Question about Breadman TR2200C Ultimate Bread Maker
Smoke coming from machine during baking
Mixing and rising stages worked as usual. During baking stage heavy smoke pouring out vent
  • Rob360 Dec 22, 2008
    I have the same problem.. and I opened it up to see what was wrong. Smoke was not coming from the mixture but from the electric motor operating the blade. Also, the machine made more noise mixing than before. Did you have that too?
    I don't know what to do, anybody knows an email address to contact the manufacturer?
5 Suggested Answers
SpotBert
  • 231 Answers
SOURCE: Bread Rises Beautifully - then sinks in middle during bake cycle
Sinking in the middle means that there was too much rising for the amount of structure in the bread.
Usual causes:
-too much yeast (reduce 1/2 tsp.)
-too much sugar (reduce 1/2 tsp.)
-not enough salt (increase 1/4 tsp.)
-too much water (reduce 1 tbsp)
Another possible remedy: use "best for bread" flour, it has more gluten, or add gluten separately, 1 tbsp.
Start with reducing amount of water.
Posted on Jan 04, 2009
  • 6 Answers
SOURCE: Sanyo Breadmaker will not finish the baking cycle.
The manual just say that an error E:05 is a bread maker malfunction and you can't fix it but must get it serviced.
Posted on Aug 30, 2009
  • 433 Answers
SOURCE: Would there be any problem if I removed the paddle
Hi, No problem at all. People do this to prevent the paddle from staying in the bread. If bread machine does not have a pause, take the pan out of the machine to remove the paddle to be safe, and do this before final rise and baking cycles. Hank
Posted on Mar 19, 2010
  • 433 Answers
SOURCE: the paddle keeps coming off during mixing and
Hi, The sealed bearing located on the bottom of the bread pan has failed. This bearing is sealed with lubricant to allow the paddle shaft to spin easily. The black stain you see is the lubricating grease. You need a new bread pan. Hank
Posted on Jan 25, 2011
How can I get the machine to start the bread making process from the beginning. It is currently stuck on knead.
Do you have your owners manual and have you baked bread in your machine before? Just want to be sure that you know the stages that the machine goes through. The first mixing and kneading stage in a tr444 will take up to 15 minutes before it stops on its own. It will then let the dough rest for about 1/2 hour before the 2nd knead begins. It takes almost 4 hours for your machine to go through all the stages before your baked bread is finished.
Jan 15, 2015 | Breadman TR444 Bread Maker
When I bake a loaf of bread it comes out of the machine with the ceramic mixing paddle baked into the loaf! How do I keep this from happening?
That often happens with bread machines. You can lessen the possibility by using milk in place of water and also choose light crust. This is pretty advanced but if it really bugs you,,, here goes.... After the final punch down and at the very beginning of the final "rise" stage you can remove the dough ball with one hand,( lightly flour your hands first) try to remove the paddle with the other hand from the dough ball and return the dough ball to the center of the pan, and close the lid Just be sure you don't remove your dough ball too early... check your owner manual and be sure you don't remove it BEFORE THE FINAL PUNCH DOWN....!
Feb 15, 2013 | Kitchen Appliances - Others
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
My machine was unplugged for no more than 3 seconds during kneading. it is quiet now and on ALERT. on a 5 hour whole wheat xl loaf..now at 3:02. how do i restart it and move it off of alert
If you feel your dough has kneaded and risen enough, try pushing the stop button until it beeps. Then unplug and replug and select the bake stage and using the timer feature put enough time on the bake cycle to equal the bake time of your original whole wheat bake stage. That time should be on your page in the manual that shows the length of all the programs.
Oct 28, 2010 | Panasonic SD-YD250 Bread Maker
What is the drive cycle for a 1999 vw jetta
The drive cycle is as follows
For all OBD2 VW's
OBD-II Drive Cycle Stages
The OBD-II Drive Cycle is an eight-stage course, as illustrated in the
chart on page 3. An explanation of each step is provided below.
Stage 1: Cold Start-The ECM determines the presence of a cold start
by comparing the engine coolant temperature to the ambient air
temperature during startup. The engine is considered cold when:
• Engine coolant temperature is below 122°F (50°C).
• Engine coolant and intake air temperatures are within 11°F (6°C) of
each other at startup.
During this period, the O2S heater, misfire, AIR, fuel system, and EVAP
monitors run.
Stage 2: Idle 2½ Minutes-Turn the air conditioning (A/C) and
headlights on to help the misfire monitor-the additional electrical loads
help even out combustion pulses. During this period, the O2S heater,
AIR, EVAP, misfire, and possibly fuel system (if operating in closed loop)
monitors run.
Stage 3: Accelerate-Prior to accelerating, turn off the A/C and
headlights (if possible). Open the throttle halfway until you reach
55 MPH (89 KPH). During acceleration, the misfire, fuel system, and
EVAP monitors run.
Stage 4: Steady State Cruise-During this portion of the cycle, the
O2S, AIR, EGR, EVAP, misfire, and fuel system monitors run.
Stage 5: Decelerate-Gradually coast down without applying the
brakes. Also, on manual transmission vehicles, remain in high gear and
do not press the clutch. During this period, the EGR, EVAP, and fuel
Stage 6: Accelerate-Apply ¾ throttle until reaching 60 MPH (97 KPH).
During acceleration, the misfire, fuel system, and EVAP monitors run.
Stage 7: Steady State Cruise-During this period, the CAT, O2S, AIR,
Stage 8: Decelerate-Gradually coast down without applying the
do not press the clutch. During this portion of the Drive Cycle, the EGR,
EVAP, and fuel system monitors run.
You can try this a couple times, but if it doesn't work you should go to a VW specialty shop like the dealer or a shop that does mostly European cars and they can use the scan tool to force the car through readiness.
Oct 11, 2010 | 1999 Volkswagen New Jetta
Would there be any problem if I removed the paddle after all dough mixing has been completed?(before baking stage)
Mar 19, 2010 | Sunbeam 5891 Bread Maker
My samsung washing machine model WA13513 13.5kg load had 8E error message popping out from the screen. Is the computer board damaged?
OVER CURRENT ERROR – Display shows 8E. IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
If the motor stops working, in one direction ten times, “8E” Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error “8E” is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power SIW OFF can clear the overload error.
would advise calling a tech... hope this helps.
Oct 25, 2009 | Washing Machines
Fabric softner does not empyt from its tray during the rise cycle
USUAL PROBLEM THERE IS ASIPHON TUBE IN THIS TRAY AND THE THEORY IS SIMPLE IN FACT :
1- WE MUST TO RECEIVE ENOUGH WATER COME TO THIS TRAY TO REACH CERTAIN LEVEL TO DRAIN THE SOFTENER
2- AND THE WATER WILL COME ONLY AT LAST STAGE RINSE
3- THE SIPHON TUBE MUST BE IN RIGHT POSITION FIT
4-UNDER THE SIPHON TUBE THERE IS A PIPE MUST BE CLEAR OF CLOGING MATERIALS
5- SO THE REMEDY WILL RELATE TO EVERY STEP
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
E8 error code
8E - OVER CURRENT ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2009 | Washing Machines
Inside tem. can not reach the set tem. during the cool days
check the presure switch jump it out and see if it fires all the time
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Breadman TR2200C Ultimate Bread Maker Logo
132 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
