerator in which the glass over the crisper is 1/8" thick frosted glass, 16" by 6 3/4" with the two back corners cut off diagonally. The frosting is simply to prevent you seeing through into the crisper below. It is maybe fifteen minutes work with a piece of window glass and a glass cutter to make a replacement. My full size refrigerator uses 1/4" glass since it is much larger and I have replaced it myself this way. If you don't have a glass cutter -- they are cheap and available in all harware stores -- you should be able to get any hardware store to make the cuts for you. They are accustomed to making custom cuts for people replacing their own windows. The have, and I use, what is known as an oil cutter which is a lot easier to use than the little hardened steel wheel cutters you will get if you buy a cheap one. Those work fine for straight cuts. Oil cutters make curver cuts equally easy to do.
Posted on Dec 07, 2008
I need Shelf replacement for Sanyo SR-3720M
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Go into the following web site:
Consumer Electronic Parts and Accessories at PacParts Inc
Mar 30, 2015 | Sanyo Refrigerators
Part Number for E522B glass shelf
if you measure the broken shelf or take it to your local glazier they will cut the proper glass to size for you and its not expensive
Mar 20, 2014 | Fisher and Paykel Active Smart E522B...
The glass shelves inside the fridge are broken, NEED TO REPLACE THEM URGENTLY
Get in touch Sanyo retailer in your area and ask him to get you the replacement.
OR
Go on line to support at Sanyo Website and order the necessary part.
OR
Take out the broken pieces and assemble them on a flat service to get the measurements or draw an impression of it on a large size paper. Go to a glass dealer and ask him to cut a required thickness glass which you can fix it yourself. It will prove to be cheaper. There is nothing special in the shelf glass
Apr 24, 2011 | Sanyo Midsize Compact Refrigerator -...
Excess frost and condensation
Could be that it is not getting a good seal when the door is shut. Check for obstructions causing that and check the door seal to see if it needs to be replaced.
Mar 13, 2017 | Sanyo SR-9510W Refrigerator
Samsung Cooltech spare shelves available in b'lore??
it is possibly cheaper to go to a glass firm and get glass cut and edges polished to fit than it would be to buy replacement shelves.the mark up is horrendous on any spare parts......
Apr 20, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Aside from licensing is there a reason I cannot replace the freon in my Sanyo sr-9510w
Hi, First check your unit's owners manual regarding the warranty as it pertains to the "sealed system" as this would fall under that, with the exception of a puncture inflicted by the consumer. Now, aside from licensing...Check your state laws. It is illegal to "recharge" a system knowing a leak exist's without first repairing such a thing, if indeed one does/did exist (I assume if it is in need of a "freon/refrigerant charge" it has leaked). I could be wrong, but I think it's against federal law in the U.S.A. to do so without a license. I know for certain it is illegal in the country I reside, Canada. Hope that helps. Good luck
Sep 30, 2009 | Sanyo SR-9510W Refrigerator
Sanyo 4.9cu.ft. compact refrigerator heats rather than cools
I'd already picked up a replacement (B&D 2.7cf) before I found the website and asked the question,,,, hoped for a quick fix answer and I'd be able to return the B&D.... oh well. With 'designed' obsolescence and 'disposable' appliances, Robert L's answer confirmed my 'fears'.
Now I'm trying to find someone locally (Conroe, TX) who would like to 'recycle' the Sanyo (everything but the compressor/motor is in great shape - door, glass shelves, etc. maybe even the coolant which I don't want to 'dump' in a landfill.
Jul 23, 2009 | Sanyo Refrigerators
Broken glass shelves- SR-4433S
you would have to order them from sanyo at www.us.sany.com
Oct 20, 2007 | Sanyo 4.4 cu. ft Counter-High...
Sanyo SR-9510W Refrigerator Logo
107 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
