Question about Toshiba Satellite A100-S8111TD Notebook
Don't reconise my cd drive
I restart my laptop some time it work but most of the time not work
Bootmgr is missing
Take one bootable windows cd rom , insert the cd rom in cd rom drive, restart your Laptop , go to bios setup and select boot from cd rom after then save and exit . your Laptop will boot from cd rom . it will take some time , when you will see action prompt , select R ( if your bootable windows cd rom is SP2 ) , select D ( if your bootable windows cd rom is SP3) . if you select R you will be prompt repair consoul , format C:\ then instal windows SP2 . if you select D , you will be prompt delite partition , delite partition C:\ after then select C to creat partition and install windows SP3. either of one windows install like that and problem will be solved. n.b. if you don,t have cd rom drive pls collect USB cd rom drive.
Jul 30, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
CD/DVD driver not working
A few solutions:
1. Have you tried to clean your cd/dvd lens? Probably your lens is getting weak.
2. For advance user: Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
- Look for DVD/CD-ROM drives and delete the subkey.
- Restart your machine.
3. Let Microsoft FixIt help you:
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
Worst case - Get a new CD/DVD-ROM for the replacement.
Don't forget to thumb up! ;) Good luck!
Feb 25, 2012 | Lenovo 3000 Y410 Laptop
The pc don't reconise the hdd
Test all leads that attach to your hard drive including electrical extensions,IDE
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps you
Jan 05, 2012 | Transcend 64GB IDE 2.5inch Solid State...
How to reboot fro cd
To boot your computer from a CD, first restart it. When it is starting up you will see a screen with your computer's manufacturer's logo (ie. HP, Acer, Samsung, Dell, etc.) On the bottom of this screen it should say what button to press to get to the boot menu. The button is usually escape, F1 or F2. You must press this button before the screen goes away. If you don't press the button in time then restart your computer and try again. Once you get to the BIOS boot menu, you will be presented a list of digital storage devices attached to your computer like USB drives, CD's, and hard drives. Use the arrow keys on your keyboard to select a device to boot from (select your CD drive.) Then press enter to begin booting from the CD. Good luck!
Jun 24, 2011 | Computers & Internet
Hello All, My dell latitude e5510 freezes when I try to play some videos, it may work for some time but it freezes after some time. This happens quite more times and I can only exit form the situation...
The laptop may be overheating. Check that all vents are clear and dust free. Listen for the internal fan. This should operate only occassionally. If it is operating all the time and speeds up just before the laptop freezes then something is causing the laptop to overheat. If the fan cannot be heard at any time, then the fan may be faulty.
May 17, 2011 | Dell Latitude - E5510 Laptop Computer...
How to reformat laptop
  • 1
    If you have the recovery cd, you can just pop-in the CD, select the reformat option and the installation process will continue automatically. Some laptop might have a special partition in the drive contains the operating system, drivers, etc. in case you want to reformat your laptop without the CD.
  • 2
    If you don't have the recovery CD, you usually can request one from the manufacturer. Otherwise, if you want to do a clean install, make sure you download all the drivers for your laptop, this may includes: motherboard, chipset, graphic card, sound card, modem, network card. Once you do that, put in the OS CD and start installing.
  • 3
    If you decided to do a clean install without the recovery CD, it would be best to create partition on your harddrive first, so you can have dedicated partition for operating system and backup. The next time you want to reformat your harddrive, you can just reformat that particular partition ex. C:\
  • May 05, 2011 | Computers & Internet
    My cd drive does not reconise any cd/dvd, cant install new software. I have a Fujitsu Amilo laptop.
    Does the drive show up at all under "My computer" (in Win XP) or "Computer" (in Win Vista or 7)? If not then try this "fix it" article from Microsoft. LINK
    If the drive shows up, but it won't read any type of disc, then the most likely cause is that the laser has died in the drive, and the drive would need to be replaced. This is fairly rare in newer optical drives, but was rather common in drives produced more than 6 to 8 years ago.
    Nov 14, 2009 | Fujitsu Computers & Internet
    Cd rom wont work
    well it depends what kind of disk are you using
    if it is a burnt disk<if you no what i meen> then you need and certen laser in your computer but if it is a reg, disk then i don no what to tell wrather than if your warrinty is valid then have it shiped to your prossecing manufacture or somthing like that
    Oct 11, 2009 | E-Machines emachines (emachinees) CD-ROM...
    Can't reconise my dvdrw rom drive
    check in bios settings your dvd is found or not reset your bios load optimal defaults.
    Mar 10, 2009 | Acer Aspire 5610 Notebook
    Toshiba Satellite A100-S8111TD Notebook Logo
    24 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
