Question about LG LN740 GPS
LG GPS not suctioning to windhield
My husband bought me an LG GPS last Christmas and I have just started using it. Problem is, the GPS won't suction to the windshield. It keeps falling off within seconds after being attached to the windshield. We have tried holding the GPS lightly while attaching it to the windshield as well as holding it tight against the windshield and than suctioning it in. But despite what we do, after seconds, it would fall off.
When we first started using it, it worked great - meaning it stayed attached to the windshield. Now it falls off 100% of the time after seconds of attaching to the windshield. Is it the unit or what can I do to make it stay attached to the windshield and is easy to take off and stick it back on after each use? So far, we are not very happy with the product due to this problem.
Thank you
  • Anonymous Feb 26, 2009
    no matter how i try to install the gps holder into the windshield, the suction cup cannot hold it and it keeps on falling off.
    Problem Solver:
  • 9 Answers
You must clean the window area using windex, or other cleaner, and wipe until dry. A clean winshield area provides the best suction, from the mounting bracket.
Slide the mounting bracket switch to Off & On a few times, make sure the suction cup is able to move(slightly) and that the small tap is facing the area with the notch in the metal.
After putting the switch to the middle, moisten the suction cup slightly
(saliva works bestter than water for some reason)
press it to the window with a slight amount of pressure
then move the switch, (Which should be set to Center!)
to lock it on firmly.
If this doesn't work, then there is a good chance the suction cup has become hardened by the sun. If that is the situation, you'll have to contact LG
(or a place that sells "knock off" brackets to get a replacement.)
I never leave my LG GPS in the car, when not in use. Even the bracket comes out, as I've seen what the sun can do to damage those plastic suction cups, fortunately, I learned it on a $5 replacement set for a Radar detector/Emergency Vehicle Alert device, and not a more expensive bracket.
Posted on Dec 14, 2008
    Problem Solver:
  • 5 Answers
I had this problem myself - other than going to the expensive option of getting a new suction cup, inspect the existing one carefully, and if here is no crack or break in the cup the problem could be caused by some slight distortion of the suction cup caused by it resting on other items in the glove box or similar. the distortion does not need to be much to stop an airtight seal. Here's the solution: Get a bowl of boiling water, soak the suction cup part of the cradle in the boiling water for a few seconds until it goes slightly soft,  remove it from the water and quickly, dry the part. Next quickly (whilst the plastic is still soft) apply the suction cup to the windscreen in the method indicated by the manufacturer -and that is it! The water softens the plastic so that it can be pulled into place by the vacuum of suction cup mechanism.
Hope this is of help to you or anyone with a similar problem
Posted on Mar 17, 2009
I need instructions on how to mount the nuvi 200w to my windshield
To secure the nuvi 200w to your windshield with the included suction cup mount (pictured below),
center the GPS on the clip, and tip the bottom edge on the bracket. Push the top of the GPS against the top clip until it clicks into place. Hold the bracket and GPS near the windshield where you like it best. Note where the suction cup is on the windshield in relation to the mirror, etc. Remove the GPS from the mount's clip by pushing the top tab back from the top of the GPS.
Clean the windshield (or portion that the suction cup will be stuck against) with a paper towel or newspaper and ammonia solution like Windex, etc. Clean the suction cup with the paper towel and Windex, too.
Lift the lever at the base of the mount - is shown in the picture above - if it isn't already. With the mount oriented as shown in the picture above, press the suction cup against the windshield where desired with one hand. Hold the mount firmly against the glass and use your other hand to press the lever on the base back toward the suction cup and glass. Press until it lays flat against the base / suction cup. Plug the power cord into the GPS and reinstall the GPS in the mount clips as done earlier.
To remove from the windshield, release the GPS from the mount clips, and lift the lever away from the base / suction cup. Locate the tab that is connected to the suction cup edge near the lever. Pull on the tab away from the glass to break the suction seal and remove from the windshield.
If this was helpful, please rate it 4 thumbs up. Thanks & good luck!
Sep 20, 2011 | Garmin GPS
Tomtom
HI,
Can you please give your zipcode so that i can find a local repair person for you.
Sep 04, 2008 | Tomtom GPS
My garmin nuvi 350 suction mount falls from the windshield after several days.
I believe they all do that, I own a Garmin and I bought what looks like a bean bag because I got tired of my suction cup mount falling off my windshield. The nice thing about the bean bag mount is that you can move it closer to you and place it anywhere on your dash. I bought mine on ebay from the Mount Guys they have a big selection of mounts for all types of GPS's take a look you might want to make the change too.
I hope this helps you out and if it did please leave me some feedback
Apr 03, 2011 | Garmin GPS
Suction base broke off. Can I get replacement piece?
Mine did the same thing. I used JB Weld epoxy and made a new base. Just filled the hole where the base goes in and the stuck what was left in the wet epoxy. Let it set up and it is as good as new, maybe better
Mar 06, 2010 | Amcor 3900 GPS Receiver
Suction cup does not stick to the base of the tom tom..Everytime I try to attach the suction cup, it just falls over. Help
  1. If you will stick the suction cup to your windshield make sure to clean it first use dry clothe and put pressure while rubbing it to the windshield.
  2. After cleaning it before you stick the suction cup to the windshield make sure the lock is release and then put a pressure and then while pressing it then that's the time you will lock it.
Feb 06, 2010 | Tomtom ONE GPS Receiver
Cant make Tomtom mount stick to anything
you need to pull the two ears on the sides of the suction cup away from the windshield before you tighten it down. its really easy once you figure it out. hope this helps
Feb 23, 2009 | Tomtom ONE GPS Receiver
I just bought the magellan maestro, and I can't get the suction cup to stick. The surface is clean and we wet it, but it loosens rapidly.
The GPS unit comes with an adhesive disk that must be installed on the surface where you want to place the GPS unit. The suction cup will only work with this adhesive disk. Once the adhesive disk is installed, the suction cup will hold. Here's the instructions magellan web site...
  1. Clean and dry the dashboard where the adhesive disk is going to be installed using enclosed alcohol pad.
  2. Remove the protective paper cover from the bottom of the adhesive disk; place the bottom of the adhesive disk firmly on the dashboard.
  3. Apply even pressure on the top of the adhesive disk for a secure fit (Allow 24 hours to cure).
  4. Place suction cup mount on top of adhesive disk.
  5. Firmly press suction cup mount down flat against the adhesive disk, press the suction cup lever down to secure the suction cup to the adhesive disk.
Nov 03, 2008 | Magellan RoadMate™ 1212 Car GPS Receiver
Garmin street pilot c330 - Suction cup lever broken
If you cannot un-assemble the suction cup assembly to fix it, then you would have to replace it. If it is under warranty, demand an exchange.
Jerry G.
Jun 01, 2008 | Garmin StreetPilot C330 GPS Receiver
LG LN740 GPS Logo
277 people viewed this question
Top LG GPS Experts
Nater13
Are you a LG GPS Expert? Answer questions, earn points and help others
