Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Need owners manual
I have lost the manual for this vacuum and I need to clean the filter. is it a good idea to keep a spare? I can not see how to remove the one on my unit. I love the machine and just noticed the note on cleaning the filter every few months. Have I ruined my machine?
    Problem Solver:
  • 9 Answers
Hi, try here:
http://safemanuals.com/user-guide-instructions-owner-manual/DYSON/DC07-_E
I doubt you've ruined it, just clean/change it asap!!
Hope that helps.
Posted on Dec 07, 2008
Why does the thermal protection keep shutting the vacuum off?
Hi! It appears your thermal protector sensor has kicked in and caused your cleaner to power off. This is usually due to a clog or a filter that needs to be cleaned or replaced. Try these steps to get your vacuum back up & running!
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Clean the filter as suggested by the owner's manual.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
Your vacuum should turn back on after it cools off, this can take up to an hour. Hope this helps!
Jun 28, 2014 | Hoover Vacuums
No dirt in cup and the red thing does not turn
Hello! It sounds like your vacuum has lost suction. This is caused by either a clog or a filter that needs to be cleaned or replaced. Please try these brief trouble-shooting steps.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Exhaust Foam Filter
Primary Filter
Hope this was helpful!
May 10, 2014 | Hoover Nano Cyclonic Compact Bagless...
My dco7 keeps overheating and switching itself off...Any ideas wot could be causing this??
Yes. There's a blockage somewhere which is restricting the airflow. Follow instructions in the User Manual (you can download one from the Dyson website if necessary) for clearing blockages. Also make sure the washable filter is clean (and don't put it back until it's completely dry - at least 24 hours in a warm place). Good luck!
Feb 03, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Wand lost suction
cleaning all filter Assy and all Handle Assy and Hose Assy...
Nov 06, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
My hoover mach 6 bagless overheats, shuts off for about an 1 hr will run again, all filters are clean, no blocks in hoses, how can i fix this problem
This is telling you that there is poor air flow or a blockage somewhere. To simply check for proper suction, remove the accessory hose to see if there is normal suction, if not then your problem is further in the unit. Troubleshooting from there will tell you where the problem is. Another possibility is that your thermal overload circuit is faulty. in this case a pro vac shop needs to service the issue.
Feb 28, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Miele Revolution Vaccuum cleaner manual
Under the download section is the owners manual. This is for the same series Miele that you have so this manual will have most everything you need to know. The black filter is a charcoal filter, this is good if you want to control the odor but don't have allergies. If you have allergies you might wont to get a HEPA filter. I would recommend changing the filter every 6 months to a year. You need to use the empty filter when you want to use it as a blower. The hose will not fit into the opening with the HEPA or charcoal filter in place. I hope this helps.
https://www.centralvacuumstores.com/item.php?id=4545#
Jan 06, 2009 | Miele Revolution 600 Bagged Canister...
How do I clean the filters
Generic problem for all Vacuums
How do I clean the
How do I clean the filters?
Comment by Avonb, posted on Apr 22, 2008 I have a Bagless twin clean, thought I was cleaning the filters but apparently not, the manual is very vague
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not knowing the Model # or Brand name, it is a good idea that you can vacuum of the filters, if you have a blower – you can blow off the dirt from the filters, some filters are washable and you can clean them by washing them and letting them dry completely before you re-install the filters. Idea? If you have an old paint brush, that is ideal to clean off HEPA filters or cartridge filters or use a blower to clean off the dirt. You need to be the best judge on how to clean the filters. You can check the company’s website for the brand name such as:
http://www.hoover.com ---- example given
Don – The Vac Man
Apr 22, 2008 | Vacuums
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
149 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
