Question about Desa International CBP20T Wall Mounted Panel Heater
CBP20T floor heater will not stay burning
The heater has worked fine for several years when we got it brand new. Now, the pilot light will stay lit and the gas will flow if the unit is kept burning on the highest "5" setting. If it is turned down, or started at a lower setting, it will burn for only a few seconds up to a minute before going out completely. We have replaced the regulator and maintain gas in the outside supply tank. What can we do to resolve the issue?
Thanks for your help!
Keith
  • Boricuahbg Jan 05, 2009
    I have the same problem. My model is CBP20T..
It may be dirty, see link below for manual. I had the same problem and its now fixed.
http://12.153.20.74/manuals/107882-01M.pdf
Good Luck,
Boricuahbg
Posted on Jan 05, 2009
Pilot light will not stay lit. Have been lighting this unit for several years with no problem. Could it be thermocoupler? Thanks
The thermocouple does not affect the lighting of the pilot, but it does affect the pilot flame staying lit, once you release the gas control valve, before turning it to the ON position. If you could furnish more information about your heater (Brand & Model Number), I can supply you with more information on how to solve the problem.
Thanks for choosing FixYa.
Sep 16, 2011 | Heating & Cooling
Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Dec 17, 2009 | General Electric GE SmartWater Household...
Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Nov 12, 2009 | Heating & Cooling
The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
My 1.5 yr old gas water heater has a pilot light problem
YOUR WATER HEATER HAS WHAT IS CALLED A STANDING PILOT-STAYS LIT ALWAYS WHEN THE PILOT GOES OUT YOU LOOSE EVERYTHING. YOU HAVE TO REPLACE THE THERMOCOUPLE WHICH KEEP THE PILOT LIT. ONCE THE PILOT IS LIT THE THERMOCOUPLE SENDS IN MILLIVOLTS TO THE BURNER TO SAY ITS READY FOR BURNING
IF YOU ARE NOT FAMILURE WITH THIS REPLACEMENT PLEASE FIND SOME ONE WHO CAN. IT IS NOT HARD TO DO ASK A NABOR OR FRIENDS SOME HAS TO KNOW HOW. SERVICE COMPANYS ARE OUT FOR THE MONEY FOR A 10 MINUTE JOB
Aug 10, 2009 | Water Heaters
GWN10T pilot blows itself out
You must clean the pilot regularly to ensure it burns properly. Use a small can of air for cleaning computers and blow air through the pilot to remove dust and small particles that accumulate in the pilot barrel. Use several burst being that it is 2 years old and has not been blown out. THe manual references cleaning the pilot in the maintenance section.
Mar 29, 2009 | Desa International GWN10T Wall Mounted...
Pilot light won't stay lit on convection heater.
replace the therocouple. next year do not turn the pilot off
Nov 24, 2008 | Clairion Convection Heater - HC-1500
Desa International CBP20T Wall Mounted Panel Heater Logo
156 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
