Question about Plumbing
Broken fitting pumpout fitting on holding tank broken need new one
  • 1 more comment
  • Ron Krysiewski May 11, 2010
    I believe he is talking about a hot water heater. The drain valve it's not hard to break, especially if it's plastic. The tapping is 3/4" IPS you may have a hard time removing the old one. It is hard to understand your problem without seeing the problem. It would be nice to take a snapshot, and posting it. Always be careful of what you do! If all else fails Do Call A Plumber!
  • ideasnow May 11, 2010
    Please provide some more details. Would like to know more about the tank. The size of it, ease of access, etc.
  • Chris Ballard
    Chris Ballard May 11, 2010
    need some more information. What is the holding tank for (hot water?) What kind of fitting is it, what size and what material is it made of?
    Not familiar with industry standards in AUS but I can try.
  • 10,865 Answers
It is difficult but not impossible to remove the broken part with a lot of WD-40 and a good big pipe wrench. Then take the broken fitting to the hardware store and get one like it. Also purchase a tube of pipe dope and reassemble.
please mark this as a fixya!
Posted on Feb 27, 2009
How do I replace water lines from bathroom sink to outside drain lines
Supply or drain? The supply lines will be routed either behind cabinets or through the floor. You can use a sharkbite fitting to connect the new water line to the old and then pull until you have reached the location to be connected. Then install the required fittings to properly connect. The drain lines do not go directly outside. They are directly plumbed into a holding tank and then the holding tank is plumbed out to a valve and then a drain fitting.
May 03, 2014 | Dutchmen 2013 Kodiak 240BHSL
Tip
How to install a new flush valve
  • Flush valves are held to the tank by one large jam nut on the bottom of the tank. Installing a new flush valve usually requires removing the toilet tank from the bowl, which can be rather complicated. However, wall-mounted tanks may not need to be removed.
  • If the toilet tank must be removed, turn the water off completely, flush the toilet and hold the trip lever down to evacuate most of the tank water. Use a sponge to remove the remaining water. Disconnect the tank's inlet fitting from the water supply. If the flexible riser tube is damaged, replace it.
  • Then, unscrew the two rubber-gasketed bolts flanking the flush valve. These bolts go through the tank and bowl flange, with nuts beneath. Use caution–forcing the bolts may cause you to break the tank, bowl or both. Use plenty of penetrating oil on the threads. If they still won't budge without force, try wrapping masking tape around a hacksaw blade and sawing with the teeth facing you, so the blade cuts on the "pull" stroke. The layer of masking tape will protect the bowl's glazed surface from saw scratches.
  • The tank should now lift away from the bowl. Lay it upside-down on a throw rug or newspaper padding to protect it, and unscrew the large nut holding the flush valve to the tank. Use channel-locking pliers plus penetrating oil and extreme care to avoid breakage. Clamp a well-padded locking plier/wrench around the flush valve to keep it from rotating inside the tank.
  • Install the new flush valve according to the directions. The rubber gasket goes on the inside of the tank to prevent leakage. The flat washer fits on the outside to prevent tank damage.
  • Use new brass tank hold-down bolts, which will remain workable. Tighten the bolts just enough to compress the tank's soft rubber gasket and keep it from leaking.
  • Install the water supply riser to the tank and turn on the water.
on Jan 16, 2010 | Plumbing
How to change fuel line on Husqvarna Trimmer 128L
They are juat a pull in fitting. Get access to the fuel tank, the broken fuel line should just pull out the tank. The new full line goes back in through the top, just pull through into the tank until the hole in the tank sits between the 2 flanges on the fuel line.
Mar 20, 2013 | Husqvarna 128L Line Trimmer
Need holding tank and fuel tank capacities for 1989 rock wood 27.5th class c on ford Econoline 460 chassis
howdie ph your local part store and ask for gas tanks to fit Econoline van with 460 motor they will be the same capacities
Jul 24, 2012 | Ford Cars & Trucks
A weight in the gas tank has broken the gas line. How do I replace the line/weight part?
The weight is the fuel filter, the hose is an interference fit in the tank, you need to cut a point on the end of a new hose, feed it in through the top of the tank just far enough to grab it with a pair of long nose pliers through the fuel filler hole, pull it on through, connect a new fuel filteron the end, now drop it back into the tank, allow enough pipe to allow the filter to move freely in the tank.
