Question about Jabra BT350 Bluetooth Headset Headset
Hi i have an verizon jabra bluetooth its universal im tryin to hook it up to my phone but when its pairing its askin for an code and i dont have it
5 Suggested Answers
Kidyubyub
  • 143 Answers
SOURCE: How to hook up a Jabra BT350 bluetooth
Make sure your cell phone's bluetooth is activated. Once you do that, you should be able to hold down the main button on the Jabra and once it turns on, it will connect with your phone.
Also, go to this site for Jabra. It links directly to the manual.
Posted on Jun 22, 2008
SOURCE: jabra bt125 broken ear hook
It's kinda cheesy, but a piece of #10 wire fits perfectly into the hole. That's what I'm using now. Neither the original is very comfortable, but they work.
Posted on Feb 20, 2009
SOURCE: get jabra in discoverable mode
ok i finally found out.. Turn on the jabra unit once on hold the answer button AND the volume up button at same time till u get solid blue light... It will flash like 8 times then go solid... At that point it can b found by all ur devices... the passcode is 0000... Enjoy
Posted on May 10, 2009
  • 5 Answers
SOURCE: Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Posted on Jun 29, 2009
homedesigner
  • 583 Answers
SOURCE: I cannot get my Blackberry Storm to pair with my Jabra BT2070.
You have to first put the Headset into discoverable mode. According to the Jabra website, this is done by pressing and holding the end/mute button until the light comes on steady. Follow the procedure for your phone to pair a bluetooth device to it. The PIN code will be 0000.
Posted on Feb 07, 2010
How do you pair blue tooth to Jabra VBT185z
it auto pairs .
set mobile phone to bluetooth on
finger click on blue tooth and select discover bluetooth devices
you should see mobile phone detect jabra vbt185z
then pin is 0000 if asked
http://uswww03.gnnetcom.com/jabra/verizon/vbt185z/Datasheet_VBT185z.pdf
Oct 19, 2015 | Jabra Radio Communications
How do i hook up jabra blue tooth on my apple i phone 4
Go to settings on the i-phone then to bluetooth it will automatically search for bluetooth devices close by, get your habra headset and press and hold down the main button for about three to five seconds so the light flashes on and off quickly, this is the pair mode, then once the i-phone has picked up the headset it will ask you for a pin to pair the two devices just enter 0000 it is the universal code for new devices, and you should be right
Sep 29, 2013 | Jabra Radio Communications
Manual for jabra t820
To pair the Jabra with a Verizon Wireless phone, the phone must have Bluetooth. Bluetooth allows a device to communicate and transfer data with another Bluetooth device without having to be physically connected to it. The instructions for connecting the Jabra with the Verizon phone vary slightly depending upon your phone model. Jabra headset instructions don't vary per model.
Jun 19, 2012 | Radio Communications
Can I sync the Jabra OTE3 with an iPhone4?
as long as the iphone supports bluetooth and it is not disabled it should. bluetooth is universal. some carriers will have the phone maker disable certain functions on certain phones.
For example, I had a friend who had verizon and the only bluetooth function available was hands free, couldnt do anything else with it even though the phone supported it, verizon had the other functions disabled
Sep 06, 2010 | Jabra Bluetooth Headset with Adjustable...
Im trying to connect my Jabra BT350 to my blackberry 8520 but my blackberry bluetooth wont even find the device even the Jabra headset is turned on.....i also lost my Jabra BT350 user manual cd and i dont...
The headset has to be in learning mode first for any phone to find it, press and hold the power on button for 8 seconds until the power light comes on and stays on then search for it with your phone, pairing code can be 0000
Aug 29, 2010 | Jabra BT350 Bluetooth Headset Headset
Feb 07, 2010 | Jabra Bluetooth Headset with Adjustable...
I dont know how to pair my jabra bt350 with my lg dare from verizon
hello mom. try putting your phone into activate new device and than your tooth into discover mode, than your phone will ask you for password key and put in 0000 and press the o.k. button and pair it. it works most of the time. good luck.
Jan 24, 2009 | Jabra BT350 Bluetooth Headset Headset
Cannot pair LG Voyager cell with Jabra BT150
do you have the bluetooth in discovery mode first before trying to pair?
Nov 30, 2008 | LG VOYAGER VX10000 Cellular Phone
Jabra BT135
Firs turn it off then..........
then hold the button for 10 seconds
it will now pair with your phone
the code is "0000"
Apr 25, 2008 | Jabra Bluetooth Headset with Adjustable...
Jabra BT350 Bluetooth Headset Headset Logo
82 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
