Question about Whirlpool LGR4634J Gas Dryer
Autocycle doesn't stop
We had the prior problem of the autocycle not advancing. We checked the sensor on lower left side on the burner tube. Ohmed out fine. Wondering if a propane orifice installed when natural gas was being used would cause the same problem. It seems like the flame is very small and it isn't producing enough heat. When ran in the timed mode, the timer advances, but the clothes are still wet.
  • 1 more comment
  • Mary Bell Feb 25, 2007
    Thanks Gendos. We swtched out the orifice and the flame was still low and it didn't fix the problem. Then we switched out the 4 prong t-stat and that didn't fix the problem either. It is still not heating up enough to get the clothes dry or to make the auto cycle advance. We had already cleaned out any lint that was hanging around and all the exhaust lines are open.
    Any other suggestions before we give up??
  • Mary Bell Mar 04, 2007
    Gendos
    Thanks for all your help. We disconnected the hose from the dryer as you suggested, but it didn't make any difference.
    Any more ideas??
    Mheidenhof
  • Mary Bell Mar 24, 2007
    Hi Gendos,
    We disconnected the vent hose from the dryer and ran the dryer. The air temp from the dryer vent outlet is 80 degrees. Thanks again for all your help!!
    mheidenhof
Change the ceramic fuse
Posted on Dec 20, 2007
How to tell what year the heidleberg quickfold is ?
I have never heard of that is it a motorcycle or autocycle ?
Mar 06, 2015 | Motorcycles
My dryer is an Inglis, heavy duty 6 cycle, 4 temp, autocycle that is about 7 years old. Recently it just heats up but does not dry the clothes. They are steamy hot but wet. I checked the vent, it is not...
It sounds like the blower is not forcing air through the dryer. I would start by turning the dryer on and checking the vent exhaust to see if there is a good healthy air flow where it vents to the outside. If there is not good air flow, start back tracking the air flow for obstructions or other problems. Check the lint filter to be clean, check the air piping to be clear, check the blower to be clear and functioning.
Oct 03, 2013 | Dryers
Ingersoll rand intellisys 22128763 stays on 'checking machine' after a power outage. How do I get it back to 'ready to start'?
e stop warning on screen stays on. i checked with a meter and both sets of contacts work. left side with red wires have 130v ac in and out of switch. right side of e stop has blue wires and no voltage. i ohmed with meter and switch is working
Feb 28, 2012 | Ingersoll Rand Tools & Hardware - Others
I have a P-R405B-EP and the flame roll-out switch went off. I by- passed the switch briefly to see what the problem is. The switch worked for good reason. Ther are some flames coming from the bottom left...
Thank you for posting your question here on Fixya.com.
Spiders have been in the burner tubes and there is enough silk in there to prevent the gas flow down the tube. I use a stiff piece of #8 wire to run up inside the tube to clear out the silk.
Along the bottom edge where it slips over the jet you should see a little dip and opening from below the gas manifold. Run the wire up into the burner from there. If there is a lot or a few passes doesn't clear it out I bend a little hook into the tip of the wire. After a few more passes it should clean it all out and the burner tunes should work properly. Confirm this by checking all the flames to ensure they are solid blue and a few inches tall off the burners.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Aug 21, 2011 | Raypak RP2100 DIGITAL POOL HEATER R265
95 jeep grand cherokee died wont start,it cranks, checked fuel pump replaced filter cleaned injecters still nothing
Check to see if getting fire from coil or plugs. If not, your problem is most likely the Crankshaft Position Sensor.
$18 - $21 dollars. CPS is on left side of where transmission buckles to fly wheel, near top edge. One bolt and plugs in. (2 wires in plug)
Drive shaft to 4-wheel gear box might be in your way. No prob. 4 small bols and lower front end of drive shaft.
About a 45 - 60 minute job for shadetree mechanics, like myself, and 2 coffee breaks.
Prior syptoms of sensor going bad is engine rumbling real bad when coming to a stop, and sometimes dies but will start.
Hope this it.
Jun 09, 2009 | 1995 Jeep Grand Cherokee
Kenmore 2.1 cu. ft Washer water won't stop filing, cycle doesn't start...
most likely cause
kenmore pressure sensors work off a tube that runs from the bottom of the drum to the sensor, either the tube has come off the sensor body inside the control panel
  • open control panel reattach tube, wrap wiretie or twisttie to keep in plpace
or less likely cause
kenmore level sensors fail
there is a spring inside that stretches over time and mis reads, it is adjustable
  • control panel is still open from previous check
  • remove level selector from control panel, usually an unlock latch on the right side, rotate 45deg counter clockwise withdraw.
  • there is a 1/8 inch bolt head, turn right raise water level, turl left lower water level
Aug 23, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Whirlpool LGR4634J Gas Dryer Logo
90 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
