Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
RED Ghost Image on Samsung 42" Rear projection HDTV (Model - HCN4226W)
My TV just started showing a red ghost on everything. ( Component, Cable, and RCA inputs.) I called the repair shop and they said that the capsule needs to be replaced at the cost of 450 dollars!!!! I bought the TV for 900...... anyways, I tried using the 'perfect focus' feature that samsung has under the convergence menu and it does the green focus and the moves on to the red and it makes a bunch of irregular movements and the returns to the green one and starts all over again. I can't figuire it out and I have never repaired a TV before, although I am very handy and I'm sure I could figure it..... I just don't know where to start. nay suggestions? Is it a cinvergence problem or bad capsules? Thanks, Colorado.
I WOULD RATHER THINK IT IS ONE OF THE CINVERGENCE AMPLIFIER & DRIVER IC,S A REAR PROJECTION TV NORMALY HAS 2 OF THEM AND THEY ARE THE SAME AND NORMALLY THE NUMBER ON THE IC STARTS WITH "STR *****" SWAPING THE TWO AROUND WOULD PROVE THAT YOU GOT A PROBLEM ON ONE OF THEM,THEN JUST GET 2 NEW IC'C THE SYMPTOM THAT YOU ARE DESCRYBING IS MOST LIKELY THE IC'S HOPE THIS HELPS IGNATIUS ,SOUTH AFRICA TV REPAIR ENGINEER
Posted on Feb 20, 2007
Samsung HCN4226W "image pinching"
The convergence IC has gone out and is located on the Main bd or the Power supply bd depending on the specific model and must be replaced and a Full convergence alignment must be performed to return your tv to a watchable condition. Only a Samsung trained tech can do this.
Jul 16, 2009 | Samsung HCN4226W 42" Rear Projection...
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Dont turn on
sometimes a small signal diode in power supply side is shorted. or IC component damaged.
Jun 02, 2009 | Samsung HCN4226W 42" Rear Projection...
No color!
we had this exact same issue with our Samsung projection tv. We solved the problem (temporarily) by trading in the cable box for a new one. All colors worked for a while, now the red goes on and off at will... I think we may have had a problem with the cable box AND the tv. Maybe this will help?? Good luck!
Mar 11, 2009 | Samsung HCN4226W 42" Rear Projection...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Blue ghost
Replace convergence IC'S and check values of convergence circuit resistors.
Aug 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W blue color outlines
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Convergence problem?
That board, P/N Bp94-00155a should fix the problem and be fairly easy to replace. Make sure you unplug the TV before starting the repair though. Duh!
Mar 11, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
120 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
