Question about Dryers
My maytag dryer burning flame goes out to early and can not sustain the heat require to dry my clothes
    Habit-Forming:
  • 36 Answers
It sounds like the dryer is kicking the flame out on a hi limit thermostat. you need to check to make sure that there are no blockages in the vent line. if you can start the dryer with the so you can see the burner. If the flame seems to be very wide and not in almost a straight line that would confirm the problem. there should be a hi limit thermostat on the top of the burner and if the flame is touching or coming to close to the thermostat it will cause your problem
Posted on Jan 02, 2009
Maytag gas dryer not drying cloths
Here's an idea, is your machine in a well ventilated area? Gas powered devices have oxygen sensors that detect when the oxygen level drops to a dangerous level, this shuts off the gas, but not the machine. Put a fan in the room, open the window or door and try again.
Dec 29, 2013 | Computers & Internet
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
Dryer runs ok. igniter glows and lights flame. Flame burns for about 30 seconds and goes out. After a while it does it again. Minimal drying being done.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 19, 2011 | Maytag ADG7005AWW Gas Dryer
I have a Maytag SDG3606AWW Gas Dryer that is working but not drying the clothes. I have replaced the fuse, cycling thermostat on the blower motor. The gas flames is firing through the tube, goes on full...
heatman101;
Jun 13, 2011 | Maytag SDG3606A Gas Dryer
I have an old 1985 Maytag LDG313 gas dryer. It turns on just fine, but after 5-10 seconds the flame goes out. It comes back on again within a short time, but then goes out again. What part causes this...
It is supposed to cycle on and off. Basically like an oven does to maintain temperature. If the flame stays on all the time, the clothes will burn. So it is designed to cycle on and off. If it wasnt going on and off then you would have a problem. So as long as its drying the clothes, then you don't have a problem.
If there is something else its doing or not doing, let me know and i will help you.
Feb 28, 2011 | Dryers
My Maytag MDG7600AW gas dryer doesn't dry clothes any more. It take over 3 hours to dry at first. but now it won't dry any more. After reading the posts here, I open up the front panel and clean up all the...
The problem is the dryer coils are failing. They tend to fail as they heat up.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Apr 23, 2010 | Maytag MDG7600AW Gas Dryer
Maytag dryer not heating
Many gas appliances have safety devices that all need to be functional or you will not be sucessfull in passing fuel to the burner assembly.
There are 2 or 3 electrically controled coils on the gas valve (electromagnetic), these lift a pin in the control and gas flows as requested, these can fail and are realatively inexpensive and easy to replace, $4-25 depending on how many and where purchased.
Other sensors are 2-limit thermostats, radiant sensor, heat sensors, motor temp sensor, humidity sensor, switches (door etc.) all must function in the system to allow correct performance, lastly control panel, also most problems involve cleanlyness of the entire system and all associted exhaust piping.
There are no appliances that are free from maintanance so all require inspections and regular cleanings.
Dec 28, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Atlantis Gas Dryer
I would sstart by replaceing the gas valve coils they are located on the top of the gas vavle . they will weaken over time and will not stay energized to open the primary and secondary vavle
Jun 14, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Dryers Logo
97 people viewed this question
Top Dryers Experts
