Question about Vacuums
Spotbot won't shut off, handpiece won't work.
When I run the Bissel Spotbot I am unable to use the manual hand cleaner, it will not work when trying to select it from the controls. When I try to turn on the unit to use the main system it starts up, but when you hit the stop button it will not stay off, but will stay off as long as I hold the stop button. I must unplug it to keep it off.
Thinking it has to do with the control panel I was looking into trying to get to the panel, but i'm at a loss on that. It's already out of warranty of course, so that's the only reason i'm getting into the system.
Paul
  • jenradano14 Apr 02, 2009
    I couldn't get the manual mode to work out of the box. When I called Bissell's tech center they offered to replace it. But due to the turnaround time, I'm just going to take it back to the store where I purchased it. If its out of warranty, you can find authorized repair centers on their website.
    Sounds like its a pretty common problem.
  • 33 Answers
SOURCE: My power brushes on my
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Posted on Jan 18, 2009
  • 61 Answers
SOURCE: Spray does not soak the carpet like it used to.
You probally have a clogged line. Either take it apart yourself and manually unclogg each line (requires a compressor) or take it to a local vac shop and have them do it.
Posted on Apr 15, 2009
  • 85 Answers
SOURCE: Unit starts and immediately shuts off
it has a bad circut board it is a defect and bissell will replace it
Posted on Dec 15, 2009
SOURCE: Accessing motor Miele Flamenco II
I had the same thing happen to my S251. Open up the vac. There is a third hidden screw in the groove where the accessory door is hinged. It's really well hidden, use a flashlight. Once its open, you'll have access to the power cord and you can test its conductivity. I didn't really believe it could be something as pedestrian as that, but the retractable power cord takes a lot of abuse, and eventually it fails. Replaced mine and the vac works great.
Posted on Mar 24, 2010
VacuumRepair
  • 438 Answers
SOURCE: Our Bissell Proheat Carept Cleaner 1699 is not
Hi Paul,
I just want to make sure that you still would like help with your Bissell. As you may see from my profile, when I help someone out, I always spend considerable time answering questions, taking pictures, and really making sure that you know how to fix the problem. Before I spend so much time doing this, I like to follow up and make sure that A. there's a real customer I'm answering, and B. that you haven't already fixed your machine. If you'd like me to walk you through this troubleshooting, please just add a comment here on the repair page.
Thanks,
Chris Jones
Posted on Apr 15, 2010
My Bissell Spotbot Pet cleaner stopped working. Took it out of the closet, plugged it in, No power? It worked great the last time it was used.
Well, if cycling it manually doesn't work and replacing the controller board didn't make a difference did you check the flex hose sensor? Bots won't run unless everything is clicked into place.
"Testimonials" don't continue the thread :)
I managed to dig up a copy of the service guide since I haven't owned a spotbot in years. http://evacuumstore.com/images/spotbot-repair-guide.pdf
Mar 22, 2017 | Bissell SpotBot Pet Spot Cleaner
Why is bissell spotbot leaking water into motor
Warranty? Owner's manual? troubleshooting in manual? Contact customer service usually they are helpful. Sounds dangerous, hopefully they will want to know.
Mar 13, 2015 | Bissell Spotbot Pet Hands-free Compact...
The top of my Spotbot separates from the bottom when picked up
There are a few screws that hold the two parts together. Check the housing and see if cracked around those screws.
SpotBot Supplies
800-775-6586
GoodVac com
Feb 22, 2015 | Bissell SpotBot Hands-Free Compact Deep...
Bissel spotbot mod.1200 wiring diagram
Hey Bill! We don't have the wiring diagrams, but our Authorized Service Centers can help you with your problem.
Here's a quick link to locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Mar 08, 2013 | Bissell SpotBot Robotic Wet/Dry Vacuum
My Bissel Spotbot will only let me use the Manual Mode, when I try to push "Set in Stain" or "Surface" stain the light won't turn on. My children were playing with it, but I...
There is a small magnet in the end of the hose. Under the phillips screw and plastic cover. Mine rusted to bits and stopped tripping the switch. A bit of a super strong hard drive magnet siliconed back in the end of the hose and all was fine.
May 26, 2011 | Bissell SpotBot Robotic Wet/Dry Vacuum
Solution not coming out
The solution is to throw the piece of junk out! Last week my BISSEL upright rug shampooer stopped spraying and I did all the *fixes* that I could find on the internet, short of new parts. It's in the Trash now. Today my BISSEL SpotBot stopped spraying...I've used it maybe 10 times. BISSEL makes junk, IMO.
Sep 09, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
I need a users manual for bissell spotbot
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Jul 28, 2010 | Bissell SpotBot Hands-Free Compact Deep...
Apr 15, 2009 | Bissell SpotBot Hands-Free Compact Deep...
Vacuums Logo
50 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
