Question about Canon PowerShot S1 IS Digital Camera
Canon S1 flash stuck
The flash on my Canon S1 does not pop open. Any suggestions to gently rel;ease it or hints as to how I can manually trigger the release. Not sure where it is located. I want to make it so the flash is always open. It looks as thought he spring or catch is sprung because it doesn't close abolutely all the way. Thank you.
Mine does the exact same thing but I just pop it open manually when I need it. The great thing is that unless you have a very dark night shot you can pretty much shoot with out it, but don't be afraid to pop it out manually. It will close again!
Posted on Aug 11, 2007
Canon 60d internal flash not popping up
Check the metal tabs inside the notable rails as they need to touch the upper part of the rails to allow built in flash to work
Use a micro screwdriver to push the tabs up to the rail
GENTLY as that was what was wrong with my canon digital body
Jun 21, 2015 | Canon EOS 60D Digital Camera with 18135mm...
Use of Canon 60D's wireless function to control power on Canon 430EXII, being operated manually.
Your flash will fire optically. This is wireless but not radio.On the flashgun window move through the options until you see all of these in the window :- Flashing M, MZoom (24mm)
(the power output eg) 1/4
Flashgun icon CH1 Slave (blank)
The front panel should show a flashing red light. This means it is ready to receive the light signal from your onboard flash. From the camera menu select the in built flash control.
Set it to - Built-in flash - CustWireless
Flash mode - Manual flash
Wireless func - (single flashgun icon)
Channel- 1 ch
firing group - (flashgun icon)All
(flashgun icon) flashoutput - 1/64
selecting 1/64 should be sufficient to trigger the flash gun but not light the scene.
Manually pop up the onboard flash
In the view finder you'll see a number of green bars when half pressing the shutter and wait for them to go down to one which mean the camera and flashgun are communicating, fully press to take the shot and the flash (off camera) should fire.
Jun 26, 2017 | Canon EOS 60D Digital Camera
I have canon 450 d i face the problem error 99 if i open flash it showing error 99 give me answer
error 99 means flash is stuck . pop the flash and when it clicks, you have to smack the side of the camera to make it pop open
Nov 23, 2010 | Canon EOS 40D Digital Camera
The flash on my Canon EOS 400D won't work
Can you pull it up manually, Be careful when doing this but try opening it manually, it is possible that the catch for the flash is just stuck temporarily.
Jan 05, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
My Printer says error code 6A00 What do i do?
Try this especially if the printer had not been used for some time.
Switch it off, open the lid and manually (GENTLY!)slide the cartridge-tray to the left. Then you can see if a piece of paper or ink stucks it. Gently degunk the base pad with a little isopropyl alcohol on a Q-tip and ease the mechanism back.
Dec 01, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Cannon powershot s1 IS flash problem
Check with Canon. There could be a fix for it and covered under warranty as well.
Apr 20, 2008 | Canon PowerShot S1 IS Digital Camera
Flash will not pop up. Camera was returned to Canon but not repaired because warranty had expired. Problem was diagnosed as software, not mechanical-estimate $300.00. Flash did pop up once and operate...
This also happened to my camera and I am able to pop the flash up manually by flicking it up with the edge of my fingernail. It helps to simultaneously press down on the piece just above the microphone (I think) which is just above the viewfinder. That gives a little leverage.
Apr 02, 2008 | Canon PowerShot S1 IS Digital Camera
Flash does not pop up when it on automatic
hello
unfortunately, the only solution is to return it to the store where you bought it from or call Canon. I had that issue when I first bought my camera and i had to return it to the store
Mar 07, 2008 | Canon PowerShot S1 IS Digital Camera
Flash is Stuck
You have to yank on the flash, its the only way. Mine gets stuck most of the time, but does open on its own on rare occasion. it must be a defect of the model.
Aug 05, 2006 | Canon PowerShot S1 IS Digital Camera
Powershot S1 Digital Camera: Flash won't fire
Make sure the camera is not in Document mode . Document takes a picture with added contrast so text stands out. Make sure the camera is not set to Infinity focus . When you select Infinity Focus, the camera automatically turns off the flash and auto focus so you get sharp, clear pictures. Make sure the camera is set to Fill, Auto, or Red Eye flash. See your camera manual for details about setting the flash.
Dec 31, 2005 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
137 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
P.J. Ryan
P.J. Ryan
Level 1 Expert
Are you a Canon Camera Expert? Answer questions, earn points and help others
