Question about Astra Mega II Espresso Machine
Whistling sound We have an Astra Mega II which has been working wonderfully for the past few months, but it has started whistling after five minutes of being on. It is annoying to the point that we can't use the machine anymore but being in a restaurant we kinda need it. It is coming from inside of the machine but I can't tell where. Any ideas?
    Problem Solver:
  • 7 Answers
The Astras have a vacuum relief valve, usually located on the boiler top. It looks sort of like a cap, with a pin or rod sticking up out of the middle, possibly with a ring through the end. While the machine is cold, you might try working that back and forth to see if it is stuck or not. If it is stuck, get it replaced.
Posted on Aug 29, 2009
Our LG tv has started making a vibrating whistling sound when you first cut it on, you can hear it get faster and faster then slowly goes away.. Also over the past few months I've notices the picture
the picture getting darker means the lamp has aged and u need to replace it another thing u need ti replace the mirrors in the light tunnel of the light engine they have faded secondly the noise means the colour wheel has aged you need to replace it u will have to replace the whole light engine cos the color wheel comes inbuilt the light engine and u will be ok ontact lg dealer in your area
Jul 19, 2013 | Televison & Video
Our LG tv has started making a vibrating whistling noise when you first cut it on, you can hear it get faster and faster, then slowly goes away. Also, I've notices over the past few months the picture...
It sounds that the horizontal output section circuit to your TV is to be checked. It is really a skilled work. Contact any service technician.
Theres a whistling sound after the car warms up & its hard to start
Sounds like a vacuum leak ,,causes lean condition ,can cause internal engine problems ,
Oct 12, 2017 | 2000 Daewoo Leganza
I have 2000 ford expedition and last few weeks its been making a whistling noise when accelerate, then past few days it's been running rough, idel low and shakes a bit then today check engine ligh
You might check the pulleys that the serpentine belt runs on. Make sure all are free wheeling and not loose or rough or make noise. You would need to remove the belt to check them.
Jan 16, 2013 | 2000 Ford Expedition
Clicking sound near cambelt
It might be the idler pulley or automatic tensioner. When either one dries up, the bearing wears out and starts causing whistling or whining noises, might need replacing. Try replacing the cheapest one, the idler pulley to see if it stops. If not, it might be your belt tensioner.
Jun 25, 2012 | Cars & Trucks
Shower head is making high pitched whistling nois
The holes are probably clogged from hard water. Take the whole head assembly and dip it in a bucket of CLR for an hour or so. Then rinse off and give that a try. If your cheap, you can use a bucket of white vinegar and a little bit o water, but the smell is most disagreeable.
Feb 12, 2010 | Grohe 28444000 Chrome Movario Movario Five...
Whistling from engine
This is a symptom of the inlet manifold gasket having a leak.The whistling is air going in through the small leak/hole in the gasket.With the throttle butterfly shut,air is getting sucked in the only way it can.Try tightening the inlet manifold bolts 1st.But more than likely the gasket needs replacing.Hope this helps
Jan 09, 2010 | 2000 Jeep Cherokee
I have a 2005 Honda Pilot. Just recently, I am hearing a light whistling sound coming from the passenger side of the car. It almost sounds like when you have something in a container that is hot and the...
If it started after the brakes where changed it might be a problem with installation (maybe brake wear indicators [metal tabs to allert when brake pads are low]) or could just have a pebble stuck inbetween pad and disc. sometimes if the pad /disc wears unevenly, one or the other will develop a lip and this may cause your whistling sound.
Jul 29, 2009 | 2005 Honda Pilot
Loud whistling sound on 1999 GMC Suburban
It sounds like your Idler pully bearing or your tensioner bearing. Regardless change them both and the surpentine belt too. The sound is letting you know that the bearinf is bad and will fail soon. Good luck
Apr 06, 2009 | 1999 GMC Suburban
Whistling noise
Sounds as if it needs descaling. Do you live in a hard water area?
Aug 09, 2008 | Cuisinart CJK-17BC Cordless Electric...
Astra Mega II Espresso Machine Logo
221 people viewed this question
Top Astra Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Astra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
