Question about Cobra 148 GTL 120-Channels Base CB Radio
148gtl, Taiwan when you modulate the meter swings backwards
Hello,I took this radio in for repair everything worked but there was no power or movment in the meters when keyed,so caps C95,109,173,174 was replaced and that brought the radio back to where it keyed up but only keys a 1/2 watt,the repair guy never finished it,he goes south for the winter.he said that the finals were putting out what they should,and the regulater also..Here is the specs on the radio..PCB 412,PLL MB8719..final is C1969 can you tell me what else I need to replace? on SSB it swings forward but its not powering up all the way.Can you help?
Thank you so much
  • 3 more comments
  • AnyMHz.com
    AnyMHz.com May 11, 2010
    yes more info please sounds like a dead key of 1/2 watts.
  • Tom Arsenault
    Tom Arsenault May 11, 2010
    1/2 watt deadkey or 1/2 watt swing? Has the power mod been done to the radio? Has a "modulator" or "super tune" been done?
  • Steve Tompkins
    Steve Tompkins Mar 14, 2013
    The idea is on AM Amplitude Modulation- You need full power to get high performance-its all audio modulation& antenna- AUDIO Mods make sthem super loud with only 1 1/2 watts of power- so the key is turned back some by old timers.
  • Steve Tompkins
    Sorry I meant to say"You don't need full power of 4 or 12 watts SSB- You just need 100 to 130% modulation by Power Mics or Modification of Audio mod(swing)Setback dead key to 1 watt to 1 1/2 is the old timers way.
  • Steve Tompkins
    Loudness is the result of setback 1/2 watt. But to clear it up& further range is to give it 3 watts deadkey.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
In the back is where power mods have been added...It sounds like a swing kit 1/2 watt deadkey to 25 watts which is a powerful modulation exceeding 100%. Its a 220uf capacitor in place of a jumper J1 or J(x) J something in some radios. if you replace the jumper and remove the capacitor 220uf or 470uf one.(near finals it will return to around 4 watt dead key) The result of 4 watts is modulation is flat;where if you adjust it to 2 1/4 watt to say 20 watts it will be very loud and modulation is at 100%.
Posted on Jan 06, 2012
My radio 148gtl d has low modulation
The Modulation adjustment is VR5, or you can cut D9, though I do not recommend completely disabling the AMC circuit. If VR5 does not have enough range, lift the banded end of D9 & solder a 1K-ohm resistor in series with the diode, then adjust for 100% modulation or to where the AMC circuit just starts to limit modulation.
Mar 04, 2014 | Cobra 148GTL AM/Single Sideband CB Radio -...
148 GTL - 4 Pin reading incorrect on meter.
The SWR circuit in the radio basically consists of a group of diodes and network---less than ten parts
I would get a schematic (old ones should do) and check the diodes and the path from them up to the meter.
Mar 11, 2012 | Radio Communications
I have a Realistic TRC-457.It has very low power and modulation.It is a virgin radio other than someone has replaced the final and driver.I noticet that I cant set the modulation and swr levels on my dosy...
How many watts does it do? If it swings say: 1.5 watts up to 4 watts, someone has installed a swing kit which has a very small carrier. In AM, carrier is not important, its modulation and swing that makes it loud. If its low Audio modulation then it may be that final has went bad too.
May 31, 2011 | Radio Shack TRC-503 CB Radio
How to increase the power out put of my 148 gtl-dx cobra to up to 5watts ?
clip diode D11..Turn coil ferrites near finals it will numbered like say: L10,L20,L14 or something etc. It should already factory go like 3 watts to 10 watts on a real out meter. The radio meter is a simulated but not accurate meter read. But crank ferrite coils until meter reaches 5 watts on radio meter..and lock it down there OK.
Apr 18, 2011 | Cobra 29 LTD CB Radio
Hello i own a cobra 29 ltd classic from 1993 today i was talkin skip like crazy!! running about 100 watts out of a texas star modulator!! i left for a while came back talked for a while everything was good...
sounds like the amp got hot and shorted on the bias.. and is keyed up a few watts. to fix you will have to have the amp repaired. new power transistor. to fix. 3174269649 Texas.
Dec 12, 2010 | Cobra 29 LTD CB Radio
Galaxy saturn tubro 100 watt power is sticking after key up.
Not sure what you mean completely. If you mean, when you key up, it keys at 100 watts and stays, then this is probably not a problem.
If it doesn't swing, it is either the watt meter you are using, or you have the power up too high, or both.
I usually key my saturn turbo around 80 watts. You have to be careful with these radios. they get hot fast and when they do, they get whacky. Make sure you have a PC fan plowing on the heat sink on the back.
The higher the dead key, the less swing you will see.
Now as for the watt meter....
There are a few types of meters out there. The 2 most common are ones that read AVG, or average watts, or PEP or Peak envelope power, which in short terms is your Peak wattage. Some meters do both.
An AVG meter will not read peak wattage, or swing. So if you meter is an AVG meter, or is set to AVG, then it will not read swing, and will show you your dead key, and that's it. Some times the needle will move a little, but it is not showing your true swing.
All in all a PEP meter is a loose representation any way, because you really cannot get an accurate reading when there is modulation. But it's close enough. You would need a spectrum analyzer to really see what you are putting out with modulation. AVG with no modulation is a more accurate reading however you cannot see swing.
Now PEP while transmitting in SSB with modulation, would be accurate. Just not AM, but like I said, its close enough and is what every one goes by.
I don't know if your Saturn turbo has been modded or peaked and tuned but, you should see a max of about 170 to 200 watts swing on that radio if its been done right. But you will need a PEP reading meter to see that.
I wouldn't run it past 80 watt dead key for long. With that radio you should really only run what you need. For instance, when I am using mine, I start at around 70--80 watts, and do a check, and if it's not strong enough I bring it up a little, until the audio sounds good to who I am talking too.
Like I said, you have to keep it from getting too hot.
Nov 04, 2010 | Radio Communications
Cobra 148GTL
Hello k007,
It sounds like you may have damaged the RF power amplifier stage of the CB. Since you were adjusting the antenna characteristics. Did you have a SWR (Standing Wave Ratio) meter connected while you were tuning the unit? If you did you might have noticed the needle go past the 1.2 mark when you were adjusting the antenna or the unit itself. In any event I think that the RF power Amp is shot.
Thank you,
Shuttle83
Nov 04, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
380 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
