Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
How do i choose tv1 or tv2 on my DVR?
I am running a DVR-625 with 2 TV's, here's the problem: if something is currently playing I can choose TV1 or TV2 by just pressing the record button and a screen comes up with that option. BUT if I want to record something in the future I can't seem to find an option to select which t to record it on..... is there a way to to record something that is not currently playing (i.e. tomorrow) and choose which tv to record it on?
  • 505 Answers
Your recording will record onto your one DVR box, for playback on either tv. On many satelite boxes you have to search for the program you want by entering the name. Then select the program and select to record the future broadcast.
Posted on Dec 07, 2008
When I change the channel on tv2, it also changes the channel on tv1. I have changed the address for tv2's remote, but it still changes tv1's channel.
Hi my nameis Mike Houston of DISH Network and I see your TV2 changes TV1 as well, thereis an easy fix to this problem. You will want to make sure the receiver is inDual Mode and then make sure the TV2 connection on the back of the receiver isin the right port. I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/same-video-2-tvs.I will leave my e-mail if you have any questions Michael.houston@dishnetwork.com.
May 22, 2011 | DISH Network DVR-625 DTV Receiver /...
No picture and the fan will not stop running,
Are you receiving no picture on TV1 or TV2?
If it is on TV1 you will want to verify your television is on channel 3 or 4. In some cases with the VIP receivers it may be 65 or 72 as well. I would also suggest going through the inputs on the receiver. Most tvs would list it as a "tv/video", "source", or "input". You'll also want to make sure all connections are tight and secure. At last resort you can try a hard reset by unplugging the receiver for 10 seconds.
It no picture is on TV2, you will want to confirm what channel the TV should be on by using TV1. On TV1 go to Menu then press 6-1-5 and change TV2 to the channel showing in "TV2 out".
With the fan running that is completely normal as the DVR function is always in use. It always has the capability to be paused and to use the rewind function so the fan is always cooling the hard drive.
Nick Franta
DISH Network Customer Service
Feb 07, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Hd-Fox T2 Displays InSt how do I get to Installation Wizard
Hi geroncolm my name is Mike Houston of DISH Network. The dual HD receivers allow for TV1 to show in standard and high definition. On the TV2 it will show in SD format only, even if the TV is a HDTV. We do have System Wizard and you will need to be in front of TV1 and hold down the 0 button on the remote for 10 seconds, it will enter the system wizard. Once you enter System Wizard it will allow you to reformat the remote.
Jan 14, 2011 | DISH Network DVR-625 DTV Receiver /...
With 2 tvs you set to record on 1 and it records on 2 instead?records on the opposite tv
Hello, Matthew Gonzales with DISH Network here. The default setting in our receivers are to automatically record everything onto TV2. You can change the setting by pressing menu-8- 5 (preferences-record plus), then you can either disable the feature, or set it to record onto TV1. If the feature is disabled, the show will record at whichever TV the timer is set up on. If it is set to TV1, all timers will attempt to record on TV1 (unless TV1 already has a recording going on it then it goes to TV2). Hope this helps.
Matt
Jan 04, 2011 | DISH Network DVR-625 DTV Receiver /...
Tvs sync together
The receiver seems to be in single mode. On the right side of the receiver press the front panel. A small pop open door will open and inside there will be a MODE button. Press this button and ensure both the green and blue lights are lit on the receiver. If they are now but weren't earlier this should solve the issue however there may be another issue.
Take the TV2 remote to the TV1 location associated with that system. With the TV1 remote and TV on press menu menu on the TV1 remote this will bring you to the System Info Screen. Near the bottom of the screen there will be two remote addresses- primary=TV1 and Secondary=TV2. Using the TV2 remote press and hold the small clear SAT button until all light across the top light up. Now key in a two digit number that is different from the original secondary address at this location and also different than the address for TV1. Now press the pound key and the SAT button will flash thrice. Now press the record button a few times until the secondary address changes to the number you selected. Once this is done you can exit out of all screens on all receivers and go to the TV2 location that was having the issue and it should be resolved. I hope this resolved your issue and thanks for using Fix Ya.
