Dell Inspiron 1501 all of a sudden says it has the "wrong power supply, will run some operations slowly, and will not charge"
    Master:
  • 409 Answers
Sounds like your PSU has failed (or is failing) contact dell for a replacement
Posted on Dec 07, 2008
My dell inspiron 1501 does not swith ON is this due to motherboard problem
There could be problem with motherboard. But before that can check with a different battery(fully charged).
Jan 18, 2012 | Dell Inspiron 1501 Laptop
Hi, I have a Dell Inspiron 1501 laptop, model no. PP23LA. My problem is that the system does not recognise the power adaptor/charger & will not charge the battery. The laptop will run with the power...
If the battery is not charging, the problem is most likely the battery...not the charger. Check around to see if you can get a battery replacement I think would be your best course of action. If you have a friend with a model laptop with the same battery you could always "test out the scenario" before purchasing one.
Good Luck
May 19, 2011 | Dell Inspiron 1501 Notebook
Not charging batteries
It sounds like you are using a 65 watt AC adapter or an Auto Air Adapter.
The system needs a 90 watt adapter to charge the battery while the system is on.
Jan 20, 2010 | Dell Inspiron 1501 Notebook
My 1501 Dell Inspiron wont turn on. The charger
The ac power jack needs to be either resoldered or replaced.
Dec 09, 2009 | Dell Inspiron 1501 Notebook
Dell 1501 inspiron does not recognize adaptor and will not charge. I am on second adaptor
If you are using a second adapter, then the problem could the battery or the power jack where the adapter is connected to.
First, try removing the battery and connect the adapter to the computer and to the wall socket. Turn the laptop on, and if it works, then the problem is the battery.
But if the laptop did not turn on, try slowly wiggling the adapter connector while it's connected to the power jack, if you find it loose, then you just need to contact a repair tech to tighten it.
But if the power jack is tight, but still the laptop is not charging, then this laptop needs repair.
Have a good day!
Nov 21, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 will not charge
open thebattery and refix it after clear dust from its slots.
also change adapter of same output.
if still problems then u have to purchase new battery.
Jan 07, 2009 | Dell Inspiron 1501 Notebook
My Dell Inspiron 1501 won't charge
If you're covered, Dell can replace the power converter on the motherboard for you. Yes, I have experience with this and yes, that should fix it.
Jan 03, 2009 | Dell Inspiron 1501 Notebook
Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
David Payne
David Payne
