I have a dayton fuel trimmer garage heater. The pilot will light, but the main burners will not ignite. Could it be a faulty gas valve?
  • cangels5592 Dec 11, 2008
    What is the power phile? It has an ignition control box in the back. Is that the same thing as the power phile??? Thanks for your help.
  • Anonymous Mar 30, 2014
    Incoming Gas pressure 40psi & 230 volt electrical.when the machine is on that time ignition working but main gas burners is not working. I replaced one new gas valve recently but still not rectify the problem. Pc board to gas valve incoming supply 230 volt its came
    Main burner is not working. I don't know what is the reason. Please give me a solution.
  • Heating & Co... Master
  • 2,883 Answers
If it has a power phile on it then you would get pilot and no gas , change the power phile if this is the case ,
hope this helps
Posted on Dec 08, 2008
  • Paul Carew Dec 11, 2008
    a power phile generates a current from the pilot flame which holds open the saftey device on the gas valve , the same as a thermocouple .
    there could be a pressure swtich fitted and one of the tubes could be blocked ,
    you could try national energy they do spares for heaters and they my be able to help they are on the web .
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have a hanging Dayton in garage pilot lights fine furnace fires up runs 6or7 min. then burner and pilot go out
Does unit fan come on ??? Is flue clear as most units have a safety klixon if exhaust not venting properly.
Nov 24, 2012 | Dayton Gas Furnace Heater
We have a late ignition on start up, we cleaned the burners and replaced gas valve and still has late ignition.
if it has a pilot light is this too small causing it to light with a bang is what you mean with late ignition ??
Aug 22, 2011 | Dayton (3E227) Gas Radiator Heater
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Mar 30, 2011 | Dayton (3E405) Gas Radiator Heater
Pilot runs gas valve clicks but no ignition dayton 3e226c
There is a small Allen head screw in the gas valve that can be removed to test for gas after the gas valve. When the gas valve opens, gas should be present at that port. If none, you have a bad gas valve. If you gas gas, then there must be a restriction at the main burner.
Jan 21, 2011 | Dayton Gas Furnace Heater
How do I change the termocouple on an older Dayton furnace
Locate the gas valve,there will be three lines coming off the bottom and going into the burner compartment. The center one is the largest and is the main gas feed to burner. The one on right is usually silver and about 1/4 inch in diameter. It is the pilot feed line. The third is usually coppercolored ,this is the line for the thermocouple. You can trace thermocouple line down into burner comparment. The tip of the thermoucople usually slips into a friction fit mounted right in front of pilot burner.Slip old thermocouple out of holder and unscrew fitting from the bottom of gas valve. Install new thermocouple into pilot burner assembly,make sure thermocouple is fully seated and in direct line of pilot flame. screw fitting into bottom of gas valve. Set gas valve control to pilot,depress pilot button and light pilot. Hold pilot button down for about 2 mins.Tip of thermocouple should be cherry red. If it'snot try to reposition so thermocouple is more covered by pilot flame. Relese pilot button and if pilot stays on rotate gas valve control to on.Hope this helps you. Yhanks
Nov 20, 2010 | Dayton Gas Furnace Heater
I was wondering if the Dayton fuel trimmer model# 3E369B can be placed on blocks in the floor of my garage
Yes, it can be set on concrete blocks or anything non-flammable.
Also make sure that you do not run it if you are working with flammable gases or materials. I don't believe that that heater is sealed combustion.
Make sure also that you have correct venting so you don't wake up dead...
If you can take good precaution then go for it...
Heatman101
Jan 14, 2010 | Dayton Gas Furnace Heater
No ignition on dayton gas furnace. how hard is it to install new gas valve on a dayton furnace
not hard but before replacing check pilot light and thermocouple for proper function and setting if pilot light not in right position thermocouple wont open gas valve if electronic ignition check for power and proper gap on igniter also check stat for proper function
Oct 31, 2009 | Dayton Gas Furnace Heater
Propane patio heater ignition problem
I would change the thermocouple and here is why:
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners
May 27, 2009 | Endless Summer Blue Rhino 235000...
I have a Dayton gas heater Model 3E225
Does the main blower fan kick on? Also, if the heater is vented outside via a flue pipe, there may be a small (about 3 or 4 inches in diameter) vent fan that kicks on to ensure the exhaust fumes are evacuated through the flue pipe. If there's a problem with that fan, the burner won't light either.
Nov 20, 2008 | Dayton (3E379) Heater
Heating & Cooling Logo
261 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
