Question about Orion Xtreme XTR8 Car Speaker
Orion XTR8MB Any one have any information on these? Like frequency response efficiency, I can't find anything on them on the web. I got them cheap and would like to use them but I have no idea of there capabilities. Help please ... DanL
  • 156 Answers
I couldn't find much; Orion is under different ownership than when the Extreme series woofers were manufactured. However, I found some T/S parameters embedded in the WinISD program; this will at least help you (or a shop) design a box for them. Impedance: 4 ohm Qts: .21 Vas: 11.3 liters or .399 cubic feet Fs: 68.5 Hz Xmax: .002 m Sensitivity: 97.3dB Power handling: 200 watts
Posted on Mar 07, 2007
Crossover to Es 100 to JBL 8400P. I have Harmon kardon 460 reciver?
setting Crossover frequency is trying to find the best frequency where the sub will see below that frequency and the es100 will see above that set frequency for maximum speaker efficiency.
8400P, i believe has a adjustable crossover frequency or cut frequency from 50-150Hz.
The e100 has a rated frequency response of 32Hz to 40kHz. So, the lows going to the sub, will allow the es100 to not have to handle deep bass frequencies.
So, I would suggest starting at 100Hz. That would mean your sub will be seeing roughly 100Hz and down, and the es100 will see roughly 100Hz and up.
Listen to your favorite music, and adjust accordingly.
Apr 05, 2010 | JBL Studio L 8400P Subwoofer
What are specs for a ported subwoofer enclosure for a 12" pioneer champ series
TS-W307D2
Design and Specifications
12” Dual Voice Coil (DVC) Subwoofer for Enclosure applications 1,200 Watts Max. Power Handling 400 Watts Nominal Rating Qts = 0.44 Xmax = 8.7mm Fs = 33.9 Hz Vas = 42.2 litres Frequency Response : 18 ~ 500 Hz. Efficiency : 89 dB Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms) Delivered with “jumper link”: ready for 4 Ohm use f0 (Lowest Resonant Frequency) : 33.9 Hz. Recommended Sealed Enclosure : 24 ~ 49.6 Litres RECOMMENDED sealed enclosure, not Ported. 24 Litres = 1464.569 cu. inches 49.6 Litres = 3026.777 cu. inches
Nov 23, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
I have a d5000 amp and its wired up to a 15.2 hcca orion sub when i turn it up high volume,it cuts out anyone know why
make sure you have the frequency cuts right. if ur giving the sub anything lower then 30hz (assuming ur using 15's) the amp will cut out to protect the woofers from overload
Nov 18, 2009 | Orion HCCA-D5000 Car Audio Amplifier
I have an Orion TV Mod TV1933b
Unfortunately, with most TVs this function is located only on the remote. If you could do it without the remote there would be a button on the panel of the TV labeled accordingly.
To purchase a replacement remote (a universal remote won't work with that model TV) call Fox International at 800-321-6993. They are the largest Orion parts distributor that I know. Orion doesn't sell parts directly to the public.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 11, 2009 | Orion1934 19" TV
What do hpf and lpf switchs do
Hello rwalinske, The abbreviations "hpf" and "lpf" stand for High Pass Filter and Low Pass Filter. They do exactly what their names imply. They allow frequencies above or below a specific setting, while blocking or attentunating frequencies below or above the setting. There's also a "band pass filter" which allows frequencies within a specific range below the high setting and above the low setting. Finally there's a "subsonic" filter which blocks inaudible frequencies below the threshold of hearing. The hpf is generally used in speaker component systems to send the high frequencies to the tweeters. The lpf is normally used with subwoofer systems and is set to send frequencies below the setting to the subwoofer. While most amps will amplify a wide range of frequencies, they are more efficient when the range is limited depending on their intended use. For example, a typical 2-channel amp might have a frequency response of 20-20KHz. When used to drive a set of normal speakers, you would not use either the lpf or the hpf, but simply let it send all frequencies to the speakers. But when used to drive a subwoofer, and operated in "bridged" mode, the amp can put all of it's amplifying power into frequencies than can be used by a subwoofer if the lpf switch is turned on. Hope this helps.
Jun 05, 2009 | Sony Car Audio & Video
Increase the power of my DJs4
Generally No Problem
BUT-------------------------------
Frequency Response will not be Flat any more.
(The Frequency Response between Different Size drivers is different)
Will Require More Power to Drive (Heavy Driver/Bigger Driver ususally requires more Power to move cone and efficiency is usually less)
Crossover Parts May not handle the Power in order to push bigger driver.
May encounter over driving to other Driver (Mid/Tweet) when you push with higher power in order to move the heavy cone.
Feb 02, 2009 | Audio Players & Recorders
Tv won't come on
check board-mounted fuse near power supply.
May 27, 2007 | Orion STV2763 27" TV
Car Audio & Video Logo
107 people viewed this question
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Dalynn Turner
Marvin
Marvin
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
