Question about Olympus SP-350 Digital Camera
Zoom malfunctioning Whenever I try to zoom in using my Olympus camera, it zooms in a little bit of the way, beeps twice and zooms out. I have read the manuals and various troubleshooting things, but have found nothing that exactly described my problem.
Update the camera software online .....tha's what I did and it worked after 4 zoom error messages.
Posted on Apr 16, 2007
  • 114 Answers
Well u can´t do a thing....just send to the repair centre. that camera still under warranty. cause the model is younger them 2 years, they will replace the zoom lens, and don´t worry if it looks like that u drop it, they will fix for free anyway. good luck
Posted on Feb 24, 2007
    Novelist:
  • 107 Answers
This sounds like there is debris lodged in the zoom gears. Been to the beach lately? The gears in the zoom mechanism are very small, and even a tiny spec of sand or other debris can jam them up. Alternatively the sensor inside the lens that feeds back the position of the lens to the control circuit may be failing - so the camera thinks the lens has retracted all the way and stops. If the stoppage of the zoom action is abrupt then it is probably debris, if it is a smooth stoppage like the camera is stopping on purpose it is probably a position sensor. Either way the camera will require repair. David Millier Advance Camera Repair
I have a zooming problem on my Olympus Camedia C-700 Ultra, can you help?
It sounds like some part of the power zoom mechanism has failed. It could be repairable but with the age of the camera I doubt it would be worth it- something else may fail and a newer camera would also provide improved image quality.
Jan 27, 2015 | Olympus Cameras
My olympus c765 beeps when the shutter closes. how can it be silenced
In the top menu, select MODE. Select MENU, SETUP, the box-with-sound-waves icon, then OFF. For full details see "Beep" on page 152 of the Reference Manual.
Aug 01, 2012 | Olympus Camedia C-7000 Zoom, Camedia C-70...
My olympus sp-590uz will turn on but is then frozen.
I have had a similar problem. My solution was to check the zoom button. It seems that when it is "out of range" you can do nothing with the camera. Try to adjust the zoom a Little bit and you will probably be "in range" and the camera with work.
Jul 01, 2012 | Olympus SP-590 UZ Digital Camera
How do I eject the memory card from Olympus Camedia C-310 Zoom Digital camera
Simple press it a little and it will then eject a bit so you can grasp it for removal.
Bob
Oct 12, 2010 | Olympus Camedia C-310 Zoom Digital Camera
Olympus camedia c-3040 zoom how to delete pic
Judging by your explanation, the photos are on your sd digital memory card rather than the internal memory.
Since you are unable to delete just those 15, it sounds like you might have accidentally enabled the "protect" function.
Get out your manual (or download a new one) and read about how to protect/unprotect photos, and also read about how to format your card in camera - something you should do on a VERY regular basis for the health of your memory card.
While you have the book out, read ALL of it - twice! You'll be amazed how much you'll learn.
Oct 03, 2009 | Olympus Camedia C-3040 Zoom Digital Camera
How to change language setting from Japanese to english
I am going to have to say contact Olympus I have read all their manuals and notes on the camera and cant find nothing for language setting on it.
Aug 07, 2008 | Olympus Camedia C-3020 Zoom Digital Camera
Zooming with Olympus Stylus 820
Hey missy0528,
There are a few reasons your images might be grainy, one of which is your image quality is set to low. I would always have the camera set to the highest resolution possible, because you can always reduce the size of an image but you can never make it bigger. Another cause of grainy images in digital cameras is the sensitivity of the camera (ISO) is set to high. Since you are only seeing grainy images when you use the zoom the reason for the grainy images is most likely do to using the digital zoom. All a digital zoom does is crop the image much as you can do in some computer applications, and by doing this you greatly reduce your image quality. I would never use a digital zoom. Your camera has a 5x optical zoom and a 5.6x digital zoom. I would only use the optical zoom. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 09, 2008 | Olympus Stylus 820 Digital Camera
Olympus Camedia D-560 Zoom camera opens but won't zoom or shoot
Hey Realblond,
I would try resetting the camera back to factory specifications. You can do this by selecting mode reset under the shooting mode menu. If this doesn't work I would have it looked at be an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
May 09, 2008 | Olympus Camedia C-350 Digital Camera
Wide zoom flash problem
I haven't used that particular camera, but it would sound a bit like a problem with the white balance setting. Check your manual about white balance adjustment and try to take a few test shots manually adjusting the white balance to see if this might be the case.
Sep 13, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Zoom card problems
this is also my first posting, and I am having a simular problem with the same camera type. When I place the card in the camera, I get the No Card message. When I use the card in a multicard reader I can view all the images. Since the camera is not detecting a card, i can not attempt to format it
Sep 12, 2005 | Olympus C-3000 Zoom Digital Camera
Olympus SP-350 Digital Camera Logo
204 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