Jul 31, 2011 | Poulan Garden
Hi I have a Husqvarna 136 chainsaw the fuel line seems to have seperated/broken off inside the fuel tank. I can not see any place to reconnect it anybody have any ideas
The fuel hose is all one piece from the tank up to the carb, it is just an interference fit in the tank, you will need to replace the complete pipe, the best way to do this is to **** the new pipe up the middle, about 30/40mm, take away one side of the pipe, it will now fit through the hole in the tank from the top, use a pair of long nose pliers through the fuel filler hole to grab the pipe and pull it on in, trim the end and re fit the fuel filter.
May 10, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Dishwater does not drain? where is the draain plug?
frigidaire dishwashers have two pumps (one for wash and one for pumpout). The small pump
is the one that does the pumpout, but first is the line clear where it connects to a disposal?
If this is a new install, is the knockout on the disposal connection removed, and is the disposal
working. (If it is not working then the water cannot drain through the disposal).
If you have an "Air Gap", it may be clogged. It is a small cylinder located next to the
faucet that serves no apparent purpose. If it is clogged the disposal will not drain. They are
about 7 dollars for a new one or you can disassemble it to clean it.
If your pump has failed you can find the serial number inside the door on the left to
get a replacement. I hope this helps.
Apr 27, 2011 | Frigidaire Dishwashers
What makes the speed odometer work improperly?
there is a sender in the fule tank this may be faulty so its not sending the info to the tank gage find the whire from this sender on the fule tank and short it out to the car bodywork the tank should then read full up if the wireing is good, if there is still no reading its likley to be the gage not working, or a broken wire to the sender,,,if the sender is broken it canot be fixed so fit a new one but check how much fule is in the tank before you try to remove the old sender or it may spill out every were, if you fit a new selder only add a gall of fule and see if there is a reading on the gage before adding more so you find out when the tank is realy empty,, never trust the gage to be true
Mar 05, 2010 | 1998 Jeep Cherokee
Will the new blue ttr plastics fit my old 1999 white ttr
you can use the new blue tank and it will fit just fine
Apr 13, 2009 | 2002 Yamaha TT-R 250
Return fuel nipple is broke from finger pump
The part previously recommended is not the correct part if it is the return line that is bad. Return line does not use the filter. If yours is like all the Ryobi units that I have seen you just need a piece (about 3-4" needed, but buy extra.) of 1/8 ID fuel line. You can usually order that from parts suppliers. Hardware stores will not have it. There is a fitting with a hose barb on it that fits through the tank. On the outside of the tank on the bottom there will be a round plastic ring, assuming the fitting is still in place and just the hose split at the fitting. Use a knife or thin blade of some type to pry off ring. It is actually around the hose that is over the barb. Keep ring, you will need again. Now push fitting up into the tank. You may have to trim off the hose that is outside the tank on the barb to get it to go into the tank. Shake tank around and get fitting out of tank. You will see there is a piece of hose on it yet. Remove that piece of hose. Now take the new hose and slide it onto the barb. It must go all the way to the top of the barb fitting so that the hose actually goes into the tank through the hole drilled in the tank. The OD of the hose acts as the seal to keep gas from leaking out of the tank. You may need to put some oil of some type (vegtable oil works well) on the barb and inside of hose to help slip it on and use some pliers with smooth or rounded jaws ( no serrations, will damage hose) to get hose on. Thread other end of hose into the fill hole of the tank and out the hole in the bottom of the tank. Hint: Straighten out paper clip or use small wire inserted into the hole from the bottom of the tank up towards the fill opening. Slip tube over that and use the wire to guid the tube directly to the opening. Pull hose through the tank. When fitting with barb and hose over it reached the hole in the tank it will resist being pulled through. Carefully pull firmly on hose to strech it so the hose/fitting "bulge" pulls into the hole in the tank. Look into tank and see when top flange of fitting is tight agains the bottom inside of tank. You should see bottom of barb outside of the tank with the hose on it. Once in place put the plastic retainer ring back over hose and push up to bottom of tank. It should fit snuggly when you get to the "bulge" area. Cut hose length as needed to fit onto straight tube fitting on primer bulb. Should be good to go. You may find that the other hoses are getting bad also and may want to change them at the same time, as they will probably be ready to crack also. You can reuse filter from tank if it is not plugged, just add a new hose as described previously. Otherwise you can order a new filter with the line already on it. That is the part that was recommended to you earlier. That line goes directly to the carb inlet barb. That barb is also hard to push hose on. Third line is from the return side of the carb to the suction side of the primer bulb. That is just a straight piece of 1/8" ID hose and pushes onto straight tube fittings, very easy to get hose on compared to barb fittings.
Hope this helps. Contact me if you have any questions.
Mar 04, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Plumbing Logo
122 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
