Question about Lexmark Z53 Color InkJet Printer
Unable to connect printer to pc
When I connect my Z53 to my PC via the USB cable the PC does not recognize the printer. Tried different PCs and different USB ports. No luck. So obviously cannot set it up. This used to work once upon a time. Change the black ink cartridge and it stopped working. Any help/suggestions greatly appreciated.
  • Pope1 Jun 07, 2008
    my printer came without the installation cd and i can not find the download on the internet
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 1,362 Answers
Did you try a different USB cable if yes then try this.
O.K. first go to
-File
-Print
-Porperties
do you see your printer there? is it highlighted? does it have a checkmark?
if it's not there then you have to install it in Printers and faxes add a printer.
If if not highlighted then right click on it and "set as default"
then place your mmose over it and see if it says "ready" or offline
if  it's offline then the connection is wrong, leave mouse over printer and change connection it should change to 'ready"
Posted on Oct 15, 2007
Ematic lp2p tablet doesn't recognize usb or pc
1 port is a mini hdmi port to connect to a tv via a hdmi mini to hdmi cable,the other is a mini usb port,with the data cable that you can buy for it,you can connect to a computer,not just any usb cable will work,there is 1 for charging and 1 for data Ematic Edan XL EGS109 9 Inch Tablet 5 ft USB 2 0 Mini Micro Cable
Apr 27, 2015 | Tablets & eReaders
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
Tip
Samsung ML-2525W printer & Mac OS X 10.6
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable (3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch (4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless) (5) WiFi to router, with Mac/PC via Ethernet to router/switch (6) WiFi to router, with Mac/PC also via WiFi
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Also required different driver for wireless config (as opposed to USB).
My computer does not recognize my printer
Ensure you use the right driver to install your printer. Browse www.support.dell.com to get your printer model driver. And you will find it work.
Jun 10, 2011 | Dell 946 All-In-One InkJet Printer
Canon MP620 is not recognized by PC
Make sure you do not have it plugged in before you start the install. Also for the next install attempt, plug the cable in to a different USB port than the one you;ve previously tried.
May 23, 2009 | Canon PIXMA MP620 All-In-One InkJet...
HP Photosmart C7280 wireless connection
My experience is different. My DSL router died in the night and I had to install the old one. I just changed the wireless settings on my C7280, and now all three connections work. If no wire (ethernet or USB) is connected, the wireless connection works. If the Ethernet cable is connected, it works via Ethernet, and if the USB cable is connected, it works via USB. It seems to default in that order.
Oct 29, 2008 | HP Photosmart C7180 All-In-One InkJet...
Pc cant recognize the camera on the USB port
What is the Pc doing that shows you it is not recognizing the camera?
Have you looked in My computer at your drives to see if it is showing there? For some reason mine sometimes shows up my F drive instead of my camera drive. Then you can just click on the drive and open the folder for the photos.
Aug 22, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Vision M not recognized
I'm having the exact same problem. My zen is 'charging' but isn't detected anywhere on my pc and I'd leave it charging for days but nothing happens. I've tried different usb ports, reinstalling the software several times but nothing. I recently reinstalled Windows and with my new pc my Zen cannot work on it for some reason?! I put previous files from my old pc onto my Zen hoping that I could transfer them onto my new Windows pc but I fear I've lost the data on my Zen completely. Arggh, any suggestions guys? Please..x
Feb 29, 2008 | Creative Labs Zen Touch MP3 Player
"Off-line" error message
Go to control panel - printers. Right click your printer icon - select delete printer. Reinstall the software and drivers via CD supplied. May have to restart your computer when complete. Go back to control panel - select printers - select add a printer and follow the instructions. When finished print a test page.
Sep 13, 2006 | Lexmark X83 All-In-One InkJet Printer
Lexmark Z53 Color InkJet Printer Logo
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
