Question about Refrigerators
I have a beko ap930 . always E4 apears on the display .
Although the fridge end frezeer works fine .
  • 1 more comment
  • ezzdinstar Dec 08, 2008
    the informition which you gave me about my fridge wasn,t clear . i got e4 problem and i checked if the there was any water on it . but nothing in there!!
  • 734 Answers
That is correct, either you have a bad relay or the compressor is shot.
Posted on Dec 08, 2008
  • 1 more comment
  • futureloginn
    futureloginn Dec 08, 2008
    ll that check out then read voltage through the relay to confirm that the compressor is recieving 120 volts...if it isn't and you have 120 volts going to the realy then your relay is bad. If there is 120 volts going through the relay to the compressor then your compressor is stuck (shot)
  • futureloginn
    Is there a switch inside the fridge on the back?Has someone accidentally moved it from highest setting to lowest?
    Ours has numbers 1 -5 with 5 being the coldest.
  • futureloginn
    futureloginn Dec 10, 2008
    Is there a switch inside the fridge on the back?Has someone accidentally moved it from highest setting to lowest?Ours has numbers 1 -5 with 5 being the coldest.
  • 1,800 Answers
E4= Thermostat Short Circuit.
u have to remove the short circuit from that part
click here to learn the how to test it
    Sergeant:
  • 399 Answers
Its the short circuit in your thermistor area.please check it out to make this problem solve.
    Sergeant:
    Champion:
  • 304 Answers
E4 - Fridge thermistor short circuit.
there was a problem on the thermistor, you need to check on this part.
you may need to call someone if you were not experience how to troubleshoot this problem.
hope this initial info helps.
  • Elizabeth Krijt
    Elizabeth Krijt Dec 08, 2008
    so unplugging the fridge for a while. or try to reset the system settings made.
    let me know if the error message will disappear.
    Genius:
  • 1,550 Answers
You need to be clear with your problem .
Provide some more information about your problem.
  • SAM ANDERSON Dec 08, 2008
    Sorry i did not see your tag properly .
    E4 means Fridge thermistor short circuit.
  • Refrigerators Master
  • 19,396 Answers
E4 must be drain problem, check if ther is ice or water accumulating inside the friodge.
  • Ginko
    Ginko Dec 08, 2008
    E4 - Fridge thermistor short circuit. is for a Cannon appliances error code, however it is possible that the two appliances have the same code.
    If the code happens sporadically , and the frodge works, it can be a malfunction on the control assembly.
  • Ginko
    Ginko Dec 08, 2008
    Beko should have same hotpoint codes, see
    how to mend it
    Then it is an E4 - Fridge thermistor short circuit error, if the fridge is working, that means that the thermistor is fine, otherwise you get poor cooling or icing up and food freezing in the fridge compartments.
    This is probably a little control panel malfunction, should the fridge start having cooling problems, and E4 comes up, then test and replace the thermistor, if it works, leave it.
    If you are in UK call Beko at : 0870 241 0638
Why does the new fan in my Beko AP930 not come on. It worked for 30 minutes when I first installed it.
Three possibilities: 1) new fan motor failed or is jammed by something
2) power is not getting to the new fan. 3) The fan run circuitry is not getting the 'run' signal from the temperature sensing system.
Jul 23, 2014 | Beko Fridge Water Filter Ap930 Ap930x...
Why won't the new fan on my fridge freezer work
The new fan motor may have failed!. Check the power supply to the fan motor. If the fan motor was not designed for the very cold air (-20 F) it simply stuck.
Service manual for beko
go to www. fitness.manualsonline.om or www. retrevo.com or www.manualsfactory.com
God bless you
Jun 18, 2012 | Beko Fridge Water Filter Ap930 Ap930x...
Beko fridge freezer modle ap930s my fridge is freezing everything inside is this because the thermostat is not working?
Change the thermostat.
http://www.acmehowto.com/howto/appliance/refrigerator/repair/tempcontrol.php
Nov 28, 2010 | Refrigerators
Error code E3, BEKO AP930
Hi, the error code E3 on the BEKO AP930 you have a problem with the fridge thermostat open circuit....
Take care
Jul 23, 2010 | Refrigerators
Beko ap930 no water geting to to ice tray
For me, this problem was because the tube was blocked with ice (the part of the tube inside the machine), which is why the tube popped off the back.
Try defrosting the freezer, or pushing hot water through the pipe with a syringe
Oct 28, 2009 | Beko 24 in. D3421F Free-standing...
Fault e8 displayed on beko ap930 fridge freezer
I had the same error message and the ice cube dispenser stopped working. On examining the workings, I found that the wire that should have been connected to the ice cube tray had sheared somehow (???) - a simple splice with lots of insulation tape has apparently fixed the problem.
Jul 03, 2008 | Refrigerators
Beko AP930 with Error code E0 in LHS of display .... what does this mean ? .... nothing in manual
Error codes are printed on underside of plastic cover on top of fridge. Warning electrical components inside! Error code E0 is the FREEZER door not being recognised as closed, switches are normally ok may be problem with printed circuit board. Freezer will work as normal but engineer should be called.
May 08, 2008 | Refrigerators
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
