Question about Sennheiser Me66/k6 Professional Microphone
Microphone wiring for DV camera
I would like to know the correct wiring sequence to use a sennheiser Me66/k6 on a Canon Xl-1s. That is from the K6 XLR output into the XLR input on the Canon M100 adapter that in turn feeds into Audio One inpot Thanks Chris Owen
  • 68 Answers
On both xlr connection, you can see numbers on the plug from the out side and the inside. number 1,2 and three. 1 is for the ground, 2 for the hot wire and 3 is for the return, just match numbers. if you switch them, it will not work. just make sure one to one and so forth. good luck
Posted on Apr 01, 2007
Phantom Power Not working through K6
The K6 unit will require professional repair.
Nov 29, 2013 | Sennheiser ME66 / K6 Professional...
Sound only comes through one channel, have you any idea why? Norman Bevan
Most likely there is a broken wire inside the mic. You'll have to disassemble it to fix it, and it's not what I would call an easy job. Get a tech to help you, if you can. Chances are that it's just a wire that's broken and needs resoldering.
Also, on the following page, they talk about determining whether the problem is with the mic or headset, which should always be done first.
Sennheiser recommends sending it in for repair, and here's their site:
http://www.sennheiserusa.com/serviceandsupport_faqs_other-questions
Good luck, and hope this helps.
Nov 15, 2010 | Sennheiser K6 Professional Microphone
My k6 gsxr 750 hesitates after 12,000 rpm in the
stop running it so hard. check your plugs and wires then check distributer or coil pack which ever it has.
Apr 23, 2010 | 1998 Suzuki GSX-R 750 W
No sound pickup
For a mic like sennheiser ME66\K6 prof.mic.you have two options.
What might cause the blinking of the light,might be the battery,cause it functions in two ways,either by battery or by phantom power that needs to be activated by +48v power phantom on your mixer before it can work properly .
So you will do is either you get a replacement of the battery on get a mixer that has +48v power phantom power.
Jan 19, 2010 | Sennheiser ME66 / K6 Professional...
How big of a processer can i put in it?
current specs:
366 MHz AMD-K6-2 processor with 3DNow! technology.
read this;
http://www.amd.com/us/press-releases/Pages/Press_Release_826.aspx
The K6-2 was an x86 microprocessor introduced by AMD on May 28, 1998, and available in speeds ranging from 266 to 550 MHz. An enhancement of the original K6, the K6-2 introduced AMD's 3D-Now! SIMD instruction set, featured a larger 64 KiB Level 1 cache (32 KiB instruction and 32 KiB data), and an upgraded system-bus interface called Super Socket 7, which was backward compatible with older Socket 7 motherboards. It was manufactured using a 0.25 micrometre process, ran at 2.2 volts, and had 9.3 million transistors.
Nov 26, 2009 | Compaq Presario 1275 Notebook
Where can I find the mic that comes with the sony 250 and how much does it cost just for the mic?
The mic that came with the camera was very poor. Try a Sennheiser K6/ME64 (not ME66).
Nov 20, 2009 | Sony Dvcam DSR-250 Camcorder
Can i replace a k6 267 cpu with a k6-2 300 cpu
If it's a Socket 7 CPU, then yes. Make sure the Voltage/Clock jumpers are set correctly on the motherboard.
Nov 03, 2009 | HP (356877-001) Motherboard
AMD k6-2
the problem is xp which makes with an older K6-2 the clock speed lower. It takes a lot for a machine to run XP.
The best way is either go back to 98 or the only way could be ME.
not much what you can do about it otherwise
Apr 30, 2008 | AMD K6-2 , 450 Mhz
Sennheiser Me66/k6 Professional Microphone Logo
135 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