Feb 10, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Dish dvr 625 can't get dvd/vcr player to work with tv2..
if you have the coax hooked to the VCR in you will need to change the VCR channel to 22 and leave the TV itself tuned to 3 or 4.. I recommend setting the vcr to 60 or 73 to see if you can get reception on there as that is usually the two channels that TV2 is modulated on. You can check the modulation by going to TV1 and pressing menu-6-1-5 on the TV1 remote. Thanks for using Fix Ya. If I can be of further assistance please let me know.
Jan 28, 2009 | DISH Network DVR-625 DTV Receiver /...
Problem with DISH DVR 625
You can accomplish this by either going to the specific TV and selecting the record option at the time the program is about to come on or you can press menu-8-5 and change the record preferences. You can either set the DVR to record programs to the TV2 location by default or TV1 by enabling the record plus feature. In dual mode without record plus enabled all programs you select to record default to the tuner you are viewing e,g, if watching tv1 and selecting to record a program in the future it will record to the tv1 location.In single mode all recordings default to tv2 so you can continue to watch live tv from tv1. I hope this answers your question and thanks for using Fix Ya. Let me know if I can further assist you.
Dec 14, 2008 | DISH Network DVR-625 DTV Receiver /...
Hi,my brand new UHF remote wont operate the #2 tv??
Go to the tv 1 location with your TV2 remote. Turn TV1 on and using TV1's remote press menu-menu. You will be at the System Info Screen. Take TV2 REMOTE and press and hold the SAT button on the top left until all buttons on the top light up. Release the SAT button. Now key in a two digit number from 1to 16 and press the # key. The SAT button will flash three times. Now press the record button until the remote address for TV2 changes to the number you chose. When accomplished exit out of the screen with th TV1 remote and you should now be able to control TV 2. As a precaution ensure the remote antenna is on the back of the receiver. If you still have difficulty it may be required to move the remote antenna closer to TV2. I hope this answers your question. Thanks for using Fix Ya and let me know if I can of further assistance.
Dec 12, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 DTV - AUDIO PROBLEM ON LOCAL CHANNELS ONLY
I am probably stating the obvious here but here it goes:
If the 625 is connected to the tv using coax directly try using the RCA jacks to connect directly to the tv. If the 625 goes through a peripheral first, eliminate that peripheral and conect directly to the tv.If the problem exists with different media connections still at the same tv you can remove the coax off of the TV1(3-4) output on the back of the 625 and attach it to the TV2(CH60-73) output.You would then change your tv channel from 3 or 4 to ch 60air or 73 cable(which will be the same channel that TV2 is normally on in the remote room without the 625) Once you are on the right channel you will be able to tune TV1 to your local channel using the TV2 remote. If the audio is good here it eliminates the TV coax input on the TV1 and the coax cable connecting it as the source of the problem. You will have already eliminated any other inputs on the same tv as being faulty by using the other connecting media leaving you with the internal components of the receiver as being faulty. In this situation I know of no recourse except the obvious.
Aug 08, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 - Audio Problem
FIRST TRY CONNECTING THE RECEIVER TO THE TV VIA A DIFFERENT MEDIUM SUCH AS RCA INPUTS IF CURRENTLY CONNECTED WITH COAX.
If the problem is still evident you can send the TV1signal to TV2 or vice versa. This is accomplished by switching the output cables from tv 1 to tv 2 and changing the tv you want to use as your "monitor" to the proper channel. If viewing tv1 on tv2 change the TV channel from 60 air or 73 cable to 3. if using tv1 to view tv2 the process is the oppposite from 3 to 60air or 73cable.
To check which channel tv2 is modulated to do the following:
go to TV2 and with it on press menu, 6, 1, and then 5 on the Dish remote. That will dispay both tv output channels. You only need to be concerned with TV2.
This should isolate the problem by either it being present on both TV's using the TV1 output, which would mean the internals of the receiver are faulty, or if it is fine on the other TV it would indicate that the problem lies with the TV itself which is unlikely.This is assuming the FIRST method did noyt resolve the problem.
You may also want to try running the medium source from the back of the receiver directly to the TV.
This is all assuming you receive your locals through the satellite and not an off air antenna. Hope this helps you out.
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
154 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
