Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Food freezes in refrigerator
I have a GE artica model #pss25ngmc, the temperature keeps going down to 26- 28 degrees even when it is set at 37. I want to know if I can fix this problem, i am pretty handy or call an expert to come and tale a look at it.
  • mdmvisa Jan 07, 2009
    I have a GE Arctica model #PS123SGMD, the temperature keeps going down to 26- 28 degrees even when it is set at 37. I want to know if I can fix this problem?
3 Suggested Answers
marka19
  • 1430 Answers
SOURCE: Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Posted on Jul 16, 2010
heatman101
  • 43501 Answers
SOURCE: food is freezing on refrig
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Temperature in refrigerator will not stay set. It keeps getting colder. I have a GE Artica model PSS27SGMD. It is a side by side with ice through the door. It is +- 9 years old
GE Artica had problems with the "Motherboards" originally installed. They have since switched manufacturers so my educated guess that is the problem.
Jan 08, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
All of a sudden my GE Profile Artica's freezer is at 25 degrees and the fridge side is at 43 degrees. I've forgotten how to "set" the temperatures but I'm afraid that's not the problem. Any ideas?
I would clean the condenser coil. This coil is located under or in back of the frig. When they get dirty the frig can't pull down the temp.
It's a common problem.
I hope this helps.
Aug 23, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile Artica S/S, model # PSS25NGMD BB. The fridge side is freezing the food and the digital thermometer keeps going back to 22-25 degrees. Also, yesterday the in-door water dispenser quit...
With temperatures like that the water tank is frozen stopping water to dispenser. This could be thermistors in fresh food section going bad or a combination of thermistors and motherboard. I can assist you if you have not already called for a technician. Sea Breeze
Mar 23, 2010 | GE Refrigerators
Freezer temperature v
This sounds like your motherboard,computer or control board(they call it different things in different models) is bad. It is responsible for the fan speed and timing of the defrost cycle. To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Sep 20, 2009 | Freezers
Everything in the refrigerator is freezing
The 37 degree reading you're seeing is the temp. setting, not the present actual temp. When it jumps back to 22-25 its telling you what the actual temp is inside the refrig....simply wait about 24 hours. It should then read about 37...that is, the temp you set it at 24 hours previously.
Nov 23, 2008 | GE Profile PFS22 33" Artica French Door...
GE PSW26M Artica Cooling and Ice Maker Problems
on the back of the frig is a small rectangle panel. inside that panel is the motherboard that controls the whole refrigerator. thoughs boards have been nothing but trouble. one of the problems it causes when it goes bad is the problem your having. replace the board to fix it
Nov 29, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
50 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
