Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
In colder weather the garage door stops when opening half way.
This started last winter, went away all summer and now as the cold sets in is back. The door stops opening half way up. If you start to put it down and then hit the up button again it will go past that point. As of this past week it now stops at 2 or 3 points on the way up. What could be causing this. I have greased the screw drive regularly and have inspected for burrs or screw damage and there is not any. It acts like there is a binding or dead spot on the screw motor but the seasonality is odd.
  • 3 more comments
  • packrat16 Dec 09, 2008
    My door does the same thing any time the temperature drops into the 20's or lower. After opening and closing several times (the colder it is the more it goes up and down) it will close for good. It works fine the rest of the time. I'd love to know what to do to fix it.
  • jokermia Dec 09, 2008
    Same as the other post - the colder it gets, the less my door will work. It will go up a little, then half, then a little, etc. I'll have to cycle through opening the door at least 10 times before it will finally work. I ONLY have this problem during cold weather.
  • richpaul Dec 11, 2008
    The colder it gets the lower the door stops in the opening mode. In the 30's it stops about half way, in the 20's it stops about a foot from the floor. It only happens when it gets colder outside. What can we do to fix this?
  • Anonymous Dec 26, 2008
    where are the up and down ajustments located on the LIFTMASTER FORMULA 1
  • smokem Jan 09, 2009
    I tried adjusting the force. I've disconnected the door itself. Everything is lubricated. Sometimes the door doesn't open or close at all, or it stops while moving. When it doesn't work usually within a minute or so if I try again it works. This is very frustrating.
I had the same problem when it was cold the door would only raise a few inches and I had to keep pushing the opener numerous times before it would raise all the way.
On the back of the opener where the wires are connected there are 2 adjustment screws, one for up pressure and one for down. I increased the up screw and now it rsises all the way. Hope this helps.
Posted on Dec 10, 2008
    Problem Solver:
Because I disengaged the door and the motor and chain continued acting up, I found the following:
The controls (potentiometers) that regulate force get dirty in time and make poor contact inside which become evident when cold as the contact springs separate from the track. Cleaning the inside of them is the solution, I injected 91% alcohol with a fine hypodermic (G27)needle through any spaces I could see leading to the inside of the potentiometers while turning them.
I suppose one can use any alternative electronics cleaner or the good old carbon tetrachloride.
I experienced a de-programing of the remote possibly due to wetness of of the board and I had to use a blow dryer to bring her back to function because I powered it while still wet; and reprogrammed it after. It works well now, I have too doors and fixed both the same way. Good luck.
Posted on Dec 27, 2009
I have the same problem also. i used silicone lubricant on all rollers and have moved the side rails away from the door.( my door would rub against the rails in cold weather) then i adjusted the up tension higher and that seems to have worked so far.
Posted on Jan 23, 2009
On down door reverses in cold weather
A garage door guy says that in colder weather the weather stripping can become stiffer, less pliable, causing more drag or friction on the door. You may need to increase the down pressure a bit. If it's set in the normal range, try increasing it a little bit at a time, but don't max it out.
Dec 26, 2012 | liftmaster Chamberlain Garage Door Opener...
My 2001 mustang wont start in cold weather
sounds 2 things here. fuel pressure regulator or the idle air control valve. I an goingwith idle air control valve
Nov 12, 2012 | 2001 Ford Mustang
My garage door will only open half way. It appears to be getting stuck when it is opening.
If you haven't gotten your issue fixed yet... I had the same problem (stopped opening half way when using the remote, went down fine, could lift/close manually fine as well) and this happened on our first cold weather day of the year which was very telling. Anyhow, there are two gauges/dials on your garage door opener unit itself (above, where the light is) which controls how much torque/strength your door uses to open or shut through resistance. I turned mine up some and it now works fine; what likely happened was that the metal tracks or the wood frame condensed in the cold and was providing just enough resistance to stop it when opening - as they have a security device built in to stop if they meet any resistance. Hopefully this helps!
Oct 27, 2012 | Sears Craftsman LiftMaster Chamberlain...
The door was working fine for 8 years, last week it went down to about 2 inches from the floor, then went back up. No obstructions. I the started to adjust the chain...bad idea. Now in is inconsistant...
If this is a wood garage door (as opposed to steel), the problem may be that the door has become heavier. It might even be sagging enough to interfere with smooth operation. The added weight could be from being recently painted or the paint finish has gotten to the point where it's not sealing the wood anymore, so it's soaked up the summer humidity. Call an overhead garage door service company to take a look at it. They can probably make the adjustments to get it working. Then you might want to wait until a couple of weeks of dryer weather in the fall before you repaint the door.
Aug 14, 2010 | liftmaster Chamberlain Garage Door Opener...
Refrigerator/freezer stopped cooling during a heat wave
Good day,
Turning the thermostat to a warmer setting should not have caused the machine to quit cooling. Actually, the engineers give you far less leeway than you might think.
The controls are more in a class of fine tuning, otherwise people would be getting themselves into trouble. The manufacturers simply design the warm and cold parameters in a fairly narrow range.
The best setting is normal. When away, the machine will run far less simply because of no door openings. Opening a door lets in large amounts of air every time it's done, which is where your cost to run it exists.
Two things. One, if the temp in the kitchen exceeded 90 degrees for any length of time, you are operating it beyond it's design range, however two, it sounds as if the thermostat hung up, causing your issue. You may want to have it replaced, but it would be useless to call anyone when it's performing normally.
There is no test on thermostats other than by observing their action when the machine is not operating properly.
Jul 08, 2010 | Kenmore 64802 Top Freezer Refrigerator
Garage door not opening properly.
Check the springs on your garage door. If one is broken, the opener will not have enough power to raise up and it will stop like that.Or the up and down limit settings have gone off or bad.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door will not work in cold weather.
Leave car outside. Seriously, try a little more force to force adjustments.
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opener only opens a little bit
i have run into this problem before this might be of some help
check your track and see if someone has greased it if so get a rag and solvent and remove all grease from roller track this track is never to be lubricated in the summer grease thins and lets dooor move but in winter grase hardens and acts like glue binding door past set limits.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
You can turn up the up and down force on the motor head to give the unit more power. During colder weather the unit needs more power. Afterward do a 2x4 safety reversal test. thanks, BB
Sep 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
12,481 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
